查看: 1228|回复: 1
[有问必答] MFRC522改用SI522问题
发表于 2025-4-3 14:14:23 | 显示全部楼层 |阅读模式
MFRC522用了很多年没什么问题
最近想替换成SI522试下
发现寄存器读取有问题
参照文档 https://item.szlcsc.com/datasheet/SI522/3027565.html?spm=sc.gb.xds.a&lcsc_vid=FVFcUlEHFQcIAQZfQVVaVAZWRldXVQdVQFhaVgZRFFAxVlNSRFRWU1JWR1FcXzsOAxUeFF5JWBYZEEoVDQ0NFAdIFA4DSA%3D%3D
写了之后
想试下刷M1卡读下卡号,发现寻卡一直失败。
Updated Gain: 70
Fixed RF Control: 83
FIFO Level: 01
IRQ Status: 14
FIFO Data: 26
No card detected or error, Status: 0, BackBits: 08
天线打开成功的,增益0x00,0x10,0x20,0x30,x40,0x50,0x60,0x70都试了,结果一样的
SPI时钟频率降低试了2M,1M,500k,125k 结果也一样
有没有大佬用过SI522的,帮忙指导下
下附代码:
#define READER522_CS_LOW()      HAL_GPIO_WritePin(READER522_CS_GPIO_Port, READER522_CS_Pin, GPIO_PIN_RESET)
#define READER522_CS_HIGH()     HAL_GPIO_WritePin(READER522_CS_GPIO_Port, READER522_CS_Pin, GPIO_PIN_SET)
#define READER522_RST_LOW()     HAL_GPIO_WritePin(READER522_NRST_GPIO_Port, READER522_NRST_Pin, GPIO_PIN_RESET)
#define READER522_RST_HIGH()    HAL_GPIO_WritePin(READER522_NRST_GPIO_Port, READER522_NRST_Pin, GPIO_PIN_SET)
// SPI 写寄存器
void READER522_WriteRegister(uint8_t reg, uint8_t value)
  uint8_t data[2] = {(reg << 1) & 0x7E, value}; // SPI 写命令格式
  READER522_CS_LOW();
  HAL_SPI_Transmit(&READER522_SPI, data, 2, 100);
  READER522_CS_HIGH();
// SPI 读寄存器
uint8_t READER522_ReadRegister(uint8_t reg)
  uint8_t addr = ((reg << 1) & 0x7E) | 0x80; // SPI 读命令格式
  uint8_t value = 0;
  READER522_CS_LOW();
  HAL_SPI_Transmit(&READER522_SPI, &addr, 1, 100);
  HAL_SPI_Receive(&READER522_SPI, &value, 1, 100);
  return value;
void READER522_ClearBitMask(uint8_t reg, uint8_t mask)
  uint8_t tmp = READER522_ReadRegister(reg);
  READER522_WriteRegister(reg, tmp & (~mask)); // 清除特定位
//通讯时返回的错误代码
#define MI_OK                 0
#define MI_NOTAGERR           1
#define MI_ERR                2
void READER522_Reset()
  READER522_RST_LOW();
  HAL_Delay(10);
  READER522_RST_HIGH();
  HAL_Delay(50);
void READER522_AntennaOn(void)
  uint8_t value = READER522_ReadRegister(0x14);
  if (!(value & 0x03))
    READER522_WriteRegister(0x14, value | 0x03); // 打开天线
  HAL_Delay(10);
  uint8_t rfControl = READER522_ReadRegister(0x14);
  printf("Fixed RF Control: %02X\n", rfControl);
bool READER522_Init()
  READER522_Reset(); // 复位芯片
  READER522_WriteRegister(0x01, 0x0F); // 复位 SI522
  HAL_Delay(10);
  READER522_WriteRegister(0x0A, 0x80); // 允许 FIFO 写入
  READER522_ClearBitMask(0x14, 0x80);  // 强制 ISO14443A
  // 关闭天线
  READER522_WriteRegister(0x14, 0x00);
  // 设置定时器
  READER522_WriteRegister(0x2A, 0x8D); // TMode 寄存器:内部定时器设定
  READER522_WriteRegister(0x2B, 0x3E); // TPrescaler
  READER522_WriteRegister(0x2D, 30);   // TReloadLow
  READER522_WriteRegister(0x2C, 0);    // TReloadHi
  READER522_WriteRegister(0x15, 0x40); // TxAuto: 100%ASK
  READER522_WriteRegister(0x11, 0x3D); // RxSel:增益控制 48dB
  // 调节增益
  READER522_WriteRegister(0x26, 0x70); // 设置最大增益
  HAL_Delay(10);
  uint8_t gain = READER522_ReadRegister(0x26);
  printf("Updated Gain: %02X\n", gain);
  // 使能天线
  READER522_AntennaOn();
  return true;
int8_t READER522_ToCard(uint8_t command, uint8_t* sendData, uint8_t sendLen, uint8_t* backBits)
  uint8_t status = 1;
  uint8_t irqEn = 0x00;
  uint8_t waitIRq = 0x00;
  uint8_t lastBits;
  uint8_t n;
  uint8_t i;
  switch (command)
  case 0x0C: // 发送 REQA / 寻卡
    irqEn = 0x77;
    waitIRq = 0x30;
  READER522_WriteRegister(0x02, irqEn | 0x80); // 启用中断
  READER522_WriteRegister(0x04, 0x00);         // 清除中断标志
  READER522_WriteRegister(0x0A, 0x80);         // FIFO 初始化
  // 写入 FIFO
  for (i = 0; i < sendLen; i++)
    READER522_WriteRegister(0x09, sendData[i]);
  READER522_WriteRegister(0x01, command); // 执行命令
  // 等待执行完成
  i = 25;
  do {
    HAL_Delay(1);
    n = READER522_ReadRegister(0x04);
    i--;
  while ((i != 0) && !(n & 0x01) && !(n & waitIRq));
  if (i != 0)
    if (!(READER522_ReadRegister(0x06) & 0x1B)) // 检查错误寄存器
      status = 0;                       // 成功
      n = READER522_ReadRegister(0x0A); // FIFO Level
      lastBits = READER522_ReadRegister(0x0C) & 0x07;
      if (lastBits)
        *backBits = (n - 1) * 8 + lastBits;
        *backBits = n * 8;
      status = 1; // 失败
  return status;
uint8_t READER522_Request(uint8_t reqMode, uint8_t *backBits)
    uint8_t status;
    uint8_t data[2];
    READER522_WriteRegister(0x0D, 0x07);  // 设置 FIFO 数据宽度
    READER522_ClearBitMask(0x08, 0x08);   // 关闭自动增益
    data[0] = reqMode; // 0x26(寻卡)
    status = READER522_ToCard(0x0C, data, 1, backBits);
    return status;
发表于 2025-4-4 12:10:19 | 显示全部楼层
SPI硬件上还有就是SPI GPIO的上拉使能了,速度等级降低试试
GMT+8, 2026-11-22 14:31 , Processed in 0.473817 second(s), 24 queries .
