查看: 4367|回复: 9
[SEGGER RTT] 添加SEGGER_RTT_printf的浮点数打印
发表于 2024-8-16 18:24:01 | 显示全部楼层 |阅读模式
SEGGER_RTT_vprintf函数中添加代码如下:
case 'f':
      case 'F':
        float fv = (float)va_arg(*pParamList, double); // Retrieves the input floating point value
        v = (int)fv;                                                         // Take the positive integer part
        _PrintInt(&BufferDesc, v, 10u, FieldWidth, FieldWidth, FormatFlags); // According to an integer
        if ((NumDigits == 0) || (NumDigits > 6)) // 最高打印6位小数
          NumDigits = 6;
        _StoreChar(&BufferDesc, '.'); // Display decimal point
        unsigned int powN = _pow(10, NumDigits);
        fv = fv - v;            // 取小数部分
        fv = fv < 0 ? -fv : fv; // 取小数的绝对值
        fv *= powN;             // 根据显示精度取整
        v = (int)(fv);
        if (fv - v >= 0.5f) // 四舍五入
          v += 1;
        _PrintUnsigned(&BufferDesc, (unsigned)v, 10u, NumDigits, FieldWidth, FormatFlags | FORMAT_FLAG_LEFT_JUSTIFY | FORMAT_FLAG_PAD_ZERO); // Display three decimal places
其中依赖的函数与数组:
static unsigned int _powBuf[] = {1, 10, 100, 1000, 10000, 100000, 1000000};
 *       _pow
static unsigned int _pow(unsigned char base, unsigned char index)
  (void)base;
  if (index <= 6)
    return _powBuf[index];
    return 1;
测试浮点的代码:
    float data_float = 1234.12595f;
    double data_double = 1234.12595f;
    float short_pi = 3.14f;
    float pi = 3.1415926535f;
    SEGGER_RTT_printf(0, "data_float = %.0f\n", data_float);
    SEGGER_RTT_printf(0, "data_float = %.1f\n", data_float);
    SEGGER_RTT_printf(0, "data_float = %.2f\n", data_float);
    SEGGER_RTT_printf(0, "data_float = %.3f\n", data_float);
    SEGGER_RTT_printf(0, "data_float = %.4f\n", data_float);
    SEGGER_RTT_printf(0, "data_float = %.5f\n", data_float);
    SEGGER_RTT_printf(0, "data_float = %.6f\n", data_float);
    SEGGER_RTT_printf(0, "data_float = %.7f\n", data_float);
    SEGGER_RTT_printf(0, "-data_float = %f\n", -data_float);
    SEGGER_RTT_printf(0, "-data_float = %03.5f\n", -data_float);
    SEGGER_RTT_printf(0, "-data_float = %6.5lf\n", -data_float);
    SEGGER_RTT_printf(0, "data_double = %.0lf\n", data_double);
    SEGGER_RTT_printf(0, "data_double = %.1lf\n", data_double);
    SEGGER_RTT_printf(0, "data_double = %.2lf\n", data_double);
    SEGGER_RTT_printf(0, "data_double = %.3lf\n", data_double);
    SEGGER_RTT_printf(0, "data_double = %.4lf\n", data_double);
    SEGGER_RTT_printf(0, "data_double = %.5lf\n", data_double);
    SEGGER_RTT_printf(0, "data_double = %.6lf\n", data_double);
    SEGGER_RTT_printf(0, "data_double = %.7lf\n", data_double);
    SEGGER_RTT_printf(0, "-data_double = %lf\n", -data_double);
    SEGGER_RTT_printf(0, "-data_double = %03.5lf\n", -data_double);
    SEGGER_RTT_printf(0, "-data_double = %6.5lf\n", -data_double);
    SEGGER_RTT_printf(0, "pi = %f\n", short_pi);
    SEGGER_RTT_printf(0, "pi = %f\n", pi);
打印效果:
对比电脑端C语言的效果:
占用的flash大小:
增加前: 333.png
增加后: 444.png
flash占用2964Bytes,约2.9KB。
存在的问题:
1. %.0f 处理的不好,正确逻辑应该不打印小数,这里打印了六位最高精度。
原因是想尽量减少修改,如果想正确处理这部分逻辑,需要判断"."的时候添加标志位。而且应该也没什么人打浮点数不打小数吧。
2. double 的精度不够。
可以看到float的精度符合预期,但是double的精度与float相同。比较奇怪的是电脑端的c语言也是一样。
最后吐槽一下CubeIDE:
本来没想在这里添加浮点支持的,但是神奇的CubelIDE使能了-u _printf_float后,flash神奇的增加了十几KB,各位有兴趣的话可以试试。
参与人数 1金币 +100 收起 理由
eric2013 + 100 很给力!
 楼主| 发表于 2024-8-16 18:29:11 | 显示全部楼层
这个浮点打印的精度最高只到六位小数,如果需要增加的话,需要修改第一段代码中的最大值限制,以及第二个计算十次方函数的数组也要对应添加变量。
这份代码的尺寸是我能做到的最小尺寸了,希望有大佬优化一下
发表于 2024-8-17 09:55:54 | 显示全部楼层
这里有个NIT的printf的实现,好像还不错,https://github.com/mpaland/printf
发表于 2024-8-17 10:40:32 | 显示全部楼层
谢谢楼主分享。
 楼主| 发表于 2024-8-20 10:39:45 | 显示全部楼层
测试过了,使用这个的vsnprintf,比我写的大了接近10k。但是比CubeIDE的-u _printf_float小了接近8k。
这个确实更标准、通用一些。
发表于 2024-11-17 21:49:45 | 显示全部楼层
还有优化之处,比如
short_pi = 3.14;
printf("pi = %-7.3fA\n", short_pi);
printf("pi = %07.3fA\n", short_pi);
printf("pi = %10.3fA\n", short_pi);
上面添加的代码,这些和C库的打印出来都不对
发表于 2025-4-1 19:45:48 | 显示全部楼层
有一点小小的问题,当浮点数在(-1,0)之间时,打印出的数字没有负号。
稍微优化了一下,如果有问题,欢迎各位大佬指正。
case 'f':
case 'F':
    int sign = fv < 0 ? -1 : 1; // 记录符号
    fv = fv < 0 ? -fv : fv; // 取绝对值
    int v = (int)fv;                                                         // Take the positive integer part
    if (sign == -1) {
        _StoreChar(&BufferDesc, '-'); // 如果是负数,先输出负号
    if ((Precision == 0) || (Precision > 6)) // 最高打印6位小数
        Precision = 6;
    unsigned int powN = _pow(10, Precision);
    v = (int)(fv);
        v += 1;
    _PrintUnsigned(&BufferDesc, (unsigned)v, 10u, Precision, FieldWidth, FormatFlags | FORMAT_FLAG_LEFT_JUSTIFY | FORMAT_FLAG_PAD_ZERO); // Display three decimal places
发表于 2025-7-15 15:33:32 | 显示全部楼层
在SEGGER_RTT_Config.h中加入
#define SEGGER_RTT_PRINT_FLOAT_ENABLE    1  // 打开浮点打印功能
#define SEGGER_RTT_FLOAT_DECIMAL_PLACES  6  // 定义小数点后的位数
在SEGGER_RTT_printf.c中加入
#if SEGGER_RTT_PRINT_FLOAT_ENABLE
        case 'f':
        case 'F':
            float fv = (float)va_arg(*pParamList, double);    //取出输入的浮点数值
                        if(fv < 0) _StoreChar(&BufferDesc, '-');          // 判断正负,用来显示负号
            v = abs((int)fv);                                 //取整数部分
            _PrintInt(&BufferDesc, v, 10u, NumDigits, FieldWidth, FormatFlags); //显示整数
            _StoreChar(&BufferDesc, '.');                                       //显示小数点
                        uint32_t powbuffer[] = {1, 10, 100, 1000, 10000, 100000, 1000000, 10000000, 100000000, 1000000000};
                        uint32_t powdata;
                        if(SEGGER_RTT_FLOAT_DECIMAL_PLACES > 9)
                                powdata = powbuffer[9];
                                powdata = powbuffer[SEGGER_RTT_FLOAT_DECIMAL_PLACES];
            v = abs((int)(fv * powdata));
            v = v % powdata;
            _PrintInt(&BufferDesc, v, 10u, SEGGER_RTT_FLOAT_DECIMAL_PLACES, FieldWidth, FormatFlags);
#endif
发表于 2025-7-15 17:05:30 | 显示全部楼层
我的修改如下,目前测试正常
case 'f':
      case 'F':
        int powbuffer[] = {1, 10, 100, 1000, 10000, 100000, 1000000};
        int powdata;
        float fv = (float)va_arg(*pParamList, double); // 取出输入的浮点数值
        if (fv < 0)
          fv = -fv;
          NumDigits = 6;
        powdata = powbuffer[NumDigits];
        int ipart = (int)fv;                                // 整数部分
        int fpart = (int)(((fv - ipart) * powdata) + 0.5f); // 小数部分,进行四舍五入
        _PrintInt(&BufferDesc, ipart, 10u, 1, 0, FormatFlags & (~FORMAT_FLAG_PAD_ZERO)); // 显示整数
        _StoreChar(&BufferDesc, '.');                                                    // 显示小数点
        _PrintInt(&BufferDesc, fpart, 10u, NumDigits, FieldWidth,
                  FormatFlags | FORMAT_FLAG_LEFT_JUSTIFY | FORMAT_FLAG_PAD_ZERO); // 显示小数
发表于 2025-7-16 19:44:45 | 显示全部楼层
用编译器自带的sprintf()把浮点转成字符串不香吗?
GMT+8, 2026-11-24 07:55 , Processed in 0.967695 second(s), 28 queries .
