查看: 1678|回复: 4
[有问必答] stm32f407+freertos+串口空闲中断+DMA,不进入串口中断回调函数
发表于 2024-7-5 15:21:45 | 显示全部楼层 |阅读模式
使用了stm32f407+freertos+串口空闲中断+DMA,dma和串口的中断都开启了都在freertos的管理范围内(都是5),但是只能进入USART1_IRQHandler这个中断函数不会进入DMA2_Stream2_IRQHandler、HAL_UARTEx_RxEventCallback、HAL_UART_RxCpltCallback这些函数,求大佬解答
void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  if(uartHandle->Instance==USART1)
  /* USER CODE BEGIN USART1_MspInit 0 */
  /* USER CODE END USART1_MspInit 0 */
    /* USART1 clock enable */
    __HAL_RCC_USART1_CLK_ENABLE();
    __HAL_RCC_GPIOA_CLK_ENABLE();
    /**USART1 GPIO Configuration
    PA9     ------> USART1_TX
    PA10     ------> USART1_RX
    GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART1;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    /* USART1 DMA Init */
    /* USART1_RX Init */
    hdma_usart1_rx.Instance = DMA2_Stream2;
    hdma_usart1_rx.Init.Channel = DMA_CHANNEL_4;
    hdma_usart1_rx.Init.Direction = DMA_PERIPH_TO_MEMORY;
    hdma_usart1_rx.Init.PeriphInc = DMA_PINC_DISABLE;
    hdma_usart1_rx.Init.MemInc = DMA_MINC_ENABLE;
    hdma_usart1_rx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
    hdma_usart1_rx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
    hdma_usart1_rx.Init.Mode = DMA_CIRCULAR;
    hdma_usart1_rx.Init.Priority = DMA_PRIORITY_LOW;
    hdma_usart1_rx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
    if (HAL_DMA_Init(&hdma_usart1_rx) != HAL_OK)
      Error_Handler();
    __HAL_LINKDMA(uartHandle,hdmarx,hdma_usart1_rx);
    /* USART1 interrupt Init */
    HAL_NVIC_SetPriority(USART1_IRQn, 5, 0);
    HAL_NVIC_EnableIRQ(USART1_IRQn);
  /* USER CODE BEGIN USART1_MspInit 1 */
  /* USER CODE END USART1_MspInit 1 */
发表于 2024-7-5 19:33:23 | 显示全部楼层
看上去你的DMA中断没有打开呀
发表于 2024-7-5 19:57:33 | 显示全部楼层
  /* DMA controller clock enable */
  __HAL_RCC_DMA2_CLK_ENABLE();
HAL_NVIC_SetPriority(DMA2_Stream4_IRQn, 5, 0);
  HAL_NVIC_EnableIRQ(DMA2_Stream4_IRQn);
这几句加了没?
发表于 2024-7-6 09:19:22 | 显示全部楼层
看看有没有打开对应的中断
发表于 2024-7-7 11:47:36 来自手机 | 显示全部楼层
不要用circle模式。遇见问题先单步调试。跟踪一下调用。
GMT+8, 2026-1-11 22:30 , Processed in 0.062540 second(s), 23 queries .
