查看: 1669|回复: 3
[BOOT/IAP] stm32h743 双bank切换不能使用AXI SRAM内存(想做双bank升级)
发表于 2024-9-7 19:45:37 | 显示全部楼层 |阅读模式
参考官方的历程,可以切换,但是不能勾选 0x2400000 内存,勾选上就切换失败!
 楼主| 发表于 2024-9-7 19:52:20 | 显示全部楼层
	FLASH_OBProgramInitTypeDef OBInit;
	/* Unlock the User Flash area */
	HAL_FLASH_Unlock();
	HAL_FLASH_OB_Unlock();
	/* Get the Dual boot configuration status */
	HAL_FLASHEx_OBGetConfig(&OBInit);
	/* Get FLASH_WRP_SECTORS write protection status */
	OBInit.Banks 	= FLASH_BANK_1;
	if(strchr(pra1,'2'))
		 /*Swap to bank2 */
		 /*Set OB SWAP_BANK_OPT to swap Bank2*/
		 OBInit.OptionType = OPTIONBYTE_USER;
		 OBInit.USERType   = OB_USER_SWAP_BANK;
		 OBInit.USERConfig = OB_SWAP_BANK_ENABLE;
		 HAL_FLASHEx_OBProgram(&OBInit);
	if(strchr(pra1,'1'))
		/* Swap to bank1 */
		/*Set OB SWAP_BANK_OPT to swap Bank1*/
		OBInit.USERConfig = OB_SWAP_BANK_DISABLE;
	/* Launch Option bytes loading */
	HAL_FLASH_OB_Launch();
		as the CPU is executing from the Flash Bank1, and the I-Cache is enabled :
		Instruction cache must be invalidated after bank switching to ensure that
		CPU will fetch correct instructions from the flash.
	SCB_InvalidateICache();
 楼主| 发表于 2024-9-7 19:53:12 | 显示全部楼层
代码来自官方历程,官方历程没有勾选这片内存,但是也没说原因
发表于 2024-9-8 15:29:53 | 显示全部楼层
帮顶,没测试过这个,后面有机会了试试。
GMT+8, 2026-10-25 01:54 , Processed in 0.214912 second(s), 24 queries .
