查看: 3478|回复: 11
[DMA] spi+dma+w5500传输问题
发表于 2024-10-8 15:27:18 | 显示全部楼层 |阅读模式
使用stm32f7+w5500实现网络通信,想使用spi+dma的模式来进行数据发送
以下是关于dma的部分代码
                 /*##-3- Configure the DMA streams ##########################################*/
                 /* Configure the DMA handler for Transmission process */
                 SPI1_HDMA_TX.Instance = DMA2_Stream5;          //SPI1_TX采用DMA2数据流5 通道3
                 SPI1_HDMA_TX.Init.Channel = DMA_CHANNEL_3;
                 SPI1_HDMA_TX.Init.Direction = DMA_MEMORY_TO_PERIPH;
                 SPI1_HDMA_TX.Init.PeriphInc = DMA_PINC_DISABLE;
                 SPI1_HDMA_TX.Init.MemInc = DMA_MINC_ENABLE;
                 SPI1_HDMA_TX.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
                 SPI1_HDMA_TX.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
                 SPI1_HDMA_TX.Init.Mode = DMA_NORMAL;
                 SPI1_HDMA_TX.Init.Priority = DMA_PRIORITY_HIGH;
                 SPI1_HDMA_TX.Init.FIFOMode = DMA_FIFOMODE_ENABLE;
                 SPI1_HDMA_TX.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
                 SPI1_HDMA_TX.Init.MemBurst = DMA_MBURST_SINGLE;
                 SPI1_HDMA_TX.Init.PeriphBurst = DMA_MBURST_SINGLE;
//                 SPI1_HDMA_TX.XferCpltCallback = W5500_TxCpltCallback_dma;
                 HAL_DMA_Init(&SPI1_HDMA_TX);
                 /* Associate the initialized DMA handle to the the SPI handle */
                 __HAL_LINKDMA(hspi, hdmatx, SPI1_HDMA_TX);
                 SPI1_HDMA_RX.Instance = DMA2_Stream0;           //SPI1_RX采用DMA2数据流0 通道3
                 SPI1_HDMA_RX.Init.Channel = DMA_CHANNEL_3;
                 SPI1_HDMA_RX.Init.Direction = DMA_PERIPH_TO_MEMORY;
                 SPI1_HDMA_RX.Init.PeriphInc = DMA_PINC_DISABLE;
                 SPI1_HDMA_RX.Init.MemInc = DMA_MINC_ENABLE;
                 SPI1_HDMA_RX.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
                 SPI1_HDMA_RX.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
                 SPI1_HDMA_RX.Init.Mode = DMA_NORMAL;
                 SPI1_HDMA_RX.Init.Priority = DMA_PRIORITY_HIGH;
                 SPI1_HDMA_RX.Init.FIFOMode = DMA_FIFOMODE_ENABLE;
                 SPI1_HDMA_RX.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
                 SPI1_HDMA_RX.Init.MemBurst = DMA_MBURST_SINGLE;
                 SPI1_HDMA_RX.Init.PeriphBurst = DMA_MBURST_SINGLE;
                 HAL_DMA_Init(&SPI1_HDMA_RX);
                 __HAL_LINKDMA(hspi, hdmarx, SPI1_HDMA_RX);
                 /*##-4- Configure the NVIC for DMA #########################################*/
                 /* NVIC configuration for DMA transfer complete interrupt (SPI3_TX) */
                 HAL_NVIC_SetPriority(DMA2_Stream5_IRQn, 8, 0);
                 HAL_NVIC_EnableIRQ(DMA2_Stream5_IRQn);
                /* NVIC configuration for DMA transfer complete interrupt (SPI3_RX) */
                 HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 8, 0);
                 HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
//SPI发送回调函数
void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi)
            if  (hspi->Instance == SPI1)
                W5500_TxCpltCallback();
//SPI接收回调函数
void HAL_SPI_RxCpltCallback(SPI_HandleTypeDef *hspi)
             W5500_RxCpltCallback();
void W5500_TxCpltCallback_dma(DMA_HandleTypeDef *hdma)
         osThreadFlagsSet(tid_app_osInterface, 0x04);
void W5500_RxCpltCallback_dma(DMA_HandleTypeDef *hdma)
void SPIx_DMA_TX_IRQHandler(void)
        HAL_DMA_IRQHandler(&SPI1_HDMA_TX);
void SPIx_DMA_RX_IRQHandler(void)
       HAL_DMA_IRQHandler(&SPI1_HDMA_RX);
//w5500利用spi_dma发送
void W5500_DMA_Configuration(uint8_t* MemBaseAddr, uint32_t len)
         uint8_t p_rxbuf = 0;
         if (HAL_SPI_TransmitReceive_DMA(&SPI1_Handle, MemBaseAddr,&p_rxbuf, len) != HAL_OK)
                 bsp_os_printf("error: bsp_W5500_os: DMA HAL error \r\n");
//              Error_Handler();
        if ((osThreadFlagsWait(0x04,osFlagsWaitAny,1000)&0x04 )==0)
             bsp_os_printf("error: bsp_W5500_os: DMA error \r\n");
现在的现象是 进入调试模式  程序运行到 if ((osThreadFlagsWait(0x04,osFlagsWaitAny,1000)&0x04 )==0)卡死, 点击stop查看程序卡死在哪个地方
发现程序不断进出
这两个函数
进入HAL_DMA_IRQHandler 中断处理函数
发现会进入
/* FIFO Error Interrupt management ******************************************/
if ((tmpisr & (DMA_FLAG_FEIF0_4 << hdma->StreamIndex)) != RESET)
    if(__HAL_DMA_GET_IT_SOURCE(hdma, DMA_IT_FE) != RESET)
      /* Clear the FIFO error flag */
      regs->IFCR = DMA_FLAG_FEIF0_4 << hdma->StreamIndex;
      /* Update error code */
      hdma->ErrorCode |= HAL_DMA_ERROR_FE;
研究很久也没发现问题所在。请问下是什么原因导致的呀
参与人数 1金币 +2 收起 理由
不吃鱼的猫大人 + 2 插个眼
发表于 2024-10-8 16:11:36 | 显示全部楼层
你的SPI配置贴一下,另外这两个关闭了先测试下
 楼主| 发表于 2024-10-8 16:36:40 | 显示全部楼层
/* Set the SPI parameters */
   SPI1_Handle.Instance = SPI1;
   SPI1_Handle.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_4;
   SPI1_Handle.Init.Direction = SPI_DIRECTION_2LINES;
   SPI1_Handle.Init.CLKPhase = SPI_PHASE_1EDGE;
   SPI1_Handle.Init.CLKPolarity = SPI_POLARITY_LOW;
   SPI1_Handle.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLED;
   SPI1_Handle.Init.CRCPolynomial = 7;
   SPI1_Handle.Init.DataSize = SPI_DATASIZE_8BIT;
   SPI1_Handle.Init.FirstBit = SPI_FIRSTBIT_MSB;
   SPI1_Handle.Init.NSS = SPI_NSS_SOFT;
   SPI1_Handle.Init.TIMode = SPI_TIMODE_DISABLED;
   SPI1_Handle.Init.Mode = SPI_MODE_MASTER;
   if (HAL_SPI_Init(&SPI1_Handle) != HAL_OK)
      /* Initialization Error */
      bsp_os_printf("error: bsp_W5500_os: SPI_Configuration: HAL_SPI_Init error\r\n");
      Error_Handler();
          __HAL_SPI_ENABLE(&SPI1_Handle);                 //使能SPI1
//          SPI1_ReadWriteByte(0xff);
发表于 2024-10-9 09:40:57 | 显示全部楼层
   SPI1_Handle.Init.BaudRatePresca ...
这个配置没什么问题。前面这两个配置DISABLE后,效果怎么样
还是不行的话,这里继续加大分频,并使能GPIO配置时的上拉电阻,使能上拉电阻最重要。
发表于 2025-2-8 11:24:47 | 显示全部楼层
最终调通了吗??
发表于 2025-2-8 11:25:40 | 显示全部楼层
我这边一直没有调通,网上能寻找的资料比较少,不知道楼主是否全部调通并且是老化跑通过???
发表于 2025-2-19 18:05:54 | 显示全部楼层
请问您调通了吗?
 楼主| 发表于 2025-2-20 09:24:19 | 显示全部楼层
没有调通,用的SPI_IT模式  也能满足项目需求
发表于 2025-2-20 10:54:08 | 显示全部楼层
我用的H7+W5500之前调通过,但是我没有使用FIFO,这是我之前移植的 H750_W5500_DMA SPI1-8.9 (2).7z (2.41 MB, 下载次数: 46)
发表于 2025-2-20 19:29:21 | 显示全部楼层
方便问一下您的F7+W5500就是传输速率能有多少M吗?
发表于 2025-5-15 16:00:42 | 显示全部楼层
刚刚测试完毕
socket收发缓存:16KB
单次数据:2048 Byte
STM32F407,
使用官方的方法
https://www.w5500.com/w5500/std/example28.html
使用 DMA 模式
SPI时钟配置为42MHz
[ ID] Interval       Transfer     Bandwidth
[424]  0.0- 1.0 sec  2.29 MBytes  19.2 Mbits/sec
SPI时钟配置为21MHz
[432] 280.0-281.0 sec  1.55 MBytes  13.0 Mbits/sec
使用 普通阻塞模式
SPI时钟配置为42MHz
[424]  0.0- 1.0 sec  2.16 MBytes  18.2 Mbits/sec
SPI时钟配置为21MHz
[424]  0.0- 1.0 sec  0.79 MBytes  6.59 Mbits/sec
使用 IT 模式
当使用21MHz,会不能进入 HAL_SPI_TxRxCpltCallback,但在中断加上rtt的打印信息,就能进入,但会影响时序
要将时钟分频到 10.5MHz 才能收发正常,造成速率降低
[372]  0.0- 1.0 sec  0.77 MBytes  6.44 Mbits/sec
发表于 2025-12-13 21:02:30 | 显示全部楼层
HAL_StatusTypeDef SPI2_DMA_TransmitReceive( uint8_t *tx_data, uint8_t *rx_data, uint16_t size )
    HAL_StatusTypeDef status;
    // 开始DMA传输
    status = HAL_SPI_TransmitReceive_DMA( &SPI2_Handler, tx_data, rx_data, size );
    // 等待SPI空闲
    while ( HAL_SPI_GetState( &SPI2_Handler ) != HAL_SPI_STATE_READY )
        /*delay_ms( 10 );*/
        // 可添加超时机制
    return status;
GMT+8, 2026-10-24 09:46 , Processed in 0.467372 second(s), 28 queries .
