查看: 1622|回复: 4
[技术讨论] 本人写了一份dht11的函数接口,求建议
发表于 2024-7-24 18:25:43 | 显示全部楼层 |阅读模式
* bsp_dht11.c
*  Created on: Jul 24, 2024
*      Author: vuxtvg@163.com
#include "bsp_dht11.h"
static void (*g_delay_ms_func)(uint32_t) = NULL;
static void (*g_delay_us_func)(uint32_t) = NULL;
static void (*g_set_out_func)(void) = NULL;
static void (*g_set_in_func)(void) = NULL;
static void (*g_set_out_pin)(uint8_t state) = NULL;
static uint8_t (*g_read_in_pin)(void) = NULL;
static void dht11_delay_ms(uint32_t ms) {
        if (g_delay_ms_func != NULL) {
                g_delay_ms_func(ms);
static void dht11_delay_us(uint32_t us) {
        if (g_delay_us_func != NULL) {
                g_delay_us_func(us);
static void dht11_set_out_func(void) {
        if (g_set_out_func != NULL) {
                g_set_out_func();
static void dht11_set_in_func(void) {
        if (g_set_in_func != NULL) {
                g_set_in_func();
static void dht11_set_out_pin(uint8_t state) {
        if (g_set_out_pin != NULL) {
                g_set_out_pin(state);
static uint8_t dht11_read_in_pin(void) {
        if (g_read_in_pin != NULL) {
                return g_read_in_pin();
        } else {
                return 0;
//复位DHT11  \\起始
static void dhtll_rescb() {
        dht11_set_out_func();
        dht11_set_out_pin(0); //拉低DQ
        dht11_delay_ms(20);
        dht11_set_out_pin(1);        //DQ=1
        dht11_delay_us(30);             //主机拉高20~40us
//等待DHT11的回应
//返回1:未检测到DHT11的存在
//返回0:存在
static uint8_t dht11_checkc() {
        uint8_t retry = 0;
        dht11_set_in_func();             //SET INPUT
        while (dht11_read_in_pin() && retry < 100)             //DHT11会拉低40~80us
                retry++;
                dht11_delay_us(1);
        if (retry >= 100)
                return 1;
                retry = 0;
        while (!dht11_read_in_pin() && retry < 100)             //DHT11拉低后会再次拉高40~80us
                retry++;
                dht11_delay_us(1);
        if (retry >= 100)
                return 1;
        return 0;
//从DHT11读取一个位
//返回值:1/0
static uint8_t dth11_read_bitc() {
        uint8_t retry = 0;
        while (dht11_read_in_pin() && retry < 100)             //等待变为低电平
                retry++;
                dht11_delay_us(1);
        }             //延时100
        retry = 0;
        while (!dht11_read_in_pin() && retry < 100)             //等待变高电平
                retry++;
                dht11_delay_us(1);
        dht11_delay_us(40);             //等待40us
        if (dht11_read_in_pin())
                return 1;
                return 0;
//从DHT11读取一个字节
//返回值:读到的数据DHT11_Read_ByteC
static uint8_t dht11_read_bytec() {
        uint8_t i, dat;
        dat = 0;
        for (i = 0; i < 8; i++) {
                dat <<= 1;
                dat |= dth11_read_bitc();
        return dat;
//初始化DHT11的IO口  同时检测DHT11的存在
//返回1:不存在
//返回0:存在
static uint8_t dht11_initC() {
        dht11_set_out_pin(1);        // 输出高
        dhtll_rescb();  //复位DHT11
        return dht11_checkc();  //等待DHT11的回应
void dht11_module_initC(dht11_module_cfg_t *cfg) {
        g_delay_us_func = cfg->delay_us;
        g_delay_ms_func = cfg->delay_ms;
        g_read_in_pin = cfg->read_in_pin;
        g_set_out_pin = cfg->set_out_pin;
        g_set_in_func = cfg->set_in;
        g_set_out_func = cfg->set_out;
        dht11_initC();
uint8_t dht11_module_read_dataC(float *temperature, float *humidity) {
        uint8_t buf[5];
        uint8_t i;
        dhtll_rescb();
        if (dht11_checkc() == 0) {
                for (i = 0; i < 5; i++) {
                        buf = dht11_read_bytec(); // 读取40位数据
                if ((buf[0] + buf[1] + buf[2] + buf[3]) == buf[4]) {
                        *humidity = buf[0] + buf[1] / 10.0;
                        *temperature = buf[2] + buf[3] / 10.0;
                        return 0;
        return 1;
* bsp_dht11.h
#ifndef BSP_DHT11_H_
#define BSP_DHT11_H_
#include <stdlib.h>
#include <stdint.h>
// Configuration structure
typedef struct {
        void (*delay_us)(uint32_t us); //Us延时函数
        void (*delay_ms)(uint32_t ms); //Ms延时函数
        void (*set_out)(void); //设置引脚输出
        void (*set_in)(void); //设置引脚输入
        void (*set_out_pin)(uint8_t state);  //输出引脚控制
        uint8_t (*read_in_pin)(void); //输入引脚读取
} dht11_module_cfg_t;
void dht11_initc(void);
void dht11_module_initC(dht11_module_cfg_t *cfg);
uint8_t dht11_module_read_dataC(float *temperature, float *humidity);
#endif /* BSP_DHT11_H_ */
调用接口示例
#include "main.h"
#include "dwt_delay.h"
#define DHT11_GPIO_PORT                 GPIOB
#define DHT11_GPIO_PIN                         GPIO_PIN_1
#define DHT11_OUT_PORT                        PBout(1)
#define DHT11_IN_PORT                                PBin(1)
static void DHT11_SET_IN(void) {
        __HAL_RCC_GPIOB_CLK_ENABLE();
        GPIO_InitTypeDef GPIO_InitStruct = { 0 };
        GPIO_InitStruct.Pin = DHT11_GPIO_PIN;
        GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
        GPIO_InitStruct.Pull = GPIO_PULLUP;
        HAL_GPIO_Init(DHT11_GPIO_PORT, &GPIO_InitStruct);
static void DHT11_SET_OUT(void) {
        GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
        GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
void set_out_pin(uint8_t state) {
        DHT11_OUT_PORT = state;
// Example function to read the IN pin state
uint8_t read_in_pin(void) {
        return DHT11_IN_PORT;
void dht11_initc(void) {
        dht11_module_cfg_t dht11_config;
        dht11_config.delay_ms = delay_ms_dwt;
        dht11_config.delay_us = delay_us_dwt;
        dht11_config.read_in_pin = read_in_pin;
        dht11_config.set_in = DHT11_SET_IN;
        dht11_config.set_out = DHT11_SET_OUT;
        dht11_config.set_out_pin = set_out_pin;
        dht11_module_initC(&dht11_config);
void get_temp_humi(void)
        float temperature, humidity;
        dht11_module_read_dataC(&temperature, &humidity);
        printf("temperature:%.1f humidity:%.1f\r\n",temperature,humidity);
还请给一些建议
发表于 2024-7-25 11:46:35 | 显示全部楼层
做的挺好的,很规范。
发表于 2024-7-26 11:40:25 来自手机 | 显示全部楼层
突然发现群友了,振南老师的RTOS我还没看呢
 楼主| 发表于 2024-7-28 00:43:00 | 显示全部楼层
哈哈哈,可以,我看了部分,他没更新完
 楼主| 发表于 2024-7-28 01:24:14 | 显示全部楼层
eric2013 发表于 2024-7-25 11:46
做的挺好的,很规范。
谢谢大佬回复
GMT+8, 2026-11-22 15:26 , Processed in 0.636845 second(s), 24 queries .
