查看: 1710|回复: 3
[STM32H7] STM32H743采用flash swap 进行IAP升级,reset后启动不了
发表于 2024-11-19 11:49:17 | 显示全部楼层 |阅读模式
试了一下将主程序放在第一个flash中,采用U盘将程序(bin文件添加了crc,用U盘读出来的时候,进行了校验)读取进外部SRAM(0x60000000)中,再将程序写入FLASH2中,再进行FLASH SWAP,然后看门狗重启,结果升级后,程序无法启动,同时也无法进行仿真了,flash下载不了,到擦除的时候就出错了(timeout),跪求大佬能给分析一下!
flash的过程如下:
//获取程序内存缓存地址
Uint32 GetProgramCacheAddr(void)
        return((Uint32)SampleCur);                                                //返回数据存储的首地址0x60000000
HAL_StatusTypeDef Flash_Swap(void)
    FLASH_OBProgramInitTypeDef OBInit;
    HAL_StatusTypeDef status;
    // 解锁 Flash
    HAL_FLASH_Unlock();
    HAL_FLASH_OB_Unlock();
    // 获取当前活动 Bank
    uint32_t current_bank = (FLASH->OPTSR_CUR & FLASH_OPTSR_SWAP_BANK_OPT) >> FLASH_OPTSR_SWAP_BANK_OPT_Pos;
    // 配置选项字节
    OBInit.OptionType = OPTIONBYTE_USER;
                OBInit.USERType = OB_USER_SWAP_BANK;
    OBInit.USERConfig = (current_bank == 1) ? OB_SWAP_BANK_DISABLE : OB_SWAP_BANK_ENABLE;
    // 编程选项字节
    status = HAL_FLASHEx_OBProgram(&OBInit);
    if(status == HAL_OK) {
        // 启动选项字节加载
        status = HAL_FLASH_OB_Launch();
    // 锁定 Flash
    HAL_FLASH_OB_Lock();
    HAL_FLASH_Lock();
    return status;
Uint8 UpdateProgram(void)
    uint32_t inactive_bank;
                Uint32 size;
                Uint32 *pldata;
    // 确定非活动 Bank
    inactive_bank = (FLASH->OPTSR_CUR & FLASH_OPTSR_SWAP_BANK_OPT) ? FLASH_BANK1_BASE : FLASH_BANK2_BASE;
    // 擦除非活动 Bank
    FLASH_EraseInitTypeDef EraseInit;
    EraseInit.TypeErase = FLASH_TYPEERASE_SECTORS;
    EraseInit.Banks = (inactive_bank == FLASH_BANK1_BASE) ? FLASH_BANK_1 : FLASH_BANK_2;
    EraseInit.Sector = 0;  // 从0扇区开始
    EraseInit.NbSectors = 3;  // 擦除 Bank
    uint32_t SectorError;
    status = HAL_FLASHEx_Erase(&EraseInit, &SectorError);
    if(status != HAL_OK)
                        SysData.Sys_RunFlag.bit.Needupgradef = 0;
                        return status;
                size = USBData.ReadFileLenth+32;
                pldata = (Uint32*)GetProgramCacheAddr();
                 HAL_FLASH_Unlock();
    // 写入新固件
    for(uint32_t i = 0; i < size; i += 32) {
        status = HAL_FLASH_Program(FLASH_TYPEPROGRAM_FLASHWORD,
                                 inactive_bank + i,(Uint32)&pldata);
                                        RS485_char_to_reg(20,ProgUpDate_Text3,"升级失败,正在重启");        //程序更新提示
                                        return status;
                                IWDG_Feed();
     HAL_FLASH_Lock();
   // 执行 Bank 交换
  if(Flash_Swap()==HAL_OK)
                while(1);                                //等待看门狗重启
                __enable_irq();
                return HAL_ERROR;
发表于 2024-11-20 09:31:54 | 显示全部楼层
楼主有没有单纯的测试过,两个BANK分别存储一个程序,仅仅是swap测试正常不
 楼主| 发表于 2024-12-2 19:22:01 | 显示全部楼层
问题已解决,谢谢,之前理解有错误,程序出错了!
GMT+8, 2026-10-24 20:43 , Processed in 0.189233 second(s), 24 queries .
