查看: 2175|回复: 4
STM32g474驱动M93C56
发表于 2024-6-7 15:24:59 | 显示全部楼层 |阅读模式
void M93c56_Write(uint8_t* pBuffer,uint8_t WriteAddr,uint8_t NumByteToRead)
        uint16_t i;
#if 0    //一个字节写
         M93c56_WriteEnableCmd();
     M93C56_ENABLE();     //使能从设备,置高
         SPI2_ReadWriteByte(M93C56_WRITE_CMD);      //发送写命令 00x0A  0000 1010 0000 0000
         SPI2_ReadWriteByte(WriteAddr);  //发送写地址
         SPI2_ReadWriteByte(pBuffer[0]);  //发送写数据
         M93C56_DISABLE();     //使能从设备,置低
         osDelay(5);
         osDelay(10);
     M93c56_WriteDisableCmd();
#endif
     M93c56_WriteEnableCmd();       //写多个字节
     for(i=0;i<NumByteToRead;i++)
       SPI2_ReadWriteByte(pBuffer[i]);
     osDelay(5);
     osDelay(10);
static uint8_t SPI2_ReadWriteByte(uint8_t TxData)
uint8_t RxData;
HAL_SPI_TransmitReceive(&hspi2,&TxData,&RxData,1, 1000);
return RxData; //返回收到的数据
static void M93c56_WriteEnableCmd()
  M93C56_ENABLE();     //使能从设备,置高 0x09 0x80
  SPI2_ReadWriteByte(M93C56_WRITEEN_CMD);
  SPI2_ReadWriteByte(M93C56_WRITEEN_Add);
  M93C56_DISABLE();
static void M93c56_WriteDisableCmd()
          M93C56_ENABLE();     //使能从设备,置高 0x08 0x00
          SPI2_ReadWriteByte(M93C56_WRITEDISEN_CMD);
          SPI2_ReadWriteByte(M93C56_WRITEDISEN_Add);
          M93C56_DISABLE();
这样写有问题吗?写的时候有busy和ready判断,做了延时,没做判断,然后这个时序是写一个字节还是多个字节没看明白?
写时序图
写时序图
发表于 2024-6-8 01:28:40 | 显示全部楼层
 楼主| 发表于 2024-6-14 17:32:16 | 显示全部楼层
eric2013 发表于 2024-6-8 01:28
这个ST提供驱动了
https://www.st.com/en/evaluation-tools/x-nucleo-eeprma2.html#tools-software
对于这个例程 我有点问题啊 ,SPI通讯读取数据时候要先发送空字节过去呼唤,才会回复数据,为什么例程钟直接接收数据呢,如下
  * @brief  Read data, at specific address, through spi to the M95xx
  * @param  pData: pointer to the data to read
  * @param  TarAddr : I2C data memory address to write
  * @param  DevAddr : Target device address
  * @param  Size : Size in bytes of the value to be written
  * @param  Inst : SPI instruction
  * @retval EEPROMEX enum status
int32_t EEPRMA2_SPI_RecvBuffer(uint8_t * pData, uint32_t TarAddr,
                               uint32_t DevAddr, const uint16_t Size, const uint8_t Inst )
  EEPROMEX_CTRL_LOW( (uint8_t)DevAddr & EEPROMEX_SPI_SLAVESEL );
  if (EEPRMA2_M95_IOWrite(Inst) != BSP_ERROR_NONE)
    return BSP_ERROR_COMPONENT_FAILURE;
  if (EEPRMA2_M95_WriteAddr(TarAddr, DevAddr) != BSP_ERROR_NONE )
  if (EEPRMA2_SPI_RECV( pData, Size ) != BSP_ERROR_NONE )
  EEPROMEX_CTRL_HIGH( (uint8_t)DevAddr & EEPROMEX_SPI_SLAVESEL );
  return BSP_ERROR_NONE;
先片选控制,然后发送读命令,再发送读地址,应该再发送空字节读取数据,这里为什么没有发送空字节呢?
int32_t EEPRMA2_M95_IOWrite(uint8_t TxData )
  int32_t status = BSP_ERROR_NONE;
  status = EEPRMA2_SPI_SEND( &TxData, 1);
  return status;
#define EEPRMA2_SPI_SEND         BSP_SPI1_Send
int32_t EEPRMA2_M95_WriteAddr( const uint32_t TarAddr, const uint32_t DevAddr)
  uint8_t AddrSize;
  static uint8_t Addr[3];
  uint8_t count, temp;
  uint32_t addrpacket = TarAddr;
  AddrSize = ( (uint8_t)DevAddr & EEPROMEX_SPI_ADDRSEL ) >> EEPROMEX_SPI_ADDRSHIFT;
  for (count = AddrSize; count > 0U; count--){
    temp = (uint8_t)( addrpacket & 0xFFU );
    Addr[count - 1U] = temp;
    addrpacket = addrpacket >> 8U;
  return  EEPRMA2_SPI_SEND( Addr, AddrSize );
#define EEPRMA2_SPI_RECV         BSP_SPI1_Recv
int32_t  BSP_SPI1_Recv(uint8_t *pData, uint16_t Length)
  int32_t ret = BSP_ERROR_NONE;
  if(HAL_SPI_Receive(&hspi1, pData, Length, BUS_SPI1_POLL_TIMEOUT) != HAL_OK)
      ret = BSP_ERROR_UNKNOWN_FAILURE;
  return ret;
 楼主| 发表于 2024-6-14 17:33:28 | 显示全部楼层
这个ST提供驱动了
  return status;
  uint8_t AddrSize;
  return ret;
发表于 2024-6-15 09:06:02 | 显示全部楼层
zhangtingxcy 发表于 2024-6-14 17:33
对于这个例程 我有点问题啊 ,SPI通讯读取数据时候要先发送空字节过去呼唤,才会回复数据,为什么例程钟 ...
没用过这个芯片
GMT+8, 2026-10-24 18:25 , Processed in 0.241304 second(s), 27 queries .
