查看: 2237|回复: 3
[Source Insight] SourceInsight4.0 条件编译未生效 代码为什么不变灰色?
发表于 2024-9-10 09:29:58 | 显示全部楼层 |阅读模式
不能有这种效果吗?
发表于 2024-9-10 14:25:10 | 显示全部楼层
https://www.sourceinsight.com/doc/v3/af915255.htm
Inactive Code Style
Source Insight’s C/C++ and Resource File parsers can be made to recognize inactive blocks of code that are disabled at compile-time with #ifdef directives. The Options > Preferences: Language dialog box has “Conditions” buttons that allows you to edit the list of known conditional constants.
Blocks of code that are inactive are given the “Inactive Code” style. For more information, see “Conditional Parsing”.
 楼主| 发表于 2024-9-10 17:23:41 | 显示全部楼层
需要手动一个一个添加呀,我试了可以,感觉好麻烦
发表于 2024-9-10 19:39:59 | 显示全部楼层
如果mdk装个vscode + Keil uVision Assistant插件不香么
GMT+8, 2026-11-24 10:22 , Processed in 1.139928 second(s), 24 queries .
