查看: 875|回复: 2
[LVGL] 按键的时候能打印 LV_KEY_ENTER ;但是不会触发事件, 进入encoder_key_handler打印,求助大佬指点
发表于 2025-4-7 19:13:47 | 显示全部楼层 |阅读模式
使用LVGL8.3.3  ,使用了编码器;
问题:按键的时候能打印 LV_KEY_ENTER ;但是不会触发事件, 进入encoder_key_handler打印,求助大佬指点
lv_group_t * g_encoder_group; // 焦点组[/p]extern lv_indev_t * indev_encoder;
static void encoder_key_handler(lv_event_t *e) {
    lv_event_code_t code = lv_event_get_code(e);
    lv_key_t key = lv_indev_get_key(lv_indev_get_act());
    printf("event code=%d,  key=%d \r\n", (int)code, (int) key);
    uint32_t key1 = *(uint32_t*)lv_event_get_param(e);
    printf("Event key1: %d\n", key1);
    lv_indev_t *indev = lv_indev_get_act();
    printf("Input device type: %d\n", indev->driver->type);
void setup_scr_screen111(lv_ui *ui){
// 创建焦点组
    g_encoder_group = lv_group_create();
    lv_indev_set_group(indev_encoder, g_encoder_group); // 编码器绑定到焦点组
    // 将对象加入焦点组(例如容器和按钮)
    lv_group_add_obj(g_encoder_group, ui->screen_btn_CC);
    lv_group_add_obj(g_encoder_group, ui->screen_btn_CV);
    lv_obj_add_flag(ui->screen_btn_CC, LV_OBJ_FLAG_CLICKABLE);
    lv_obj_add_flag(ui->screen_btn_CV, LV_OBJ_FLAG_CLICKABLE);
    lv_obj_set_style_bg_color(ui->screen_btn_CC, lv_color_hex(0x007ACC), LV_PART_MAIN | LV_STATE_FOCUSED); // 按钮聚焦样式
    lv_obj_set_style_bg_color(ui->screen_btn_CV, lv_color_hex(0x007ACC), LV_PART_MAIN | LV_STATE_FOCUSED);
    // 绑定事件到容器和按钮
    lv_obj_add_event_cb(ui->screen_btn_CC, encoder_key_handler, LV_EVENT_KEY, NULL);
    lv_obj_add_event_cb(ui->screen_btn_CV, encoder_key_handler, LV_EVENT_KEY, NULL);
    lv_group_focus_obj(ui->screen_btn_CC); // 手动设置焦点
    printf("%d",lv_obj_has_state(ui->screen_btn_CC, LV_STATE_FOCUSED));
static void encoder_read(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
    data->enc_diff = encoder_diff;
    data->state = encoder_state;
    if((key_steady == 0) &&(encoder_click == 1)){
        encoder_click = 0;
        data->state = LV_INDEV_STATE_PRESSED; // 中键按下为0
        data->key =  LV_KEY_ENTER ;
        printf("LV_KEY_ENTER \r\n");
    else if((key_steady == 1) &&(encoder_click == 0)){
        encoder_click = 1;
        data->state = LV_INDEV_STATE_RELEASED; // 没有键被按下
        data->key = LV_KEY_ESC; // 默认返回 ESC 键(可选)
        printf("LV_KEY_ESC \r\n");
    // 2. 处理旋转(仅在无按键操作时生效)
    else if (encoder_diff != 0) {
        data->key = (encoder_diff > 0) ? LV_KEY_RIGHT : LV_KEY_LEFT;
        printf("encoder_read state=%d,  key = %d\r\n", data->state, data->key);
    encoder_diff = 0; // 清零旋转差值
发表于 2025-4-8 10:42:20 | 显示全部楼层
帮顶。
发表于 2025-7-1 23:55:17 | 显示全部楼层
触发按键事件后,要获取按键值不是这样获取的,应该像下面这样
if (code == LV_EVENT_KEY) {
    uint32_t key = lv_event_get_key(e);
GMT+8, 2026-1-12 08:06 , Processed in 0.045150 second(s), 25 queries .
