查看: 1604|回复: 3
[ADC] 请教:AD采集的点个数不对
回帖奖励 8 个金币 回复本帖可获得 1 个金币奖励! 每人限 1 次
20
发表于 2024-8-6 19:50:38 | 显示全部楼层 |阅读模式
请教大家一个问题:就是我程序设定外部触发中断,然后进行AD采集,一次只采集1024个点,ADC的时钟我设置的最大是50MHZ,但是实际采集出来一组的点远远超过1024是为什么呢?
下面是我关于ADC的一些配置:
#define ADC_DATA_LENGTH 1024 //定义采集数据长度为1024
uint8_t g_adc3_dma_data1[ADC_DATA_LENGTH];//定义adc3采集数据存放数组
uint8_t g_adc3_dma_complete_flag = 0;        //adc3数据dma采集完成标志,在dma采集完成回调函数设置
ADC_HandleTypeDef hadc3;
DMA_HandleTypeDef hdma_adc3;
void MX_ADC3_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  hadc3.Instance = ADC3;
  hadc3.Init.Resolution = ADC_RESOLUTION_8B;
  hadc3.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc3.Init.EOCSelection = ADC_EOC_SEQ_CONV;//一组结束后给标志
  hadc3.Init.LowPowerAutoWait = DISABLE;
  hadc3.Init.ContinuousConvMode = ENABLE;//开启连续转换
  hadc3.Init.NbrOfConversion = 1;
  hadc3.Init.DiscontinuousConvMode = DISABLE;
  hadc3.Init.ExternalTrigConv = ADC_SOFTWARE_START;//软件触发
  hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
  //一旦 ADC 转换完成,通过 DMA 将数据传输到内存中
  hadc3.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
//  最新采集的数据不会覆盖旧数据
  hadc3.Init.Overrun = OVR_DATA_PRESERVED;
  hadc3.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
  hadc3.Init.OversamplingMode = DISABLE;
  if (HAL_ADC_Init(&hadc3) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  sConfig.OffsetSignedSaturation = DISABLE;
  if (HAL_ADC_ConfigChannel(&hadc3, &sConfig) != HAL_OK)
    Error_Handler();
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  if(adcHandle->Instance==ADC3)
                GPIO_InitTypeDef GPIO_InitStruct = {0};
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_ADC;
    PeriphClkInitStruct.PLL3.PLL3M = 25;
    PeriphClkInitStruct.PLL3.PLL3N = 200;
    PeriphClkInitStruct.PLL3.PLL3P = 4;
    PeriphClkInitStruct.PLL3.PLL3Q = 4;
    PeriphClkInitStruct.PLL3.PLL3R = 2;
    PeriphClkInitStruct.PLL3.PLL3RGE = RCC_PLL3VCIRANGE_0;
    PeriphClkInitStruct.PLL3.PLL3VCOSEL = RCC_PLL3VCOWIDE;
    PeriphClkInitStruct.PLL3.PLL3FRACN = 0;
    PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLL3;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
      Error_Handler();
    /* ADC3 clock enable */
    __HAL_RCC_ADC3_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    /**ADC3 GPIO Configuration
    PC3_C     ------> ADC3_INP1
                GPIO_InitStruct.Pin = GPIO_PIN_3;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG ;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    HAL_SYSCFG_AnalogSwitchConfig(SYSCFG_SWITCH_PC3, SYSCFG_SWITCH_PC3_OPEN);
    /* ADC3 DMA Init */
    /* ADC3 Init */
    hdma_adc3.Instance = DMA1_Stream2;
    hdma_adc3.Init.Request = DMA_REQUEST_ADC3;
    hdma_adc3.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_adc3.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_adc3.Init.MemInc = DMA_MINC_ENABLE;
    hdma_adc3.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_adc3.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_adc3.Init.Mode = DMA_CIRCULAR;//DMA循环模式
    hdma_adc3.Init.Priority = DMA_PRIORITY_HIGH;
    hdma_adc3.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init(&hdma_adc3) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc3);
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
    __HAL_RCC_ADC3_CLK_DISABLE();
    /* ADC3 DMA DeInit */
    HAL_DMA_DeInit(adcHandle->DMA_Handle);
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin) // 处理GPIO_PIN_1的中断事件
    if (GPIO_Pin == GPIO_PIN_1)
                g_adc3_dma_complete_flag = 1;
//ADC回调函数,ADC采集完成后进入回调函数
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef *hadc)
        if(hadc->Instance==ADC3)
                g_adc3_dma_complete_flag = 2;//采集完成标志
                HAL_ADC_Stop_DMA(&hadc3);
void ADC_Caiji(void)
        if(g_adc3_dma_complete_flag == 1)//检测到上升沿开始启动ADC_DMA
//                                HAL_Delay(1);
                                HAL_ADC_Start_DMA(&hadc3,(uint32_t *)g_adc3_dma_data1,ADC_DATA_LENGTH);//ADC的dma开始采集
                                if(g_adc3_dma_complete_flag == 2)
                                        for(int j=0;j<ADC_DATA_LENGTH;j++)
                                                //采集到的值传到上位机串口,注意用仿真器的串口容易死机。
                                                printf("%d\r\n",g_adc3_dma_data1[j]);
                        memset(g_adc3_dma_data1,0,ADC_DATA_LENGTH);//清除数据
发表于 2024-8-7 07:59:43 | 显示全部楼层
回帖奖励 +1 个金币
你看看触发一次外部中断,g_adc3_dma_complete_flag==2这个条件里面的代码是不是不止进入一次?
发表于 2024-8-7 09:14:03 | 显示全部楼层
回帖奖励 +1 个金币
设置成NORMAL,有效解决仅采集一次的问题。
 楼主| 发表于 2024-8-7 09:46:47 | 显示全部楼层
谢谢 我修改试一下
GMT+8, 2026-10-25 02:19 , Processed in 0.221360 second(s), 28 queries .
