查看: 1978|回复: 3
各位大佬你们好,我想咨询一下就是我的LAN8742_Init会卡在一个循环中出不来
发表于 2024-3-15 13:17:22 | 显示全部楼层 |阅读模式
具体为:
int32_t LAN8742_Init(lan8742_Object_t *pObj)
   uint32_t tickstart = 0, regvalue = 0, addr = 0;
   int32_t status = LAN8742_STATUS_OK;
   if(pObj->Is_Initialized == 0)
     if(pObj->IO.Init != 0)
       /* GPIO and Clocks initialization */
       pObj->IO.Init();
     /* for later check */
     pObj->DevAddr = LAN8742_MAX_DEV_ADDR + 1;
     /* Get the device address from special mode register */
     for(addr = 0; addr <= LAN8742_MAX_DEV_ADDR; addr ++)
       if(pObj->IO.ReadReg(addr, LAN8742_SMR, &regvalue) < 0)
         status = LAN8742_STATUS_READ_ERROR;
         /* Can't read from this device address
            continue with next address */
         continue;
       if((regvalue & LAN8742_SMR_PHY_ADDR) == addr)
         pObj->DevAddr = addr;
     if(pObj->DevAddr > LAN8742_MAX_DEV_ADDR)
       status = LAN8742_STATUS_ADDRESS_ERROR;
     /* if device address is matched */
     if(status == LAN8742_STATUS_OK)
       /* set a software reset  */
       if(pObj->IO.WriteReg(pObj->DevAddr, LAN8742_BCR, LAN8742_BCR_SOFT_RESET) >= 0)
         /* get software reset status */
         if(pObj->IO.ReadReg(pObj->DevAddr, LAN8742_BCR, &regvalue) >= 0)
           tickstart = pObj->IO.GetTick();
           /* wait until software reset is done or timeout occured  */
           while(regvalue & LAN8742_BCR_SOFT_RESET)
             if((pObj->IO.GetTick() - tickstart) <= LAN8742_SW_RESET_TO)
               if(pObj->IO.ReadReg(pObj->DevAddr, LAN8742_BCR, &regvalue) < 0)
               status = LAN8742_STATUS_RESET_TIMEOUT;
         status = LAN8742_STATUS_WRITE_ERROR;
     /* Wait for 2s to perform initialization */
     while((pObj->IO.GetTick() - tickstart) <= LAN8742_INIT_TO)
//           tx_thread_sleep(2000);
     pObj->Is_Initialized = 1;
   return status;
会卡在  /* Wait for 2s to perform initialization */
     }这一块出不来,请各位大佬指点指点
 楼主| 发表于 2024-3-15 13:18:18 | 显示全部楼层
#include "dm9162.h"
lan8742_Object_t DM9162;
TX_THREAD *netx_thread_ptr;
static UINT  _nx_driver_hardware_initialize(NX_IP_DRIVER *driver_req_ptr)
INT PHYLinkState;
UINT duplex, speed = 0;
lan8742_IOCtx_t  DM9162_IOCtx = {ETH_PHY_IO_Init,
                               ETH_PHY_IO_DeInit,
                               ETH_PHY_IO_WriteReg,
                               ETH_PHY_IO_ReadReg,
                               ETH_PHY_IO_GetTick};
NX_PACKET           *packet_ptr;
UINT                i;
ETH_DMADescTypeDef  *DMATxDesc;
ETH_DMADescTypeDef  *DMARxDesc = nx_driver_information.nx_driver_information_dma_rx_descriptors;
    HAL_ETH_MspInit(NULL);
    /* Default to successful return.  */
    driver_req_ptr -> nx_ip_driver_status =  NX_SUCCESS;
    /* Setup indices.  */
    nx_driver_information.nx_driver_information_receive_current_index = 0;
    nx_driver_information.nx_driver_information_transmit_current_index = 0;
    nx_driver_information.nx_driver_information_transmit_release_index = 0;
    /* Clear the number of buffers in use counter.  */
    nx_driver_information.nx_driver_information_number_of_transmit_buffers_in_use = 0;
    /* Make sure there are receive packets... otherwise, return an error.  */
    if (nx_driver_information.nx_driver_information_packet_pool_ptr == NULL)
        /* There must be receive packets. If not, return an error!  */
        return(NX_DRIVER_ERROR);
    EthHandle.Instance = ETH;
    EthHandle.Init.MACAddr = _nx_driver_hardware_address;
    EthHandle.Init.AutoNegotiation = ETH_AUTONEGOTIATION_ENABLE;
    EthHandle.Init.MediaInterface = ETH_MEDIA_INTERFACE_RMII;
    EthHandle.Init.RxMode = ETH_RXINTERRUPT_MODE;
    EthHandle.Init.ChecksumMode = ETH_CHECKSUM_BY_HARDWARE;
    EthHandle.Init.PhyAddress = LAN8742_PHY_ADDR;
    printf("程序执行到这里了");
    /* Set PHY IO functions */
    LAN8742_RegisterBusIO(&DM9162, &DM9162_IOCtx);
    printf("程序meiyou执行到这里了");
    /* Initialize the DM9162 ETH PHY */
    LAN8742_Init(&DM9162);
        printf("LAN8742_Init");
    PHYLinkState = LAN8742_GetLinkState(&DM9162);
        printf("PHYLinkState = %d\r\n",PHYLinkState);
    while(PHYLinkState <= LAN8742_STATUS_LINK_DOWN)
                printf("PHYLinkStateX = %d\r\n",PHYLinkState);
        tx_thread_sleep(100);
    switch (PHYLinkState)
      case LAN8742_STATUS_100MBITS_FULLDUPLEX:
        duplex = ETH_MODE_FULLDUPLEX;
        speed = ETH_SPEED_100M;
      case LAN8742_STATUS_100MBITS_HALFDUPLEX:
        duplex = ETH_MODE_HALFDUPLEX;
      case LAN8742_STATUS_10MBITS_FULLDUPLEX:
        speed = ETH_SPEED_10M;
      case LAN8742_STATUS_10MBITS_HALFDUPLEX:
      default:
    EthHandle.Init.Speed = speed;
    EthHandle.Init.DuplexMode = duplex;
    /* Configure Ethernet peripheral (GPIOs, clocks, MAC, DMA) */
    if (HAL_ETH_Init(&EthHandle) != HAL_OK)
        /* Return error.  */
    /* Initialize TX Descriptors list: Ring Mode.  */
    /* Fill each DMATxDesc descriptor with the right values.  */
    for(i = 0; i < NX_DRIVER_TX_DESCRIPTORS; i++)
        /* Get the pointer on the ith member of the Tx Desc list.  */
        DMATxDesc = &nx_driver_information.nx_driver_information_dma_tx_descriptors[i];
#ifdef HARDWARE_CHECKSUM_ENABLE
        /* Set Second Address Chained bit and checksum offload options.  */
        DMATxDesc -> Status = ETH_DMATXDESC_TCH | ETH_DMATXDESC_IC | ETH_DMATXDESC_CIC_TCPUDPICMP_FULL | ETH_DMATXDESC_CIC_IPV4HEADER;
#else
        /* Set Second Address Chained bit.  */
        DMATxDesc -> Status = ETH_DMATXDESC_TCH | ETH_DMATXDESC_IC;
#endif
        /* Initialize the next descriptor with the Next Descriptor Polling Enable */
        if(i < (NX_DRIVER_TX_DESCRIPTORS - 1))
            /* Set next descriptor address register with next descriptor base address */
            DMATxDesc -> Buffer2NextDescAddr = (ULONG)(nx_driver_information.nx_driver_information_dma_tx_descriptors + i + 1);
            /* For last descriptor, set next descriptor address register equal to the first descriptor base address */
            DMATxDesc -> Buffer2NextDescAddr = (ULONG) nx_driver_information.nx_driver_information_dma_tx_descriptors;
    /* Set Transmit Descriptor List Address Register */
    ETH -> DMATDLAR = (ULONG) nx_driver_information.nx_driver_information_dma_tx_descriptors;
    /* Initialize RX Descriptors list: Ring Mode  */
    /* Fill each DMARxDesc descriptor with the right values */
    for(i = 0; i < NX_DRIVER_RX_DESCRIPTORS; i++)
        /* Allocate a packet for the receive buffers.  */
        if (nx_packet_allocate(nx_driver_information.nx_driver_information_packet_pool_ptr, &packet_ptr,
                               NX_RECEIVE_PACKET, NX_NO_WAIT) == NX_SUCCESS)
            /* Adjust the packet.  */
            packet_ptr -> nx_packet_prepend_ptr += 2;
            DMARxDesc[i].Buffer1Addr =          (uint32_t) packet_ptr -> nx_packet_prepend_ptr;
            DMARxDesc[i].ControlBufferSize =    ETH_DMARXDESC_RCH | (packet_ptr -> nx_packet_data_end - packet_ptr -> nx_packet_data_start);
            /* Remember the receive packet poitner.  */
            nx_driver_information.nx_driver_information_receive_packets[i] =  packet_ptr;
            /* Set Own bit of the RX descriptor Status.  */
            DMARxDesc[i].Status =  ETH_DMARXDESC_OWN;
            /* Cannot allocate packets from the packet pool. */
        /* Initialize the next descriptor with the Next Descriptor Polling Enable.  */
        if(i < (NX_DRIVER_RX_DESCRIPTORS - 1))
            /* Set next descriptor address register with next descriptor base address.  */
            DMARxDesc[i].Buffer2NextDescAddr = (ULONG)(nx_driver_information.nx_driver_information_dma_rx_descriptors + i + 1);
            /* For last descriptor, set next descriptor address register equal to the first descriptor base address.  */
            DMARxDesc[i].Buffer2NextDescAddr = (uint32_t)(nx_driver_information.nx_driver_information_dma_rx_descriptors);
    /* Save the size of one rx buffer.  */
    nx_driver_information.nx_driver_information_rx_buffer_size = packet_ptr -> nx_packet_data_end - packet_ptr -> nx_packet_data_start;
    nx_driver_information.nx_driver_information_multicast_count = 0;
    /* Set Receive Descriptor List Address Register */
    ETH -> DMARDLAR = (ULONG) nx_driver_information.nx_driver_information_dma_rx_descriptors;
    /* Return success!  */
    return(NX_SUCCESS);
头文件没动,但是LAN8742的内容全都加进去了
发表于 2024-3-16 09:36:23 | 显示全部楼层
有个重要的地方,当前硬件设计8720的复位是怎么设计的,和系统一个硬件复位还是单独的GPIO控制的。
 楼主| 发表于 2024-3-16 09:57:03 | 显示全部楼层
大哥是单独的GPIO控制的,我昨天最终找到问题了 是HAL_GetTICK()函数的问题,在等待2S的过程中,tucjstart一直没返回数值,最终发送延时函数那边[img][/img],更改后,可以直接进行硬件初始化并进行后续功能了。
GMT+8, 2026-11-25 09:41 , Processed in 0.407618 second(s), 24 queries .
