查看: 3739|回复: 15
threadx使用USBX+FileX来读写U盘的文件
发表于 2024-5-8 10:24:18 | 显示全部楼层 |阅读模式
使用的是stm32f429,参考的STM32的例程Ux_Host_Msc。
插入U盘后,U盘是fat32格式的,板子串口输出信息如下:
**** USB OTG FS MSC Host ****
USB Host library started.
Starting MSC Application
Connect your MSC Device
ERROR: !! Unsupported MSC_Device plugged !!
这是什么原因?有知道的大神指点一下。
发表于 2024-5-8 15:01:36 | 显示全部楼层
可能U盘不兼容。换个U盘试试。
也不行的话,得程序上找下问题了。
 楼主| 发表于 2024-5-8 15:43:46 | 显示全部楼层
eric2013 发表于 2024-5-8 15:01
可能U盘不兼容。换个U盘试试。
也不行的话,得程序上找下问题了。
你好,我重新用fatfs+usb_host做,程序死在if(f_open(&MyFile, "STM32.TXT", FA_CREATE_ALWAYS | FA_WRITE) != FR_OK)还是失败了。是什么原因呢?
程序如下:
if(f_mount(&USBDISKFatFs, (TCHAR const*)USBDISKPath, 0) != FR_OK)
    /* FatFs Initialization Error */
    Error_Handler();
      /* Create and Open a new text file object with write access */
              printf("444\n");
        /* 'STM32.TXT' file Open for write Error */
        Error_Handler();
        /* Write data to the text file */
        res = f_write(&MyFile, wtext, sizeof(wtext), (void *)&byteswritten);
        if((byteswritten == 0) || (res != FR_OK))
          /* 'STM32.TXT' file Write or EOF Error */
          Error_Handler();
          /* Close the open text file */
          f_close(&MyFile);
        /* Open the text file object with read access */
        if(f_open(&MyFile, "STM32.TXT", FA_READ) != FR_OK)
          /* 'STM32.TXT' file Open for read Error */
          Error_Handler();
          /* Read data from the text file */
          res = f_read(&MyFile, rtext, sizeof(rtext), (void *)&bytesread);
          if((bytesread == 0) || (res != FR_OK))
            /* 'STM32.TXT' file Read or EOF Error */
            Error_Handler();
            f_close(&MyFile);
            /* Compare read data with the expected data */
            if((bytesread != byteswritten))
              /* Read data is different from the expected data */
              Error_Handler();
发表于 2024-5-9 08:41:05 | 显示全部楼层
sun664019227 发表于 2024-5-8 15:43
你好,我重新用fatfs+usb_host做,程序死在if(f_open(&MyFile, "STM32.TXT", FA_CREATE_ALWAYS | FA_WRIT ...
枚举成功了吗,成功了看下f_open返回值多少
 楼主| 发表于 2024-5-9 09:12:54 | 显示全部楼层
fopen返回值是1
下面a的输出值为1
      if(f_open(&MyFile, "STM32.txt", FA_CREATE_ALWAYS | FA_WRITE) != FR_OK)
              uint16_t a = f_open(&MyFile, "STM32.txt", FA_CREATE_ALWAYS | FA_WRITE);
              printf("a=%d\n", a);
        Error_Handler();
 楼主| 发表于 2024-5-9 10:58:12 | 显示全部楼层
硬件设计上,不是usb线直接连接到处理器芯片的USB管脚的,而是中间加了hub芯片,这个有影响吗?hub芯片的型号是TUSB2036VFRG,这个芯片的时钟用的6m的晶振接入的。
发表于 2024-5-10 09:12:50 | 显示全部楼层
sun664019227 发表于 2024-5-9 10:58
硬件设计上,不是usb线直接连接到处理器芯片的USB管脚的,而是中间加了hub芯片,这个有影响吗?hub芯片的 ...
要直连,使用USB HUB,还需要USB HUB类的支持才行。
 楼主| 发表于 2024-5-16 07:59:37 | 显示全部楼层
直连是可以的,感谢。
发表于 2024-5-16 14:41:37 | 显示全部楼层
sun664019227 发表于 2024-5-16 07:59
直连是可以的,感谢。
好的,USB HUB有专门的类,如果要支持的话,ThreadX USBX也是支持的。
 楼主| 发表于 2024-5-17 10:56:41 | 显示全部楼层
这个应该如何移植呢?有demo参考一下吗?
还有个问题顺便咨询一下,usb插U盘,然后同时SDIO接口使用SD卡,threadx支持吗?
发表于 2024-5-18 11:53:03 | 显示全部楼层
还有个问题顺便咨询一下,usb插U盘,然后同时SDIO接口使用SD卡 ...
1、这个ThreadX没有提供Demo,之前有网友添加过,将相应的类添加,并初始化就可以使用。
2、没问题,可以挂载多个设备的。
发表于 2024-5-24 11:26:47 | 显示全部楼层
2、没问题,可 ...
用chrerryUSB试试
发表于 2025-10-20 21:35:01 | 显示全部楼层
您好,请问Ux_Host_Msc这个参考例程在哪里啊?
发表于 2025-10-20 21:35:38 | 显示全部楼层
您好请问这个Ux_Host_Msc参考例程在哪里找啊?
发表于 2025-10-21 14:34:08 | 显示全部楼层
在这里
STM32F4的ThreadX全家桶软件包升级至V1.1.0,工程案例全部使用STM32CubeMX生成
https://forum.anfulai.cn/forum.p ... 4029&fromuid=58
发表于 2025-10-21 22:50:33 | 显示全部楼层
收到硬汉哥
GMT+8, 2026-11-25 10:34 , Processed in 0.491853 second(s), 24 queries .
