查看: 1845|回复: 5
[Flash] 【求助】STM32H743使用指针按4字节访问FLASH时,由PRECISERR引起hardfault
回帖奖励 4 个金币 回复本帖可获得 1 个金币奖励! 每人限 1 次
发表于 2024-12-12 15:53:44 | 显示全部楼层 |阅读模式
我在使用STM32H743运行openBLT程序boot部分时,在下载的检测阶段执行了FLASH读取函数,目的是检查FLASH是否为空。
在读取扇区0x08020000到0x0803FFFF的过程中,程序进入hardfault。
以下贴出flash检查程序:
static blt_bool FlashEmptyCheckSector(blt_int8u sector_idx)
  blt_bool   result = BLT_TRUE;
  blt_addr   sectorAddr;
  blt_int32u sectorSize;
  blt_int32u wordCnt;
  blt_int32u volatile const * wordPtr;
  /* retrieve sector info */
  sectorAddr = flashLayout[sector_idx].sector_start;
  sectorSize = flashLayout[sector_idx].sector_size;
  /* sanity check. sector base address should be 32-bit aligned and the size
   * should be a multiple of 32-bits.
  ASSERT_RT(((sectorAddr % sizeof(blt_int32u)) == 0) &&
            ((sectorSize % sizeof(blt_int32u)) == 0));
  /* initialize the pointer to the first word in the sector */
  wordPtr = (blt_int32u volatile const *)sectorAddr;
  /* read sector 32-bits at a time */
  for (wordCnt = 0; wordCnt < (sectorSize/sizeof(blt_int32u)); wordCnt++)
    /* service the watchdog every 256th loop iteration */
    if ((wordCnt % 256) == 0)
      CopService();
    /* word not in the erased state? */
    if (*wordPtr != 0xFFFFFFFFu)
      /* sector not empty, update the result accordingly */
      result = BLT_FALSE;
      /* no point in continuing the sector empty check */
    /* set pointer to the next word in the sector */
    wordPtr++;
  /* give the result back to the caller. */
  return result;
} /*** end of FlashEmptyCheckSector ***/
DEBUG查看Fault Report有:
想求助该问题引发的原因。
本工程由cubeMX生成,时钟为480MHz,MPU等为默认配置。外部时钟25MHz,仅使用了USART1,GPIO外设。
发表于 2024-12-13 00:25:08 | 显示全部楼层
回帖奖励 +1 个金币
不使用这个组件,单纯读取地址0x08020000到0x0803FFFF释放还会异常
 楼主| 发表于 2024-12-13 09:42:19 | 显示全部楼层
是的,我新建了一个cubemx工程,并只运行使用指针read flash的操作。附上main.c和H743II的cubeMX工程文件,您如果有时间,方便的话,帮我也试一试。
void read_flash_test()
  uint32_t sectorAddr;
  uint32_t sectorSize;
  uint32_t wordCnt;
  uint32_t volatile const * wordPtr;
  uint32_t readWord;
  sectorAddr = 0x8020000;
  sectorSize = 0x20000;
  wordPtr = (uint32_t volatile const *)sectorAddr;
  for (wordCnt = 0; wordCnt < (sectorSize/sizeof(uint32_t)); wordCnt++)
    readWord = *wordPtr;
    if (readWord != 0xFFFFFFFFu)
    wordPtr++;
int main(){
/* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    read_flash_test();
      HAL_Delay(1000);
    /* USER CODE BEGIN 3 */
FLASH_READ_TEST.zip
4.32 KB, 下载次数: 0
 楼主| 发表于 2024-12-13 09:58:38 | 显示全部楼层
我还发现一个现象就是,对bank2(即0x8100000)做相同的读操作不会引起PRECISERR上访hardfault。对bank2的读操作size为0x0100000,每次4byte,即全页读取。
 楼主| 发表于 2024-12-13 10:15:23 | 显示全部楼层
[已解决]原因未知,我做了一次正片擦除之后,再对0x08020000等各flash地址的读操作,都没有再出现PRECISERR错误了。
发表于 2024-12-14 01:35:17 | 显示全部楼层
CAizg294 发表于 2024-12-13 10:15
[已解决]原因未知,我做了一次正片擦除之后,再对0x08020000等各flash地址的读操作,都没有再出现PRECISE ...
这个确实诡异,谢谢告知最终原因
GMT+8, 2026-11-16 08:45 , Processed in 0.294614 second(s), 32 queries .
