查看: 2615|回复: 9
[LwIP] at32f407使用freertos移植lwip运行时间久了后,ping会变的很慢,直至死机
发表于 2025-3-25 13:48:28 | 显示全部楼层 |阅读模式
也按照网上的一些代码更改过,感觉都没什么效果,软件测试结果如下,测试时应用程序屏蔽掉了,lwip移植的是2.2.1
求大佬帮忙分析一下原因和继续排查方法
代码如下,
 楼主| 发表于 2025-3-25 15:17:26 | 显示全部楼层
图片怎么被吃了,补充图片
 楼主| 发表于 2025-3-25 15:24:31 | 显示全部楼层
error_status emac_rxpkt_chainmode(void)
    error_status status = ERROR;
    /* Check if the descriptor is owned by the ETHERNET DMA (when set) or CPU (when reset) */
    if ((dma_rx_desc_to_get->status & EMAC_DMARXDESC_OWN) != (u32)RESET)
        /* return error: own bit set */
        return status;
    if (((dma_rx_desc_to_get->status & EMAC_DMARXDESC_FS) != (u32)RESET) &&
        ((dma_rx_desc_to_get->status & EMAC_DMARXDESC_LS) != (u32)RESET))
        /* 单包数据 */
        rx_frame.rx_fs_desc = dma_rx_desc_to_get;
        rx_frame.rx_ls_desc = dma_rx_desc_to_get;
        /* Get the Frame Length of the received packet: substruct 4 bytes of the CRC */
        rx_frame.length = ((dma_rx_desc_to_get->status & EMAC_DMARXDESC_FL) >> EMAC_DMARxDesc_FrameLengthShift) - 4;
        rx_frame.buffer = rx_frame.rx_fs_desc->buf1addr;
        status = SUCCESS;
    else if ((dma_rx_desc_to_get->status & EMAC_DMARXDESC_FS) != (u32)RESET)
        /* 多包数据的第一包 */
        if (NULL != rx_frame.rx_fs_desc)
            /* 已经记录了一次开始帧,丢掉上次的开始帧和后续的数据 */
            while (rx_frame.rx_fs_desc != dma_rx_desc_to_get)
                rx_frame.rx_fs_desc->status = EMAC_DMARXDESC_OWN;
                rx_frame.rx_fs_desc = (emac_dma_desc_type*)rx_frame.rx_fs_desc->buf2nextdescaddr;
    else if ((dma_rx_desc_to_get->status & EMAC_DMARXDESC_LS) != (u32)RESET)
        /* 多包数据的最后一包 */
        if (NULL == rx_frame.rx_fs_desc)
            //没有对应的开始包丢掉此包数据,不做处理。
            dma_rx_desc_to_get->status = EMAC_DMARXDESC_OWN;
            goto Nothing;
            status = SUCCESS;
    else//多包数据的中间包
        if (dma_rx_desc_to_get->buf2nextdescaddr == (uint32_t)rx_frame.rx_fs_desc)
            /* 多包数据超出了缓存 */
            /* 丢掉上次的开始帧和后续的数据 */
            rx_frame.rx_fs_desc = NULL;
            goto Nothing;
            goto Nothing;
    /* Selects the next DMA Rx descriptor list for next buffer to read */
    dma_rx_desc_to_get = (emac_dma_desc_type*)(dma_rx_desc_to_get->buf2nextdescaddr);
    return status;
Nothing:
    return status;
 楼主| 发表于 2025-3-26 14:58:36 | 显示全部楼层
半场开个香槟,自己顶自己
 楼主| 发表于 2025-3-27 08:39:18 | 显示全部楼层
测试一夜无问题。
说结论:修改时改动地方比较多
这里说我感觉最重要的两点
1.不要开溢出中断
2.eth中断优先级要能被freertos管理
发表于 2025-3-27 10:28:16 | 显示全部楼层
luanyuxinhen 发表于 2025-3-26 14:58
半场开个香槟,自己顶自己
测试百万数据包,正常后,基本就正常了。
 楼主| 发表于 2025-3-27 10:59:48 | 显示全部楼层
要谢谢你公开的这个工具,要不然我测试都要测试半天,这个工具挺好用的。
发表于 2025-4-15 23:07:11 | 显示全部楼层
luanyuxinhen 发表于 2025-3-27 08:39
测试一夜无问题。
说结论:修改时改动地方比较多
这里说我感觉最重要的两点
我也是刚测试的帖子,建议一定要开溢出中断;你这里就建议不要开,真是服了
发表于 2025-4-18 16:29:04 | 显示全部楼层
你们说的溢出中断是指哪个溢出中断?
发表于 2025-4-21 11:30:00 | 显示全部楼层
gnail092 发表于 2025-4-18 16:29
你们说的溢出中断是指哪个溢出中断?
.regs_DMA_INTEN_init = &(const struct emac_regs_DMA_INTEN){.BITS = {
        .NIE = 1,   // 正常中断
        .RIE = 1,   // 接收中断
        .FBEIE = 1, // 总线错误
        .ROIE = 1,  // 上溢错误
        .TUIE = 1,  // 下溢错误
        .AIE = 1,
GMT+8, 2026-11-25 10:35 , Processed in 0.757947 second(s), 27 queries .
