查看: 1926|回复: 4
[算法] 开源加密库Mbed,Cyclone,Wolf和NetX性能
发表于 2024-12-31 07:49:52 | 显示全部楼层 |阅读模式
NetX有两个:
NetX Crypto
NetX Secure(TLS)
Mbed有两个:
MbedTLS
MbedCrypto
Cyclone有两个:
Cyclone Crypto
Cyclone SSL
Wolf有两个:
wolfSSL
wolfCrypt
在MDK RTE里面都有集成
MbedTLS
搜到一个2017年的测试
https://os.mbed.com/teams/mbed-o ... 60cd5226d/main.cpp/
  SHA-256                  :       1673 Kb/s,         70 cycles/byte
  SHA-512                  :        546 Kb/s,        215 cycles/byte
  AES-CBC-128              :       1428 Kb/s,         82 cycles/byte
  AES-CBC-192              :       1260 Kb/s,         93 cycles/byte
  AES-CBC-256              :       1127 Kb/s,        104 cycles/byte
  AES-GCM-128              :        486 Kb/s,        242 cycles/byte
  AES-GCM-192              :        464 Kb/s,        253 cycles/byte
  AES-GCM-256              :        445 Kb/s,        264 cycles/byte
  AES-CCM-128              :        610 Kb/s,        192 cycles/byte
  AES-CCM-192              :        547 Kb/s,        214 cycles/byte
  AES-CCM-256              :        496 Kb/s,        237 cycles/byte
  CTR_DRBG (NOPR)          :       1139 Kb/s,        102 cycles/byte
  CTR_DRBG (PR)            :        826 Kb/s,        142 cycles/byte
  HMAC_DRBG SHA-256 (NOPR) :        193 Kb/s,        611 cycles/byte
  HMAC_DRBG SHA-256 (PR)   :        170 Kb/s,        695 cycles/byte
  RSA-2048                 :      28 ms/ public
  RSA-2048                 :     953 ms/private
  RSA-4096                 :      93 ms/ public
  RSA-4096                 :    5327 ms/private
  ECDSA-secp384r1          :     451 ms/sign
  ECDSA-secp256r1          :     304 ms/sign
  ECDSA-secp384r1          :     863 ms/verify
  ECDSA-secp256r1          :     594 ms/verify
  ECDHE-secp384r1          :     829 ms/handshake
  ECDHE-secp256r1          :     566 ms/handshake
  ECDHE-Curve25519         :     533 ms/handshake
  ECDH-secp384r1           :     407 ms/handshake
  ECDH-secp256r1           :     281 ms/handshake
  ECDH-Curve25519          :     268 ms/handshake
wolfssl
https://github.com/wolfSSL/wolfs ... arks.md#stm32h753zi
Supports RNG, AES CBC/GCM and SHA-2 acceleration. Note: HW RNG on for all tests
Board: NUCLEO-H753ZI CPU: Cortex-M7 at 480 MHz IDE: STM32CubeIDE RTOS: FreeRTOS
STM32H753ZI (STM Crypto/Hash Acceleration, -Os, SP-ASM Cortex-M)
wolfSSL version 4.4.1
wolfCrypt Benchmark (block bytes 1024, min 1.0 sec each)
RNG                875 KB took 1.019 seconds,  858.685 KB/s
AES-128-CBC-enc     10 MB took 1.000 seconds,   10.400 MB/s
AES-128-CBC-dec     10 MB took 1.000 seconds,   10.327 MB/s
AES-192-CBC-enc     10 MB took 1.000 seconds,   10.425 MB/s
AES-192-CBC-dec     10 MB took 1.000 seconds,   10.278 MB/s
AES-256-CBC-enc     10 MB took 1.000 seconds,   10.376 MB/s
AES-256-CBC-dec     10 MB took 1.000 seconds,   10.278 MB/s
AES-128-GCM-enc      9 MB took 1.000 seconds,    8.789 MB/s
AES-128-GCM-dec      9 MB took 1.000 seconds,    8.716 MB/s
AES-192-GCM-enc      9 MB took 1.000 seconds,    8.740 MB/s
AES-192-GCM-dec      9 MB took 1.000 seconds,    8.691 MB/s
AES-256-GCM-enc      9 MB took 1.000 seconds,    8.765 MB/s
AES-256-GCM-dec      9 MB took 1.000 seconds,    8.691 MB/s
CHACHA               4 MB took 1.000 seconds,    4.443 MB/s
CHA-POLY             3 MB took 1.004 seconds,    3.040 MB/s
POLY1305            13 MB took 1.000 seconds,   12.671 MB/s
SHA-256              9 MB took 1.000 seconds,    8.691 MB/s
HMAC-SHA256          8 MB took 1.000 seconds,    8.496 MB/s
RSA     2048 public         82 ops took 1.019 sec, avg 12.427 ms, 80.471 ops/sec
RSA     2048 private         4 ops took 1.749 sec, avg 437.250 ms, 2.287 ops/sec
DH      2048 key gen         5 ops took 1.000 sec, avg 200.000 ms, 5.000 ops/sec
DH      2048 agree           6 ops took 1.200 sec, avg 200.000 ms, 5.000 ops/sec
ECC      256 key gen       121 ops took 1.000 sec, avg 8.264 ms, 121.000 ops/sec
ECDHE    256 agree          56 ops took 1.016 sec, avg 18.143 ms, 55.118 ops/sec
ECDSA    256 sign           78 ops took 1.007 sec, avg 12.910 ms, 77.458 ops/sec
ECDSA    256 verify         36 ops took 1.004 sec, avg 27.889 ms, 35.857 ops/sec
Benchmark complete
Benchmark Test: Return code 0
Cyclone
部分截图
https://www.oryx-embedded.com/benchmark/st/crypto-stm32h7.html
 楼主| 发表于 2024-12-31 07:50:27 | 显示全部楼层
NetXDUO的性能没找到,以后再补上
发表于 2024-12-31 13:17:04 | 显示全部楼层
这个不错,收藏了。我记得st自己好像也写了一个加密库。
发表于 2025-1-2 10:41:18 | 显示全部楼层
都是免费使用的吗,还是个人免费,公司商用收费
 楼主| 发表于 2025-1-3 06:41:15 | 显示全部楼层
ThreadX NetX和Mbedtls是免费的。
另外两个商用不是。
GMT+8, 2026-10-24 20:44 , Processed in 0.151831 second(s), 27 queries .
