查看: 10253|回复: 1
[SecureCRT] SecureCRT & SecureFX 6.6.278汉化(破解)
发表于 2013-6-21 20:36:57 | 显示全部楼层 |阅读模式
http://www.imuyang.com/thread-11413-1-1.html
[blockquote]声明:6.5开始,securecrt在部分电脑上菜单字体会偏小,无法定位原因,英文原版,汉化版都碰到过此问题,如果你碰到此问题,请使用英文原版试试
官方v6.6.1 b289 : hxxp://download.pchome.net/internet/telnet/download-169817.html
破解补丁:   hxxp://u.115.com/file/f67664ca4[/blockquote]
[blockquote]11.16更新: 以前使用资源编辑器调整控件大小,可能会导致某些功能不正常,这次统一定位到表示控件大小的x,y,cx,cy字节处,直接修改大小。
汉化版下载地址:http://u.115.com/file/f642daf5d0[/blockquote]由于没找到破解和注册机,发现6.5的AGAIN破解还可以用,注册方法:双击执行reg.reg
使用前最好删除配置文件夹下的SCRTMenuToolbar.ini和SFXMenuToolbar.ini,这两个文件存储的是上一版本的中英文菜单字符串。
如果觉得此版本不好用,想换回旧版本,请删除键值HKEY_LOCAL_MACHINE\SOFTWARE\VanDyke后再执行,否则可能会程序崩溃,原因是TBE和AGAIN的破解不一样
软件介绍请链接:http://download.pchome.net/internet/telnet/detail-169817.html
下载地址:http://u.115.com/file/f6bee58ccb
推荐一个等宽支持中文字体Megatops ProCoder 1.0 GB2312,使用方法:安装字体,导入注册表,重启。CRT里乱码多半是字体不支持中文的缘故,不过有的HPUX主机用more看会乱码,但cat或vi就不会。
字体下载:http://u.115.com/file/f698d2f7df
字体作者主页:http://megatops.wordpress.com/20 ... %E7%89%88%E6%9C%AC/
securecrt 6.6
[blockquote]New features:
- SecureCRT for Mac OS X delivers right out of the gate, with
reliable, mature terminal emulation, tabbed sessions, security,
powerful session configuration, and printing support.
- SecureCRT for Mac OS X adds support for the local command shell.
- Added embedded support for the Python scripting language.
- New Raw protocol mode allows for no (or little) interpretation of
data from the remote system, which is helpful for
troubleshooting.
- Added a "Send Binary" transfer option.
- A unique log name is automatically generated when the specified
name is in use (e.g., cloned or SFTP sessions).
- Arguments can be passed to scripts from buttons and mapped keys.
- Added new double-click options to tabs; these options are "Send
Tab to New Window" and "Reconnect Tab".
- On Windows, the button bar can be positioned at the top of the
SecureCRT window.
- Added an option to ConnectInTab() that will allow for silent
failure when it fails to connect to a host.
- SSH1/SSH2: Added support for the "null" host-key algorithm for
GSS-KEX as specified in RFC 4462. [/blockquote]securefx 6.6
- Limit or "throttle" the bandwidth used during file transfers to
keep from consuming all available bandwidth.
- Specify the number of parallel file transfers and, as transfers
are completed, queued files will continually fill available slots.
- Selecting Download on remote files automatically places the files
in the local CWD if a different download location has not been
specified.
- If a PASV data connection fails, SecureFX automatically tries to
reconnect using the original host/IP address.
- Added an Upload button that can be used for menu and toolbar
customization.
- The same file size display options that were previously available
for the transfer window are now also available for the tree view.
- SSL: Support for RFC 2228 Clear Command Channel (CCC) provides
enhanced compatibility with SSL servers.
- FTP/SSL: Available and negotiated SSL algorithms for implicit
as well as explicit connections are now logged.
- SFTP: Added the session INI-file-only option &quotreferred SFTP
Version" that forces SecureFX to use a specific SFTP version.
- SSH2: Added support for the "null" host-key algorithm for GSS-KEX
- SFXCL: A password can be specified when using a session with
SFXCL.
- SFXCL: Added two new options to the /S switch. The "TransferType"
option allows the transfer type to be specified independently of
the file type. The "Attr" option allows the file type to be
specified independently of the transfer type. [/blockquote]
发表于 2013-10-25 17:06:26 | 显示全部楼层
顶起,工具先进,开发效率提高不少,收藏了
[s:151]
GMT+8, 2026-11-24 08:03 , Processed in 0.260607 second(s), 23 queries .
