查看: 1937|回复: 6
[ThreadX全家桶] USBX HOST MSC 初始化内存越界
发表于 2024-9-25 11:13:02 | 显示全部楼层 |阅读模式
stm32 repo上提供的USBX host MSC实例非常啰嗦,所以自己实现,发现内存越界
ST的实现如下,
#define USBX_HOST_MEMORY_STACK_SIZE     1024 * 22
#define UX_HOST_APP_THREAD_STACK_SIZE   1024
  if (tx_byte_allocate(byte_pool, (VOID **) &pointer,
                       USBX_HOST_MEMORY_STACK_SIZE, TX_NO_WAIT) != TX_SUCCESS)
    /* USER CODE BEGIN USBX_ALLOCATE_STACK_ERORR */
    return TX_POOL_ERROR;
    /* USER CODE END USBX_ALLOCATE_STACK_ERORR */
  /* Initialize USBX Memory */
  if (ux_system_initialize(pointer, USBX_HOST_MEMORY_STACK_SIZE, UX_NULL, 0) != UX_SUCCESS)
    /* USER CODE BEGIN USBX_SYSTEM_INITIALIZE_ERORR */
    return UX_ERROR;
    /* USER CODE END USBX_SYSTEM_INITIALIZE_ERORR */
/* Allocate the stack for host application main thread */
  if (tx_byte_allocate(byte_pool, (VOID **) &pointer, UX_HOST_APP_THREAD_STACK_SIZE,
    /* USER CODE BEGIN MAIN_THREAD_ALLOCATE_STACK_ERORR */
    /* USER CODE END MAIN_THREAD_ALLOCATE_STACK_ERORR */
  /* Create the host application main thread */
  if (tx_thread_create(&ux_host_app_thread, UX_HOST_APP_THREAD_NAME, app_ux_host_thread_entry,
                       0, pointer, UX_HOST_APP_THREAD_STACK_SIZE, UX_HOST_APP_THREAD_PRIO,
                       UX_HOST_APP_THREAD_PREEMPTION_THRESHOLD, UX_HOST_APP_THREAD_TIME_SLICE,
                       UX_HOST_APP_THREAD_START_OPTION) != TX_SUCCESS)
    /* USER CODE BEGIN MAIN_THREAD_CREATE_ERORR */
    return TX_THREAD_ERROR;
    /* USER CODE END MAIN_THREAD_CREATE_ERORR */
static VOID app_ux_host_thread_entry(ULONG thread_input)
  /* USER CODE BEGIN app_ux_host_thread_entry */
  /* Initialization of USB host */
  USBX_APP_Host_Init();
  /* USER CODE END app_ux_host_thread_entry */
VOID USBX_APP_Host_Init(VOID)
  /* USER CODE BEGIN USB_Host_Init_PreTreatment_0 */
  /* USER CODE END USB_Host_Init_PreTreatment_0 */
  /* Initialize the LL driver */
  MX_USB_OTG_HS_HCD_Init();
  /* Register all the USB host controllers available in this system. */
  ux_host_stack_hcd_register(_ux_system_host_hcd_stm32_name,
                             _ux_hcd_stm32_initialize, USB_OTG_HS_PERIPH_BASE,
                             (ULONG)&hhcd_USB_OTG_HS);
ST的实现app_ux_host_thread_entry这个是一次运行的,但是新建了个进程,所以按理说直接调用也是可以的, 新建进程会一直占着内存
发现硬汉的实现非常神奇,传入的数组大小和实际大小不一样,是否也是处理这个问题?
/* USBX动态内存分配 */
#define USBX_MEMORY_SIZE            (32 * 1024)
#define USBX_APP_BYTE_POOL_SIZE     ((1024 * 10) + (USBX_MEMORY_SIZE))
static uint8_t usbx_pool[USBX_APP_BYTE_POOL_SIZE];
ux_system_initialize(usbx_pool, USBX_MEMORY_SIZE, UX_NULL, 0);
上述代码usbx_pool大小是42k,但是ux_system_initialize传入的是32k, 我改到一样大就越界错误了
发表于 2024-9-25 15:42:51 | 显示全部楼层
我没有做USBX的HOST
我只做了个Device的案例
 楼主| 发表于 2024-9-25 15:47:20 | 显示全部楼层
eric2013 发表于 2024-9-25 15:42
我没有做USBX的HOST
我只做了个Device的案例
主要是这里的处理啦,ux_system_initialize(), 其他地方没有用到缓存,就是想了解下为什么要做一个比使用大小大的buffer
 楼主| 发表于 2024-9-25 23:18:13 | 显示全部楼层
最新进展,内存没有越界,改成一样大也可以。
重点是,所有threadx全家桶api若牵扯到使用threadx的,最好再threadx上下文环境中进行,像filex很多api都会检查上下文环境,但是像ux_system_initialize这种就没有,因为是初始化,直接调用就会有问题,改到线程调用就ok了
update: 好像也不对,ST 的代码就是直接调用ux_system_initialize初始化的。。
update2: 找到原因了,直接调用使用系统堆栈,大小不够。线程中调用的话使用线程堆栈,勉强够。。这种越界还真不好找,现象是无法响应中断。。
 楼主| 发表于 2024-9-25 23:20:42 | 显示全部楼层
ps, 为什么大容量的U盘,尤其是exfat格式的,使用filex+usb host msc 总是会造成各种各样的报错甚至hardfault,把分区删掉后重建就ok了。。
发表于 2024-9-26 08:09:13 | 显示全部楼层
Superusrss 发表于 2024-9-25 15:47
主要是这里的处理啦,ux_system_initialize(), 其他地方没有用到缓存,就是想了解下为什么要做一个比使用 ...
这个地方还真忘了为什么这么处理了
发表于 2024-9-26 08:13:28 | 显示全部楼层
Superusrss 发表于 2024-9-25 23:20
ps, 为什么大容量的U盘,尤其是exfat格式的,使用filex+usb host msc 总是会造成各种各样的报错甚至hardfau ...
之前测试exFat的大容量SD,有些刚买的会识别有问题,我是通过SD卡联盟的小软件格式下好了。
GMT+8, 2026-11-24 01:57 , Processed in 1.123376 second(s), 24 queries .
