查看: 1977|回复: 7
[CAN/FDCAN] STM32H743 FDCAN
发表于 2024-9-18 16:43:41 | 显示全部楼层 |阅读模式
回环模式 接收不到数据 麻烦大佬们看看是不是中断以及初始化配置出错
void HAL_FDCAN_RxFifo0Callback(FDCAN_HandleTypeDef *hfdcan, uint32_t RxFifo0ITs)
                if (hfdcan == &hfdcan1)
                                if ((RxFifo0ITs & FDCAN_IT_RX_FIFO0_NEW_MESSAGE) != RESET)
                                        /* 从 RX FIFO0 读取数据 */
                                        HAL_FDCAN_GetRxMessage(hfdcan, FDCAN_RX_FIFO0, &hfdcan1_rx, RXBUF);
                                        /* 激活 Rx FIFO0 watermark notification */
                                        HAL_FDCAN_ActivateNotification(hfdcan, FDCAN_IT_RX_FIFO0_NEW_MESSAGE, 0);
  hfdcan1.Instance = FDCAN1;
  hfdcan1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;
  hfdcan1.Init.Mode = FDCAN_MODE_INTERNAL_LOOPBACK;
  hfdcan1.Init.AutoRetransmission = ENABLE;
  hfdcan1.Init.TransmitPause = DISABLE;
  hfdcan1.Init.ProtocolException = ENABLE;
  hfdcan1.Init.NominalPrescaler = 11;
  hfdcan1.Init.NominalSyncJumpWidth = 1;
  hfdcan1.Init.NominalTimeSeg1 = 4;
  hfdcan1.Init.NominalTimeSeg2 = 5;
  hfdcan1.Init.DataPrescaler = 11;
  hfdcan1.Init.DataSyncJumpWidth = 1;
  hfdcan1.Init.DataTimeSeg1 = 4;
  hfdcan1.Init.DataTimeSeg2 = 5;
  hfdcan1.Init.MessageRAMOffset = 0;
  hfdcan1.Init.StdFiltersNbr = 1;
  hfdcan1.Init.ExtFiltersNbr = 0;
  hfdcan1.Init.RxFifo0ElmtsNbr = 1;
  hfdcan1.Init.RxFifo0ElmtSize = FDCAN_DATA_BYTES_8;
  hfdcan1.Init.RxFifo1ElmtsNbr = 0;
  hfdcan1.Init.RxFifo1ElmtSize = FDCAN_DATA_BYTES_8;
  hfdcan1.Init.RxBuffersNbr = 0;
  hfdcan1.Init.RxBufferSize = FDCAN_DATA_BYTES_8;
  hfdcan1.Init.TxEventsNbr = 0;
  hfdcan1.Init.TxBuffersNbr = 0;
  hfdcan1.Init.TxFifoQueueElmtsNbr = 1;
  hfdcan1.Init.TxFifoQueueMode = FDCAN_TX_FIFO_OPERATION;
  hfdcan1.Init.TxElmtSize = FDCAN_DATA_BYTES_8;
  if (HAL_FDCAN_Init(&hfdcan1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN FDCAN1_Init 2 */
//        /* 设置 Rx FIFO0 的 wartermark 为 0 */
//        HAL_FDCAN_ConfigFifoWatermark(&hfdcan1, FDCAN_CFG_RX_FIFO0, 0);
        /* 激活 RX FIFO0 的 watermark 通知中断,位开启 Tx Buffer 中断*/
        HAL_FDCAN_ActivateNotification(&hfdcan1, FDCAN_IT_RX_FIFO0_NEW_MESSAGE, 0);
        HAL_FDCAN_Start(&hfdcan1);
发表于 2024-9-18 20:33:10 | 显示全部楼层
我是用的那个啥水印中断接收的,我之前用 NEW_MESSAGE 似乎也无法接收
配置的这里。
我是这样写的
    HAL_FDCAN_ConfigFifoWatermark(tCanfd1.CanfdConfig.Canfd, FDCAN_CFG_RX_FIFO0, 1);           // 设置Rx FIFO0的watermark为1,有消息立即通知
    HAL_FDCAN_ActivateNotification(tCanfd1.CanfdConfig.Canfd, FDCAN_IT_RX_FIFO0_WATERMARK, 0); // 激活RX FIFO0的watermark通知中断,位开启Tx Buffer中断
中断的这里。
我是这样写的
if((RxFifo0ITs & FDCAN_IT_RX_FIFO0_WATERMARK) != RESET)
 楼主| 发表于 2024-9-18 23:45:41 | 显示全部楼层
配置的这里。
我修改后还是无法接受,CAN通讯中断接收到的数据是存到设定的数组里面的吗?
发表于 2024-9-19 09:40:59 | 显示全部楼层
你的发送函数怎么写的
 楼主| 发表于 2024-9-19 09:46:27 | 显示全部楼层
eric2013 发表于 2024-9-19 09:40
你的发送函数怎么写的
void         can1_SendPacket(uint8_t *_DataBuf,uint8_t _Len)
        /*下面开始配置CAN发送结构体*/
        hfdcan1_tx.IdType = FDCAN_STANDARD_ID;
        hfdcan1_tx.Identifier = 0x123;
        hfdcan1_tx.FDFormat = FDCAN_CLASSIC_CAN;//设置为经典CAN模式
        hfdcan1_tx.DataLength = (uint32_t) _Len<<16;
        hfdcan1_tx.ErrorStateIndicator = FDCAN_ESI_ACTIVE;
        hfdcan1_tx.BitRateSwitch = FDCAN_BRS_OFF;//波特率不可变
        hfdcan1_tx.TxEventFifoControl = FDCAN_NO_TX_EVENTS;
        hfdcan1_tx.TxFrameType = FDCAN_DATA_FRAME;//数据帧
        hfdcan1_tx.MessageMarker = 0;
        /* 添加数据到 TX FIFO */
        HAL_FDCAN_AddMessageToTxFifoQ(&hfdcan1, &hfdcan1_tx, _DataBuf);
发表于 2024-9-20 08:39:56 | 显示全部楼层
这个部分看着没问题,发个CAN这部分的完整配置看下。
 楼主| 发表于 2024-9-20 09:43:03 | 显示全部楼层
我用您的例程已经解决了这个问题了,还有一个问题,FIFO的watermask 设置1是指接收到1个字节吗?我发送了8个字节的数据,为什么只有设置成1和2的时候才能触发中断,设置更高的阈值就不能触发中断
发表于 2024-9-21 09:29:17 | 显示全部楼层
被arm摧残者 发表于 2024-9-20 09:43
我用您的例程已经解决了这个问题了,还有一个问题,FIFO的watermask 设置1是指接收到1个字节吗?我发送了 ...
是一帧,填充够指定帧数才会触发
GMT+8, 2026-10-24 23:02 , Processed in 0.746618 second(s), 24 queries .
