查看: 3130|回复: 1
vscode搭建NXP iMXRT系列开发环境
发表于 2024-9-1 15:38:51 | 显示全部楼层 |阅读模式
1、软件要求
  a、vscode软件(插件:cortex-debug、cmake、makefile等)
  b、MCUXpresso Config Tools v15
  c、arm-none-eabi编译器
  d、jlink驱动
2、对上述软件添加环境变量
3、使用MCUXpresso Config Tools生成GCC环境工程
4、设置环境变量ARMGCC_DIR(配置交叉编译根路径)
5、使用cortex-debug生成该launch文件,注意修改框出来的
7、可以愉快的进行编译并开发调试了。
 楼主| 发表于 2024-9-1 15:48:14 | 显示全部楼层
1、安装Chocolatey
在powershell中执行:
Set-ExecutionPolicy Bypass -Scope Process -Force; iex ((New-Object System.Net.WebClient).DownloadString('https://chocolatey.org/install.ps1'))
2、使用Chocolatey 安装package
choco install make
choco install openocd
3、下载交叉编译器arm-none-eabi
下载地址:Arm GNU Toolchain Downloads | 13.2.Rel1 – Arm Developer
添加环境变量
4、生成工程
略
5、创建launch文件,修改如下:
STM32配置如下:
    // 使用 IntelliSense 了解相关属性。
    // 悬停以查看现有属性的描述。
    // 欲了解更多信息,请访问: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
            "name": "Cortex Debug",
            "cwd": "${workspaceFolder}",
            "executable": "./build/TEST.elf",
            "request": "launch",
            "type": "cortex-debug",
            "runToEntryPoint": "main",
            "servertype": "jlink",
            "device": "STM32H743II",
            "gdbPath": "C:/Program Files/arm-none-eabi/bin/arm-none-eabi-gdb.exe",
            "svdFile": "C:/Users/zhqian/AppData/Local/Arm/Packs/Keil/STM32H7xx_DFP/2.7.0/CMSIS/SVD/STM32H743.svd"
NXP配置如下
    "version": "0.2.0",
    "configurations": [
            "executable": "./flexspi_nor_sdram_debug/hello_world.elf",
            "name": "Debug with JLink",
            "device": "MIMXRT1052xxxxB?BankAddr=0x60000000&Loader=QSPI",
            "showDevDebugOutput": "raw",
            "interface": "swd",
            // "jlinkscript": "evkbimxrt1050_sdram_init.jlinkscript",
            "gdbPath": "D:/Program Files (x86)/arm-gnu-toolchain-12.2.rel1-mingw-w64-i686-arm-none-eabi/bin/arm-none-eabi-gdb.exe",
            "svdFile": "D:/Program Files/IAR Systems/Embedded Workbench 9.2/arm/config/debugger/NXP/MIMXRT1052.svd"
GMT+8, 2026-11-23 04:35 , Processed in 0.920839 second(s), 22 queries .
