查看: 3197|回复: 7
[IAR] 求一个IAR for 8051 10.30.1的版本
发表于 2024-3-17 15:28:45 | 显示全部楼层 |阅读模式
网上找了好久。没找到,官网要企业邮箱账号才能下载。
发表于 2024-3-17 18:24:19 | 显示全部楼层
一定要这么新吗
发表于 2024-3-18 08:09:37 | 显示全部楼层
帮顶。
发表于 2024-3-18 08:26:47 | 显示全部楼层
同求 EWRX 5101
发表于 2024-3-18 10:27:30 | 显示全部楼层
EW8051-10301-Autorun.zip
361.24 MB
链接:https://pan.baidu.com/s/1ikN7wFBCuOF6NvbvwuhkfA?pwd=8888
提取码:8888
发表于 2024-3-18 11:16:54 | 显示全部楼层
可以试试这个网站:downloadlynet.ir
 楼主| 发表于 2024-3-27 09:12:56 | 显示全部楼层
361.24 MB
感谢
发表于 2025-7-6 05:43:10 | 显示全部楼层
Hi,
Will it be possible to share the latest IAR Embedded Workbench for 8051 10.40.
It will be also helpful if the share is also provided other than baidu drive as sometimes it creates issue and cant be access dont know why. Thanks in advance.
GMT+8, 2026-11-24 07:43 , Processed in 0.293484 second(s), 24 queries .
