查看: 1411|回复: 2
[NUCLEO-H743ZI] 为什么stm32H7使用串口DMA发送数据全0,阻塞式串口发送数据正常
发表于 2025-4-25 10:12:18 | 显示全部楼层 |阅读模式
最近在测试NUCLEO-H743ZI开发板接受麦克风音频数据(24位数据采样率48k)(I2S接口DMA),并通过串口发送数据,
经过测试串口阻塞式(HAL_UART_Transmit)发送数据显示正常,但是使用串口DMA(HAL_UART_Transmit_DMA)发送数据串口调试助手接收到的全是00,不知道为什么.
测试了发送数组是局部变量和全局变量都是这样的问题,但是串口DMA发送特定数据是正确的
串口DMA配置代码:
void initUART2()
                GPIO_InitTypeDef  GPIO_InitStruct;
          __HAL_RCC_GPIOA_CLK_ENABLE();
                __HAL_RCC_GPIOB_CLK_ENABLE();
                __HAL_RCC_GPIOD_CLK_ENABLE();
                __HAL_RCC_DMA1_CLK_ENABLE();
                __HAL_RCC_DMA2_CLK_ENABLE();
          __HAL_RCC_USART2_CLK_ENABLE();
                HAL_NVIC_SetPriority(DMA1_Stream3_IRQn, 0, 0);
                HAL_NVIC_EnableIRQ(DMA1_Stream3_IRQn);
  /**USART2 GPIO Configuration
    PA2     ------> USART2_TX
    PA3     ------> USART2_RX
    GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 1000000;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  huart2.Init.ClockPrescaler = UART_PRESCALER_DIV1;
  huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetTxFifoThreshold(&huart2, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_SetRxFifoThreshold(&huart2, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
    Error_Handler();
  if (HAL_UARTEx_DisableFifoMode(&huart2) != HAL_OK)
    Error_Handler();
    /* USART2 DMA Init */
    /* USART2_TX Init */
    hdma_usart2_tx.Instance = DMA1_Stream3;
    hdma_usart2_tx.Init.Request = DMA_REQUEST_USART2_TX;
    hdma_usart2_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
    hdma_usart2_tx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart2_tx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart2_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart2_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart2_tx.Init.Mode = DMA_NORMAL;
    hdma_usart2_tx.Init.Priority = DMA_PRIORITY_VERY_HIGH;
    hdma_usart2_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init(&hdma_usart2_tx) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(&huart2,hdmatx,hdma_usart2_tx);
          // 配置DMA传输完成中断(TCIE)
    __HAL_DMA_ENABLE_IT(&hdma_usart2_tx, DMA_IT_TC);
          HAL_NVIC_SetPriority(USART2_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(USART2_IRQn);
void DMA1_Stream3_IRQHandler(void)
  HAL_DMA_IRQHandler(&hdma_usart2_tx);
void USART2_IRQHandler(void)
  HAL_UART_IRQHandler(&huart2);
// 串口DMA传输完成回调
void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart) {
    if (huart->Instance == USART2) {
                        BSP_LED_On(LED2);
      uart_tx_complete = 1;
发送代码:
            // 串口发送   将符号扩展后的数据拆分为3字节(MSB在前)
            uart_send_buffer[i * 3]     = (signed_data >> 16) & 0xFF; // 最高字节
            uart_send_buffer[i * 3 + 1] = (signed_data >> 8)  & 0xFF; // 中间字节
            uart_send_buffer[i * 3 + 2] = signed_data          & 0xFF; // 最低字节
            HAL_UART_Transmit_DMA(&huart2, uart_send_buffer, sizeof(uart_send_buffer));
 楼主| 发表于 2025-4-25 13:15:02 | 显示全部楼层
发表于 2025-4-26 10:09:14 | 显示全部楼层
三个地方
1、这个要用全局变量uart_send_buffer
2、这里的对勾仅勾选第2个,因为0x2000 0000是DTCM,不支持通用DMA
3、DMA UART函数前添加一个函数
SCB_CleanInvalidateDCache
GMT+8, 2026-10-24 16:49 , Processed in 0.357740 second(s), 27 queries .
