查看: 1908|回复: 4
[SPI/QSPI] 请教下, h7 的 qspi 使用 2片 mt25ql256 组合成8bit 的, 貌似读写失败 ?
发表于 2024-6-29 21:13:39 | 显示全部楼层 |阅读模式
原理图:
软件配置:
int bsp_qspi_quad_mt25ql256a(void)
        uint8_t buf[23] = {0}, val;
        __QSPI_CLK_ENABLE();
  QSPI_Handle.Instance = QUADSPI;
        /* 设置时钟速度,QSPI clock = 240MHz / (ClockPrescaler+1) = 120MHz */
  QSPI_Handle.Init.ClockPrescaler = 1;
  QSPI_Handle.Init.FifoThreshold = 1;
  QSPI_Handle.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_HALFCYCLE;
        /*Flash大小是2^(FlashSize + 1) = 2^26 = 64MB */
  QSPI_Handle.Init.FlashSize = QSPI_FLASH_SIZE;  //25;
  QSPI_Handle.Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_6_CYCLE;
  QSPI_Handle.Init.ClockMode = QSPI_CLOCK_MODE_0;
  /* 启用了双片 , 这里需要启动双片功能  */
  QSPI_Handle.Init.DualFlash = QSPI_DUALFLASH_ENABLE;
  if (HAL_QSPI_Init(&QSPI_Handle) != HAL_OK)  // 这个 HAL_QSPI_MspInit  函数被 HAL_QSPI_Init 所调用
    return 2;
  HAL_Delay(50);
  * @brief  This function put QSPI memory in QPI mode (quad I/O).
  * @param  hqspi: QSPI handle
  * @retval None
static QSPI_StaticTypeDef QSPI_EnterMemory_QPI( QSPI_HandleTypeDef *hqspi )
        int  i;
  QSPI_CommandTypeDef      s_command = {0};
  /* Initialize the QPI enable command */
  /* QSPI memory is supported to be in SPI mode, so CMD on 1 LINE */
  s_command.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
  s_command.Instruction       = ENTER_QUAD_CMD;
  s_command.AddressMode       = QSPI_ADDRESS_NONE;
  s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
  s_command.DataMode          = QSPI_DATA_NONE;
  s_command.DummyCycles       = 0;
  s_command.DdrMode           = QSPI_DDR_MODE_DISABLE;
  s_command.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
  s_command.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
  /* Send the command */
  if (HAL_QSPI_Command(hqspi, &s_command, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
    return QSPI_ERROR;
        for(i=0;i<0xfff;i++) {}  // 简短延时,等待芯片内部工作稳定,对于 MT25QL256ABA1EW9-0SIT 可以不使用
QSPI_StaticTypeDef QSPI_WritePageByte(uint8_t * _pBuf, uint32_t _uiWriteAddr, uint32_t _size)
  QSPI_StaticTypeDef res;
  QSPI_CommandTypeDef sCommand = {0};
        if (QSPI_WriteEnable(&QSPI_Handle) != QSPI_OK)
                return QSPI_ERROR;
        /* 基本配置 */
        sCommand.InstructionMode   = QSPI_INSTRUCTION_4_LINES;  /* 4线方式发送指令 */
        sCommand.AddressSize       = QSPI_ADDRESS_32_BITS;       /* 32位地址 */
        sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;  /* 无交替字节 */
        sCommand.DdrMode           = QSPI_DDR_MODE_DISABLE;      /*  不支持DDR */
        sCommand.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;  /* DDR模式,数据输出延迟 */
        sCommand.SIOOMode          = QSPI_SIOO_INST_ONLY_FIRST_CMD;         /* 仅发送一次命令 */
        /* 写序列配置 */
        sCommand.Instruction = QUAD_IN_FAST_PROG_4_BYTE_ADDR_CMD; /* 32bit地址的4线快速写入命令 */
        sCommand.DummyCycles = 0;                    /* 不需要空周期 */
        sCommand.AddressMode = QSPI_ADDRESS_4_LINES; /* 4线地址方式 */
        sCommand.DataMode    = QSPI_DATA_4_LINES;    /* 4线数据方式 */
        sCommand.NbData      = _size;                /* 写数据大小 */
        sCommand.Address     = _uiWriteAddr;         /* 写入地址 */
  if (HAL_QSPI_Command(&QSPI_Handle, &sCommand, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
    return QSPI_ERROR;
     if (HAL_QSPI_Transmit(&QSPI_Handle, (uint8_t *)_pBuf, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
                return QSPI_ERROR;
  res = QSPI_AutoPollingMemReady(&QSPI_Handle);
  if (res != QSPI_OK)
    return res;
  return QSPI_OK;
目前有几点疑问:
01. 关于 接口是 组成 8bit 的, 单片 qspi 芯片接口是 4bit, mcu 内部是吧一个 8bit 字节的数据自动分成 2组 4bit 进行发送吗 ?
02. mcu 在数据接收时也是自动的吧 2片 qspi 的 4bit 数据进行组合成 8bit 的数据吗 ?
03. 2片 4bit 的32MB 大小的芯片, 组合成 8bit 的 64MB 大小, 那
       QSPI_Handle.Init.FlashSize = QSPI_FLASH_SIZE;   这个地方是设置为 32MB 还是 64MB 呢 ???
发表于 2024-6-30 09:05:11 | 显示全部楼层
ST的H743X综合评估板是采用的这个,你可以参考下,我没用过双QSPI组成8bit的用法
 楼主| 发表于 2024-6-30 11:55:22 | 显示全部楼层
捣鼓了一个晚上,终于搞定了呀, 不容易了
在读取状态时需要读取 2 字节的状态数据 ,
使用 中断 及查询方法读写都成功了,
qspi-dual-rw.png 2片 4ibt 的组合成 8 bit 的, 这个读写速度慢不慢 ??
使用 dma 模式失败 ,也不知道是 dma 模式写出错还是读出错 , ??
发表于 2024-7-1 08:03:18 | 显示全部楼层
内存映射模式试试。
 楼主| 发表于 2024-7-1 09:26:07 | 显示全部楼层
eric2013 发表于 2024-7-1 08:03
内存映射模式试试。
后续试试看看速度会不会比 4bit 的 要快一些
GMT+8, 2026-10-25 04:03 , Processed in 0.732127 second(s), 27 queries .
