查看: 2555|回复: 3
开源USB Type-C口袋电源,支持3.3 -20 V,最大5 A
发表于 2024-11-25 07:59:03 | 显示全部楼层 |阅读模式
https://github.com/CentyLab/PocketPD
https://www.crowdsupply.com/centylab/pocketpd
电压和电流可调,电压支持3.3V-20V,单步50mV可调。电流1A-5A可调,单步50mA可调。
规格
发表于 2024-12-26 22:55:36 | 显示全部楼层
硬汉 请问这个是不是不提供硬件原理图,只开源了软件程序?没找到硬件的相关资料
 楼主| 发表于 2024-12-27 07:39:46 | 显示全部楼层
后面开源,网站说明
The electronic is developed using KiCad 8.x and will be provided at a later date under a CC4.0-BY-SA license. The hardware files will be made available at a later date.
发表于 2024-12-27 15:28:21 | 显示全部楼层
eric2013 发表于 2024-12-27 07:39
后面开源,网站说明
The electronic is developed using KiCad 8.x and will be provided at a later da ...
OK 看到了
GMT+8, 2026-10-26 01:44 , Processed in 0.125991 second(s), 24 queries .
