查看: 1697|回复: 3
[STM32H7] STM32H7 为什么要32字节的整数倍才能写?
发表于 2024-5-22 19:36:31 | 显示全部楼层 |阅读模式
代码如下:
  * @brief  This function writes a data buffer in flash (data are 32-bit aligned).
  * @note   Buff size 必须4字节对齐
  * @param  FlashAddress: start address for writing data buffer
  * @param  Data: pointer on data buffer
  * @param  DataLength: length of data buffer (unit is 32-bit word)
Func_Status BSP_FLASH_Write(uint32_t FlashAddress,  void *pBuffer ,  uint32_t WordLength)
	Func_Status ret = Ret_OK;
	if((FlashAddress < APP_START_ADDR) || (FlashAddress > FLASH_END_ADDR))
		ret = Ret_PARAM_ERR;
		return ret;
	HAL_FLASH_Unlock();
	for (int i = 0; i < WordLength; i+=8)
		if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_FLASHWORD, FlashAddress, ((uint32_t)(pBuffer+i))) == HAL_OK)
			FlashAddress += 32;
			ret = Ret_ERROR;
	HAL_FLASH_Lock();
	return ret;
 楼主| 发表于 2024-5-22 19:37:12 | 显示全部楼层
这是硬汉哥的历程里的代码,看了几遍,没看懂~
发表于 2024-5-23 08:38:33 | 显示全部楼层
这个是数据手册里面的硬性要求,操作单位256bit
 楼主| 发表于 2024-5-23 09:37:00 | 显示全部楼层
确实,手册看少了
GMT+8, 2026-10-25 04:03 , Processed in 0.246623 second(s), 27 queries .
