查看: 2967|回复: 11
[其它] Source Insight发布更新4.0.0141
More we do, more we can do.
发表于 2025-4-7 13:51:34 | 显示全部楼层 |阅读模式
官网:Source Insight - version 4.0.0141
Fix: C/C++/C#: Some class or struct member names used inside initializers where not correctly recognized.
Fix: Resizing docked panel windows didn't resize correctly if the system's Window Performance settings for "Show window contents while dragging" was disabled. This could also affect Remote Desktop connections if the corresponding option was disabled for remote connections.
Fix: Using the "Set all Panel Fonts and Colors" feature in Options > Preferences > Font & Colors did not save the Symbol window pane font settings in the configuration file so they would not persist in subsequent sessions.
Fix: Code collapsing bug when collapsing an 'else' block that starts on the same line as the closing { } block. For example:
} else { ...
Fix: Opening a new project did not refresh the File > Recent File menu right away, even though the recent-file-list is stored as part of each project.
Fix: Formatting of text with style properties using capitalization changes or expanded spaces was sometimes drawn incorrectly.
Fix: C++ function signature types are now recognized. For example:
typedef int some_function(int foo) noexcept;
Change: You can now specify the folder where log files are stored by selecting Options > Preferences > Folders. You can also disable logging completely by selecting Options > Preferences > General > Logging and de-selecting the option "Output to log file". Furthermore, the logging preferences are now stored in the Windows Registry and apply as soon as Source Insight starts up. Previously the logging was turned on by default until logging preferences were loaded later from the configuration file.
Change: Removed shaded font text on panel titles.
New: Big-Endian UTF-16 encoding with BOM (Byte Order Mark) is now supported. If you open a file without the BOM in big-endian format, Source Insight will not be able to automatically decode the file. In this case, use File > Open As Encoding and select "UTF-16 BE no BOM".
发表于 2025-4-7 14:29:03 | 显示全部楼层
谢谢分享。
发表于 2025-4-7 17:44:35 | 显示全部楼层
附件
Source Insight – version 4.0.0141.zip
19.43 MB, 下载次数: 132
发表于 2025-4-8 08:55:01 | 显示全部楼层
Source insight就小更新,再没有大功能更新就要被遗忘了
发表于 2025-4-9 01:21:30 | 显示全部楼层
感谢楼主分享
发表于 2025-4-9 08:33:43 | 显示全部楼层
挺好!!
发表于 2025-4-9 12:49:17 | 显示全部楼层
之前还有人汉化,现在都不搞了
发表于 2025-4-9 14:47:44 | 显示全部楼层
太贴心了, 谢谢. 马上用上最新版本.
发表于 2025-4-11 08:52:40 | 显示全部楼层
太感谢了,正在寻找新版本
发表于 2025-4-11 11:25:45 | 显示全部楼层
感谢,已经很久没找到新的版本了
发表于 2025-4-26 11:00:58 | 显示全部楼层
感谢楼主分享,但是用的时候license用不了可能是怎么回事儿
发表于 2025-4-27 22:02:39 | 显示全部楼层
                          同问
GMT+8, 2026-11-24 08:19 , Processed in 1.875048 second(s), 27 queries .
