查看: 1819|回复: 2
[USB] USB ULPI的读写操作实现
发表于 2025-2-21 10:24:30 | 显示全部楼层 |阅读模式
STM32CubeF7/Projects/STM32746G-Discovery/Examples/PWR/PWR_CurrentConsumption/Src/stm32f7xx_lp_modes.c at 18642033f376dead4f28f09f21b5ae75abb4020e · STMicroelectronics/STM32CubeF7
  * @file    PWR/PWR_CurrentConsumption/stm32f7xx_lp_modes.c
  * @author  MCD Application Team
  * @brief   This file provides firmware functions to manage the following
  *          functionalities of the STM32F7xx Low Power Modes:
  *           - Sleep Mode
  *           - STOP mode with RTC
  *           - STANDBY mode without RTC and BKPSRAM
  *           - STANDBY mode with RTC
  *           - STANDBY mode with RTC and BKPSRAM
  * @attention
  * Copyright (c) 2016 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup STM32F7xx_HAL_Examples
/** @addtogroup PWR_CurrentConsumption
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* ULPI PHY */
#define USBULPI_PHYCR     ((uint32_t)(0x40040000 + 0x034))
#define USBULPI_D07       ((uint32_t)0x000000FF)
#define USBULPI_New       ((uint32_t)0x02000000)
#define USBULPI_RW        ((uint32_t)0x00400000)
#define USBULPI_S_BUSY    ((uint32_t)0x04000000)
#define USBULPI_S_DONE    ((uint32_t)0x08000000)
#define Pattern_55        ((uint32_t)0x00000055)
#define Pattern_AA        ((uint32_t)0x000000AA)
#define PHY_PWR_DOWN       (1<<11)
#define PHY_ADDRESS        0x00 /* default ADDR for PHY: LAN8742 */
#define USB_OTG_READ_REG32(reg)  (*(__IO uint32_t *)(reg))
#define USB_OTG_WRITE_REG32(reg,value) (*(__IO uint32_t *)(reg) = (value))
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* RTC handler declaration */
RTC_HandleTypeDef RTCHandle;
/* Private function prototypes -----------------------------------------------*/
static void SYSCLKConfig_STOP(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  This function configures the system to enter Sleep mode for
  *         current consumption measurement purpose.
  *         Sleep Mode
  *            - System Running at PLL (216MHz)
  *            - Flash 5 wait state
  *            - Instruction and Data caches ON
  *            - Prefetch ON
  *            - Code running from Internal FLASH
  *            - All peripherals disabled.
  *            - Wakeup using EXTI Line (USER Button)
  * @param  None
  * @retval None
void SleepMode_Measure(void)
  GPIO_InitTypeDef GPIO_InitStruct;
  /* Disable USB Clock */
  __HAL_RCC_USB_OTG_HS_CLK_DISABLE();
  __HAL_RCC_USB_OTG_HS_ULPI_CLK_DISABLE();
  /* Disable Ethernet Clock */
  __HAL_RCC_ETH_CLK_DISABLE();
  /* Configure all GPIO as analog to reduce current consumption on non used IOs */
  /* Enable GPIOs clock */
   __HAL_RCC_GPIOA_CLK_ENABLE();
   __HAL_RCC_GPIOB_CLK_ENABLE();
   __HAL_RCC_GPIOC_CLK_ENABLE();
   __HAL_RCC_GPIOD_CLK_ENABLE();
   __HAL_RCC_GPIOE_CLK_ENABLE();
   __HAL_RCC_GPIOF_CLK_ENABLE();
   __HAL_RCC_GPIOG_CLK_ENABLE();
   __HAL_RCC_GPIOH_CLK_ENABLE();
   __HAL_RCC_GPIOI_CLK_ENABLE();
   __HAL_RCC_GPIOJ_CLK_ENABLE();
   __HAL_RCC_GPIOK_CLK_ENABLE();
  GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
  GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Pin = GPIO_PIN_All;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOH, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOI, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOJ, &GPIO_InitStruct);
  HAL_GPIO_Init(GPIOK, &GPIO_InitStruct);
  /* Disable GPIOs clock */
   __HAL_RCC_GPIOA_CLK_DISABLE();
   __HAL_RCC_GPIOB_CLK_DISABLE();
   __HAL_RCC_GPIOC_CLK_DISABLE();
   __HAL_RCC_GPIOD_CLK_DISABLE();
   __HAL_RCC_GPIOE_CLK_DISABLE();
   __HAL_RCC_GPIOF_CLK_DISABLE();
   __HAL_RCC_GPIOG_CLK_DISABLE();
   __HAL_RCC_GPIOH_CLK_DISABLE();
   __HAL_RCC_GPIOI_CLK_DISABLE();
   __HAL_RCC_GPIOJ_CLK_DISABLE();
   __HAL_RCC_GPIOK_CLK_DISABLE();
  /* Configure USER Button */
  BSP_PB_Init(BUTTON_KEY, BUTTON_MODE_EXTI);
  /* Suspend Tick increment to prevent wakeup by Systick interrupt.
     Otherwise the Systick interrupt will wake up the device within 1ms (HAL time base) */
  HAL_SuspendTick();
  /* Request to enter SLEEP mode */
  HAL_PWR_EnterSLEEPMode(PWR_MAINREGULATOR_ON, PWR_SLEEPENTRY_WFI);
  /* Resume Tick interrupt if disabled prior to sleep mode entry */
  HAL_ResumeTick();
  /* Exit USB Phy from LowPower mode */
  USB_PhyExitFromLowPowerMode();
  /* Exit Ethernet Phy from LowPower mode */
  ETH_PhyExitFromPowerDownMode();
  * @brief  This function configures the system to enter Stop mode with RTC
  *         clocked by LSE or LSI  for current consumption measurement purpose.
  *         STOP Mode with RTC clocked by LSE/LSI
  *           - RTC Clocked by LSE or LSI
  *           - Regulator in LP mode
  *           - HSI, HSE OFF and LSI OFF if not used as RTC Clock source
  *           - No IWDG
  *           - FLASH in deep power down mode
  *           - Automatic Wakeup using RTC clocked by LSE/LSI (~20s)
  * @param  None
  * @retval None
void StopMode_Measure(void)
  RTCHandle.Instance = RTC;
  /* Configure RTC prescaler and RTC data registers as follow:
  - Hour Format = Format 24
  - Asynch Prediv = Value according to source clock
  - Synch Prediv = Value according to source clock
  - OutPut = Output Disable
  - OutPutPolarity = High Polarity
  - OutPutType = Open Drain */
  RTCHandle.Init.HourFormat = RTC_HOURFORMAT_24;
  RTCHandle.Init.AsynchPrediv = RTC_ASYNCH_PREDIV;
  RTCHandle.Init.SynchPrediv = RTC_SYNCH_PREDIV;
  RTCHandle.Init.OutPut = RTC_OUTPUT_DISABLE;
  RTCHandle.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  RTCHandle.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  if(HAL_RTC_Init(&RTCHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
  /*## Configure the Wake up timer ###########################################*/
  /*  RTC Wakeup Interrupt Generation:
      Wakeup Time Base = (RTC_WAKEUPCLOCK_RTCCLK_DIV /(LSI))
      Wakeup Time = Wakeup Time Base * WakeUpCounter
                  = (RTC_WAKEUPCLOCK_RTCCLK_DIV /(LSI)) * WakeUpCounter
      ==> WakeUpCounter = Wakeup Time / Wakeup Time Base
      To configure the wake up timer to 20s the WakeUpCounter is set to 0xA017:
        RTC_WAKEUPCLOCK_RTCCLK_DIV = RTCCLK_Div16 = 16
        Wakeup Time Base = 16 /(~32.768KHz) = ~0,488 ms
        Wakeup Time = ~20s = 0,488ms  * WakeUpCounter
        ==> WakeUpCounter = ~20s/0,488ms = 40983 = 0xA017 */
  HAL_RTCEx_SetWakeUpTimer_IT(&RTCHandle, 0xA017, RTC_WAKEUPCLOCK_RTCCLK_DIV16);
  /* FLASH Deep Power Down Mode enabled */
  HAL_PWREx_EnableFlashPowerDown();
  /* Enter Stop Mode */
  HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
  /* Configures system clock after wake-up from STOP: enable HSE, PLL and select
  PLL as system clock source (HSE and PLL are disabled in STOP mode) */
  SYSCLKConfig_STOP();
  /* Exit USB Phy from low power mode */
  /* Exit Ethernet Phy from low power mode */
  /* Disable Wake-up timer */
  if(HAL_RTCEx_DeactivateWakeUpTimer(&RTCHandle) != HAL_OK)
    Error_Handler();
  * @brief  This function configures the system to enter Standby mode for
  *         STANDBY Mode
  *           - Backup SRAM and RTC OFF
  *           - IWDG and LSI OFF
  *           - Wakeup using WakeUp Pin (PI.11)
  * @param  None
  * @retval None
void StandbyMode_Measure(void)
  /* Disable all used wakeup sources: Pin6(PI.11) */
  HAL_PWR_DisableWakeUpPin(PWR_WAKEUP_PIN6);
  /* Clear the related wakeup pin flag */
  __HAL_PWR_CLEAR_WAKEUP_FLAG(PWR_WAKEUP_PIN_FLAG6);
  /* Re-enable all used wakeup sources: Pin6(PI.11) */
  HAL_PWR_EnableWakeUpPin(PWR_WAKEUP_PIN6);
  /* Request to enter STANDBY mode  */
  HAL_PWR_EnterSTANDBYMode();
  * @brief  This function configures the system to enter Standby mode with RTC
  *         STANDBY Mode with RTC clocked by LSE/LSI
  *           - RTC Clocked by LSE/LSI
  *           - IWDG OFF
  *           - Backup SRAM OFF
  *           - Automatic Wakeup using RTC clocked by LSE/LSI (after ~20s)
  * @param  None
  * @retval None
void StandbyRTCMode_Measure(void)
    Error_Handler();
    Error_Handler();
  /*## Clear all related wakeup flags ########################################*/
  /* Clear RTC Wake Up timer Flag */
  __HAL_RTC_WAKEUPTIMER_CLEAR_FLAG(&RTCHandle, RTC_FLAG_WUTF);
  /*## Setting the Wake up time ##############################################*/
  /*## Enter the Standby mode ################################################*/
  *         backup SRAM ON for current consumption measurement purpose.
  *         STANDBY Mode
  *           - RTC OFF
  *           - Backup SRAM ON
  * @param  None
  * @retval None
void StandbyBKPSRAMMode_Measure(void)
  /* Clear all related wakeup flags */
  /* Enable BKPRAM Clock */
  __HAL_RCC_BKPSRAM_CLK_ENABLE();
  /* Enable the Backup SRAM low power Regulator */
  HAL_PWREx_EnableBkUpReg();
  * @brief  Configures system clock after wake-up from STOP: enable HSE, PLL
  *         and select PLL as system clock source.
  * @param  None
  * @retval None
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_OscInitTypeDef RCC_OscInitStruct;
  uint32_t pFLatency = 0;
  /* Get the Oscillators configuration according to the internal RCC registers */
  HAL_RCC_GetOscConfig(&RCC_OscInitStruct);
  /* After wake-up from STOP reconfigure the system clock: Enable HSE and PLL */
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /* Get the Clocks configuration according to the internal RCC registers */
  HAL_RCC_GetClockConfig(&RCC_ClkInitStruct, &pFLatency);
  /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
     clocks dividers */
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_SYSCLK;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, pFLatency) != HAL_OK)
    Error_Handler();
  * @brief  Read CR value
  * @param  Addr the Address of the ULPI Register
  * @retval Returns value of PHY CR register
uint32_t USB_ULPI_Read(uint32_t Addr)
   __IO uint32_t val = 0;
   __IO uint32_t timeout = 100; /* Can be tuned based on the Clock or etc... */
   USB_OTG_WRITE_REG32(USBULPI_PHYCR, USBULPI_New | (Addr << 16));
   val = USB_OTG_READ_REG32(USBULPI_PHYCR);
   while (((val & USBULPI_S_DONE) == 0) && (timeout--))
   return  (val & 0x000000ff);
  * @brief  Write CR value
  * @param  Data Data to write
uint32_t USB_ULPI_Write(uint32_t Addr, uint32_t Data)   /* Parameter is the Address of the ULPI Register & Date to write */
  __IO uint32_t val;
  __IO uint32_t timeout = 10;   /* Can be tuned based on the Clock or etc... */
  USB_OTG_WRITE_REG32(USBULPI_PHYCR, USBULPI_New | USBULPI_RW | (Addr << 16) | (Data & 0x000000ff));
  return 0;
  * @brief  Configures GPIO for USB ULPI
  * @param  None
  * @retval 0
void USB_ULPI_MspInit(void)
    /* Common for all IOs */
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Alternate = GPIO_AF10_OTG_HS;
    /* D0 PA3*/
    GPIO_InitStruct.Pin = GPIO_PIN_3;
    /* CLK PA5*/
    GPIO_InitStruct.Pin = GPIO_PIN_5;
    /* D1 D2 D3 D4 D5 D6 D7 :PB0/1/5/10/11/12/13 */
    GPIO_InitStruct.Pin = GPIO_PIN_0  | GPIO_PIN_1  | GPIO_PIN_5 |\
                          GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12 |\
                          GPIO_PIN_13;
    /* NXT  PH4*/
    GPIO_InitStruct.Pin = GPIO_PIN_4;
    /* STP PC0*/
    GPIO_InitStruct.Pin = GPIO_PIN_0;
    /* DIR PC2 */
    GPIO_InitStruct.Pin = GPIO_PIN_2;
  __HAL_RCC_USB_OTG_HS_CLK_ENABLE();
  __HAL_RCC_USB_OTG_HS_ULPI_CLK_ENABLE();
  * @brief  This function configures the USB PHY to enter the low power mode
  * @param  None
  * @retval None
void USB_PhyEnterLowPowerMode(void)
  static __IO uint32_t regval = 0;
  /* USB ULPI MspInit */
  USB_ULPI_MspInit();
  /* disable ULPI_CLK by accessing ULPI_PHY */
  /* read Vendor ID : (Low, High) 0x24,0x04 for USB3300 */
  regval = USB_ULPI_Read(0x00);
  if(regval != 0x24)
    while(regval != 0x24)
      USB_ULPI_MspInit();
  regval = USB_ULPI_Read(0x01);
  if(regval != 0x04)
    Error_Handler();
  /* read Product ID */
  regval = USB_ULPI_Read(0x02);
  if(regval != 0x07)
    Error_Handler();
  regval = USB_ULPI_Read(0x03);
  if(regval != 0x00)
    Error_Handler();
  /* Write to scratch Register  the Pattern_55 */
  USB_ULPI_Write(0x16, 0x55);
  /* Read to scratch Register  and check-it again the written Pattern */
  regval = USB_ULPI_Read(0x16);
  if(regval != 0x55)
    Error_Handler();
  /* Write to scratch Register  the Pattern_AA */
  USB_ULPI_Write(0x16, 0xAA);
  if(regval != 0xAA)
    Error_Handler();
  /* read InterfaceControl reg */
  regval = USB_ULPI_Read(0x07);
  /* write InterfaceControl reg,to disable PullUp on stp,
  to avoid USB_PHY wake up when MCU entering standby */
  USB_ULPI_Write(0x07, regval | 0x80) ;
  if(regval != 0x80)
    Error_Handler();
  /* read FunctionControl reg */
  regval = USB_ULPI_Read(0x04);
  if(regval != 0x49)
    Error_Handler();
  /* write FunctionControl reg,to put PHY into LowPower mode */
  USB_ULPI_Write(0x04, regval & (~0x40));
  /* read FunctionControl reg again */
  if(regval != 0x00)
    Error_Handler();
  * @brief  This function wakeup the USB PHY from the Low power mode
  * @param  None
  * @retval None
void USB_PhyExitFromLowPowerMode(void)
  /* Enable GPIO clock for OTG USB STP pin (optional, clock should already be enabled at this phase) */
  /* Set OTG STP pin as GP Output  */
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  /* Set OTG STP pin to High state during 4 milliseconds */
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, GPIO_PIN_SET);
  /* Delay 4 ms */
  HAL_Delay(4);
  * @brief  This function configures the ETH PHY to enter the power down mode
  *         This function should be called before entering the low power mode.
  * @param  None
  * @retval None
void ETH_PhyEnterPowerDownMode(void)
  ETH_HandleTypeDef heth;
  uint32_t phyregval = 0;
  /* This part of code is used only when the ETH peripheral is disabled
	   when the ETH is used in the application this initialization code
	   is called in HAL_ETH_MspInit() function  ***********************/
	/* Enable GPIO clocks*/
  /* Configure PA2: ETH_MDIO */
  GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
  GPIO_InitStruct.Pin = GPIO_PIN_1 | GPIO_PIN_2;
  /* Configure PC1: ETH_MDC */
  GPIO_InitStruct.Pin = GPIO_PIN_1;
  /* Enable the ETH peripheral clocks */
  __HAL_RCC_ETH_CLK_ENABLE();
  /* Set ETH Handle parameters */
  heth.Instance = ETH;
  heth.Init.PhyAddress = LAN8742A_PHY_ADDRESS;
  /* Configure MDC clock: the MDC Clock Range configuration
     depend on the system clock: 216Mhz/102 = 2.1MHz  */
  /* MDC: a periodic clock that provides the timing reference for
     the MDIO data transfer at the maximum frequency of 2.5 MHz.*/
  heth.Instance->MACMIIAR = (uint32_t)ETH_MACMIIAR_CR_Div102;
  /* ETH PHY configuration in Power Down mode **********************/
  /* Read ETH PHY control register */
  HAL_ETH_ReadPHYRegister(&heth, PHY_BCR, &phyregval);
  /* Set Power down mode bit */
  phyregval |= PHY_POWERDOWN;
  /* Write new value to ETH PHY control register */
  HAL_ETH_WritePHYRegister(&heth, PHY_BCR, phyregval);
  /* Disable periph CLKs */
  * @brief  This function wakeup the ETH PHY from the power down mode
  *         When exiting from StandBy mode and the ETH is used in the example
  *         its better to call this function at the end of HAL_ETH_MspInit()
  *         then remove the code that initialize the ETH CLKs ang GPIOs.
  * @param  None
  * @retval None
void ETH_PhyExitFromPowerDownMode(void)
  /* ETH CLKs and GPIOs initialization ******************************/
  /* To be removed when the function is called from HAL_ETH_MspInit() when
     exiting from Standby mode */
  /* Configure PA2 */
  /* Configure PC1*/
  /* Enable ETH CLK */
  /* ETH PHY configuration to exit Power Down mode *****************/
  /* check if the PHY  is already in power down mode */
  if ((phyregval & PHY_POWERDOWN) != RESET)
    /* Disable Power down mode */
    phyregval &= ~ PHY_POWERDOWN;
    /* Write value to ETH PHY control register */
参与人数 1金币 +1 收起 理由
OldGerman + 1 很给力!
发表于 2025-2-21 13:49:04 | 显示全部楼层
看代码是STM32F7系列的,不知道在STM32H7系列是否适用。
 楼主| 发表于 2025-2-22 08:06:01 | 显示全部楼层
还没测,备份了下代码。
GMT+8, 2026-10-24 17:53 , Processed in 0.208804 second(s), 25 queries .
