查看: 1257|回复: 1
[STM32H7] stm32h743 eth使用lwip socket通信影响spi dma数据收发
发表于 2025-3-2 19:43:15 | 显示全部楼层 |阅读模式
stm32h743使用spi dma方式与一个外部传感器进行通信一切正常,但是一旦建立socket连接有eth数据收发之后,spi dma就偶尔不正常,目前我只能想到跟cache有关,但是不知道如何进一步定位了,求大佬支援。
MPU配置部分如下:
static void MPU_Config(void)
  MPU_Region_InitTypeDef MPU_InitStruct;
  /* Disable the MPU */
  HAL_MPU_Disable();
  /* Configure the MPU as Strongly ordered for not defined regions */
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.BaseAddress = 0x00;
  MPU_InitStruct.Size = MPU_REGION_SIZE_4GB;
  MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.SubRegionDisable = 0x87;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
  HAL_MPU_ConfigRegion(&MPU_InitStruct);
  /* Configure the MPU attributes as Device not cacheable
     for ETH DMA descriptors */
  MPU_InitStruct.BaseAddress = 0x30000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_256B;
  MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER1;
  MPU_InitStruct.SubRegionDisable = 0x00;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
  /* Configure the MPU attributes as Normal Non Cacheable
     for LwIP RAM heap which contains the Tx buffers */
  MPU_InitStruct.BaseAddress = 0x30004000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
  MPU_InitStruct.Number = MPU_REGION_NUMBER2;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
     for SPI TxRx */
  MPU_InitStruct.BaseAddress = 0x38000000;
  MPU_InitStruct.Number = MPU_REGION_NUMBER3;
  /* Enable the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
  * @brief  CPU L1-Cache enable.
  * @param  None
  * @retval None
static void CPU_CACHE_Enable(void)
  /* Enable I-Cache */
  SCB_EnableICache();
  /* Enable D-Cache */
  SCB_EnableDCache();
分散加载文件如下:
LR_IROM1 0x08000000 0x00200000  {    ; load region size_region
  ER_IROM1 0x08000000 0x00200000  {  ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
  RW_IRAM2 0x24000000 0x00080000  {  ; RW data
   .ANY (+RW +ZI)
  RW_DMARxDscrTab 0x30000000 0x80 {
  *(.RxDescripSection)
  RW_DMATxDscrTab 0x30000080 0x80 {
  *(.TxDescripSection)
  memory_RX_POOL_base 0x30000100 0x3F00 {
  *(.Rx_PoolSection)
    RW_IRAM3 0x38000000 0x0001000  {  ; RW data,spi dma读写区
    *(.RAM_D3)
SPI的dma内存区域定义如下:
uint8_t __attribute__((section (".RAM_D3"))) aTxBuffer[0x80];
uint8_t __attribute__((section (".RAM_D3"))) aRxBuffer[0x80];
问题是只要一调用send(client_sockfd, respond_frame, send_frame_len, 0);这个socket发送,spi dma就偶尔不发数据
发表于 2025-3-3 04:21:13 | 显示全部楼层
测试阶段,可以直接将函数
SCB_EnableDCache();
修改为Disable测试下
SCB_DisableDCache
GMT+8, 2026-10-24 18:38 , Processed in 0.197613 second(s), 24 queries .
