查看: 1893|回复: 6
[RL-TCPnet] 使用硬汉移植的TCPnet初始化后出现007.4 TCP-ERR:Map_Socket, No Listen Socket found
发表于 2024-7-16 09:18:36 | 显示全部楼层 |阅读模式
使用硬汉移植的TCPnet在GD32F407上初始化后作为服务端,客户端还未连接就一直重复打印008.4 TCP-ERR:Map_Socket, No Listen Socket found,想请教下大佬怎么解决,谢谢
[I] [0 ms]IP  : 192:168:10:23
[I] [2 ms]GW  : 192:168:10:1
[I] [5 ms]MASK: 255:255:255:0
[I] [8 ms]PORT: 40
[I] [10 ms]===============================================================
[I] [16 ms]下面是PYH芯片的硬件初始化:
[I] [20 ms]1. Start PHY Init
[I] [23 ms]2. Reset Complete 1
[I] [1704 ms]3. Auto-Negotiation Complete 100532
[I] [1709 ms]4. Connection Succeeded 0
[I] [1712 ms]5. Full-duplex connection
[I] [1716 ms]6. 100Mbps Mode
[I] [1719 ms]PHY_REG_MICR Complete 0
[I] [1722 ms]PHY_REG_MISR Complete 0
[I] [1726 ms]===============================================================
000.0 TCP:Init 5 Sockets
000.0 TCP: Local MSS: 1460
000.0 TCP:Socket 1 allocated
000.0 TCPisten Socket 1, Port 40
[D] [tcpnet][272][1743 ms]tcp listen res = 1
007.4 TCP:*** Processing frame ***
007.4 TCP: Ports  : Src=59286, Dst=9100
007.4 TCP: Segment: Seq=0xF217AB34, Ack=0x0
007.4 TCP: Control: [SYN] Win=64240, Cks=0x359E
007.4 TCP: Frame not mapped
007.4 TCP:Sending Reset
007.4 TCP: Ports  : Src=9100, Dst=59286
007.4 TCP: Segment: Seq=0x0, Ack=0x0
007.4 TCP: Control: [RST] Win=0, Cks=0x0EAC
008.4 TCP:*** Processing frame ***
008.4 TCP: Ports  : Src=59286, Dst=9100
008.4 TCP: Segment: Seq=0xF217AB34, Ack=0x0
008.4 TCP: Control: [SYN] Win=64240, Cks=0x359E
 楼主| 发表于 2024-7-16 09:26:04 | 显示全部楼层
客户端可以正常连上,通信也正常
 楼主| 发表于 2024-7-16 09:27:09 | 显示全部楼层
同样的软件更换STM32F407又不会出现 TCP-ERR:Map_Socket, No Listen Socket found,一切正常
 楼主| 发表于 2024-7-16 09:34:38 | 显示全部楼层
初始化部分的代码
初始化
初始化
 楼主| 发表于 2024-7-16 09:41:41 | 显示全部楼层
同一块板子同一软件换个IP就正常了,怀疑MAC地址有关系,我把MAC地址绑定了IP
 楼主| 发表于 2024-7-16 11:02:08 | 显示全部楼层
把MAC地址生成改成随机数,确保唯一性
发表于 2024-7-16 12:14:07 | 显示全部楼层
注意这个问题了把
//   <s.17>MAC Address
//   <i>Ethernet MAC Address in text representation
//   <i>Value FF-FF-FF-FF-FF-FF is not allowed,
//   <i>LSB of first byte must be 0 (an ethernet Multicast bit).
//   <i>Default: "1E-30-6C-A2-45-5E"
#define ETH0_MAC_ADDR           "1E-30-6C-A2-45-5E"
GMT+8, 2026-11-25 09:54 , Processed in 0.224219 second(s), 27 queries .
