查看: 1894|回复: 2
[STM32H7] STM32H750 RTC wakeup中断唤醒
回帖奖励 15 个金币 回复本帖可获得 5 个金币奖励! 每人限 1 次
发表于 2024-5-21 11:31:16 | 显示全部楼层 |阅读模式
我使用stm32H750的rtc中断唤醒功能,1s进入一次中断,出现的问题就是,程序第一次烧写可以正常执行,再次烧写程序及后续,唤醒中断就再也进不去了,好奇怪,不知道为甚?,下面有配置详情,问下哪位大佬遇见这个问题
初始化函数:
void MX_RTC_Init(void)
  /* USER CODE BEGIN RTC_Init 0 */
  HAL_RTC_MspDeInit(&hrtc);
  /* USER CODE END RTC_Init 0 */
  RTC_TimeTypeDef sTime = {0};
  RTC_DateTypeDef sDate = {0};
  /* USER CODE BEGIN RTC_Init 1 */
  /* USER CODE END RTC_Init 1 */
  /** Initialize RTC Only
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN Check_RTC_BKUP */
  /* USER CODE END Check_RTC_BKUP */
  /** Initialize RTC and set the Time and Date
  sTime.Hours = 0x0;
  sTime.Minutes = 0x0;
  sTime.Seconds = 0x0;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  sDate.WeekDay = RTC_WEEKDAY_MONDAY;
  sDate.Month = RTC_MONTH_JANUARY;
  sDate.Date = 0x1;
  sDate.Year = 0x0;
  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  /** Enable the WakeUp
  if (HAL_RTCEx_SetWakeUpTimer_IT(&hrtc, 0, RTC_WAKEUPCLOCK_CK_SPRE_16BITS) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN RTC_Init 2 */
  /* USER CODE END RTC_Init 2 */
void HAL_RTC_MspInit(RTC_HandleTypeDef* rtcHandle)
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  if(rtcHandle->Instance==RTC)
  /* USER CODE BEGIN RTC_MspInit 0 */
  /* USER CODE END RTC_MspInit 0 */
  /** Initializes the peripherals clock
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_RTC;
    PeriphClkInitStruct.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
      Error_Handler();
    /* RTC clock enable */
    __HAL_RCC_RTC_ENABLE();
    /* RTC interrupt Init */
    HAL_NVIC_SetPriority(RTC_WKUP_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(RTC_WKUP_IRQn);
  /* USER CODE BEGIN RTC_MspInit 1 */
  /* USER CODE END RTC_MspInit 1 */
中断回调函数:
void RTC_WKUP_IRQHandler(void)
  /* USER CODE BEGIN RTC_WKUP_IRQn 0 */
  /* USER CODE END RTC_WKUP_IRQn 0 */
  HAL_RTCEx_WakeUpTimerIRQHandler(&hrtc);
  /* USER CODE BEGIN RTC_WKUP_IRQn 1 */
  /* USER CODE END RTC_WKUP_IRQn 1 */
/* USER CODE BEGIN 1 */
void HAL_RTCEx_WakeUpTimerEventCallback(RTC_HandleTypeDef *hrtc)
    HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_13);
发表于 2024-5-21 14:32:22 | 显示全部楼层
回帖奖励 +5 个金币
帮顶,这个不清楚,没有研究过。
 楼主| 发表于 2024-5-21 17:10:09 | 显示全部楼层
解决了,需要在使能唤醒中断前清除RTC_FLAG_WUTF这个标志位,即添加这句代码:__HAL_RTC_WAKEUPTIMER_CLEAR_FLAG(&hrtc, RTC_FLAG_WUTF);在下面使能唤醒中断代码前面。 也奇怪cubemax生成的代码没有清除这个标志位,乱搞半天。
 __HAL_RTC_WAKEUPTIMER_CLEAR_FLAG(&hrtc, RTC_FLAG_WUTF);if (HAL_RTCEx_SetWakeUpTimer_IT(&hrtc, 0, RTC_WAKEUPCLOCK_CK_SPRE_16BITS) != HAL_OK)
        Error_Handler();
不过还是感谢硬汉大佬帮顶了
发表于 2024-5-22 12:59:11 | 显示全部楼层
ch123 发表于 2024-5-21 17:10
解决了,需要在使能唤醒中断前清除RTC_FLAG_WUTF这个标志位,即添加这句代码:__HAL_RTC_WAKEUPTIMER_CLEAR ...
谢谢告知最终原因
GMT+8, 2026-10-25 04:03 , Processed in 0.174646 second(s), 25 queries .
