查看: 1919|回复: 6
[技术讨论] 请大佬看看为啥 我的空闲中断一直进不去
发表于 2024-9-14 09:55:00 | 显示全部楼层 |阅读模式
uint8_t Dmx512_RX[4][520];
void usartRX_dmaTX_Enable(void)
        crm_periph_clock_enable(CRM_USART1_PERIPH_CLOCK,TRUE);
        crm_periph_clock_enable(CRM_DMA2_PERIPH_CLOCK, TRUE);
        dmamux_enable(DMA2, TRUE);
        nvic_priority_group_config(NVIC_PRIORITY_GROUP_4);
        nvic_irq_enable(USART1_IRQn, 0, 1);
        usart_init(USART1, 250000, USART_DATA_8BITS, USART_STOP_2_BIT);
        usart_clock_config(USART1, USART_CLOCK_POLARITY_HIGH, USART_CLOCK_PHASE_1EDGE,USART_CLOCK_LAST_BIT_NONE);
        usart_parity_selection_config(USART1, USART_PARITY_NONE);
        usart_hardware_flow_control_set(USART1, USART_HARDWARE_FLOW_NONE);
        usart_transmitter_enable(USART1, TRUE);
        usart_receiver_enable(USART1, TRUE);
        usart_dma_transmitter_enable(USART1, TRUE);
        usart_dma_receiver_enable(USART1, TRUE);
        usart_rs485_mode_enable(USART1, TRUE);
        usart_interrupt_enable(USART1, USART_ERR_INT, TRUE);
        usart_interrupt_enable(USART1, USART_IDLE_INT, TRUE);
        usart_enable(USART1, TRUE);
        dma_reset(DMA2_CHANNEL1);
        dma_default_para_init(&dma_init_struct);
        dma_init_struct.buffer_size = 520;
        dma_init_struct.direction = DMA_DIR_PERIPHERAL_TO_MEMORY;
        dma_init_struct.memory_base_addr = (uint32_t)Dmx512_RX[0];
        dma_init_struct.memory_data_width = DMA_MEMORY_DATA_WIDTH_BYTE;
        dma_init_struct.memory_inc_enable = TRUE;
        dma_init_struct.peripheral_base_addr = (uint32_t)&USART1->dt;
        dma_init_struct.peripheral_data_width = DMA_PERIPHERAL_DATA_WIDTH_BYTE;
        dma_init_struct.peripheral_inc_enable = FALSE;
        dma_init_struct.priority = DMA_PRIORITY_MEDIUM;
        dma_init_struct.loop_mode_enable = FALSE;
        dma_init(DMA2_CHANNEL1, &dma_init_struct);
        dmamux_init(DMA2MUX_CHANNEL1, DMAMUX_DMAREQ_ID_USART1_RX);
        dma_channel_enable(DMA2_CHANNEL1, TRUE);
void USART1_IRQHandler()
        dma_channel_enable(DMA2_CHANNEL1, FALSE);
        dma_init_struct.priority = DMA_PRIORITY_VERY_HIGH;
        usart_flag_clear(USART1,USART_FERR_FLAG);
        if((Dmx512_RX[0][0] == 0)&&(usart_flag_get(USART1, USART_IDLEF_FLAG) != RESET))
                usart_flag_clear(USART1,USART_IDLEF_FLAG);
                uint8_t DR_text = USART1->sts;
                DR_text = USART1->dt;
                MyDmaCopy_Channel1(&DmxRX_Buffer[0][5],&Dmx512_RX[0][1]);
                Havedata_flagA = 1;
发表于 2024-9-14 10:27:45 | 显示全部楼层
把你的DMA相关配置和使用先去掉,仅开始串口接收中断和空闲中断,看看能进去。
 楼主| 发表于 2024-9-14 10:50:26 | 显示全部楼层
还是一样 但是我发现 他好像只能进ERR中断--> usart_interrupt_enable(USART1, USART_ERR_INT, TRUE);
usart_flag_clear(USART1,USART_FERR_FLAG); -> 我如果不清他就进这个判断if((Dmx512_RX[0][0] == 0)&&(usart_flag_get(USART1, USART_IDLEF_FLAG) != RESET))  但是我感觉好像不是空闲中断触发的 而是错误中断触发的
而我一清 他就进不去了
 楼主| 发表于 2024-9-14 10:58:25 | 显示全部楼层
我串口接收数据为513个
发表于 2024-9-15 09:44:45 | 显示全部楼层
如果是仅可以进入ERR,说明硬件测试环境有干扰,不稳定,检查下线路。
发表于 2024-9-15 21:07:58 | 显示全部楼层
这是GD芯片代码?
发表于 2024-9-16 02:44:39 | 显示全部楼层
yklstudent 发表于 2024-9-15 21:07
这是GD芯片代码?
雅特力的
GMT+8, 2026-11-22 14:46 , Processed in 0.440790 second(s), 24 queries .
