查看: 3378|回复: 4
[FreeRTOS] STM32CubeMX配置FreeRTOS任务优先级问题
发表于 2024-7-2 10:24:30 | 显示全部楼层 |阅读模式
用STM32CubeMX 配置CMSIS-RTOS V1版本的FreeRTOS,发现任务优先级设置里面,只有7个优先级,即使在“Config parameters”里把MAX_PRIORITIES设置为大于7, 在创建任务时也只有7个选项。
这7个选项分别是:
osPriorityIdle,osPriorityLow,osPriorityBelowNormal,osPriorityNormal,osPriorityAboveNormal,osPriorityHigh,osPriorityRealtime
这种描述让人看着非常懵,为什么不用FreeRTOS原生的数字表示不同优先级呢,而且这几个优先级和FreeRTOS怎么对应起来的也不清楚,如果我要设置超过7个优先级,又该如何设置?
谁能解释下啊
发表于 2024-7-2 13:53:48 | 显示全部楼层
代码里面go to definiton 能找到对应优先级的数字
cubemX可以设置优先级最大值 但是这好像设置不了,你看看你的行不行
发表于 2024-7-2 14:32:10 | 显示全部楼层
用的V2
发表于 2024-7-3 10:46:44 | 显示全部楼层
osPriorityIdle,osPriorityLow,osPriorityBelowNormal,osPriorityNormal,osPriorityAboveNormal,osPriorityHigh,osPriorityRealtime的大小就是实际数值大小
发表于 2024-7-6 19:46:09 | 显示全部楼层
不用管,这都是为了兼容设计,免费的就不要纠结了。倒是V2的好像没有使用专门为arm设计的切换寄存器功能,就是CLZ这个功能。
USE_PORT_OPTIMISED_TASK_SELECTION USE_PORT_OPTIMISED_TASK_SELECTION Parameter Description: Some FreeRTOS ports have two methods of selecting the next task to execute - a generic method, and a method that is specific to that port. The Generic method: - Is used when configUSE_PORT_OPTIMISED_TASK_SELECTION is set to 0, or when a port specific method is not implemented. - Can be used with all FreeRTOS ports. - Is completely written in C, making it less efficient than a port specific method. - Does not impose a limit on the maximum number of available priorities. A port specific method: - Is not available for all ports. - Is used when configUSE_PORT_OPTIMISED_TASK_SELECTION is set to 1. - Relies on one or more architecture specific assembly instructions (typically a Count Leading Zeros [CLZ] of equivalent instruction) so can only be used with the architecture for which it was specifically written. - Is more efficient than the generic method. - Typically imposes a limit of 32 on the maximum number of available priorities. Warning:  Forced to 1 (Enabled) since FreeRTOS v9 support.
GMT+8, 2026-11-24 15:15 , Processed in 0.238329 second(s), 27 queries .
