查看: 1875|回复: 2
[FileX] fx_file_delete返回成功,但文件实际没删除是什么原因?
发表于 2024-11-28 18:32:38 | 显示全部楼层 |阅读模式
如题。
 楼主| 发表于 2024-11-28 22:34:07 | 显示全部楼层
如此这般就可以了,前几天在另外的工程中还设置过,立即执行就行了。
/* Defined, data sector write requests are flushed immediately to the driver.  */
#define FX_FAULT_TOLERANT
/* Define byte offset in boot sector where the cluster number of the Fault Tolerant Log file is.
   Note that this field (byte 116 to 119) is marked as reserved by FAT 12/16/32/exFAT specification. */
/* #define FX_FAULT_TOLERANT_BOOT_INDEX         116 */
#define FX_FAULT_TOLERANT_DATA
发表于 2024-11-29 08:48:51 | 显示全部楼层
谢谢告知原因。
GMT+8, 2026-10-24 20:16 , Processed in 0.545661 second(s), 24 queries .
