查看: 2294|回复: 2
[LwIP] STM32F746 LWIP无法PING通
发表于 2024-3-12 23:50:06 | 显示全部楼层 |阅读模式
最近用STM32F746做LWIP功能测试,用的是TCP_ECH功能,测试了官方的例程还有自己生成的CUBE工程均PING失败了。
调试的时候函数内PHYLinkState = LAN8742_GetLinkState(&LAN8742);变量PHYLinkState 的值一直是0x0002,代表100Mbit速度通讯的,状态一直都是对的。
望各位提供下思路,应该是哪里的问题
void ethernet_link_check_state(struct netif *netif)
  ETH_MACConfigTypeDef MACConf = {0};
  int32_t PHYLinkState = 0;
  uint32_t linkchanged = 0U, speed = 0U, duplex =0U;
  if(netif_is_link_up(netif) && (PHYLinkState <= LAN8742_STATUS_LINK_DOWN))
    HAL_ETH_Stop(&EthHandle);
    netif_set_down(netif);
    netif_set_link_down(netif);
  else if(!netif_is_link_up(netif) && (PHYLinkState > LAN8742_STATUS_LINK_DOWN))
    switch (PHYLinkState)
    case LAN8742_STATUS_100MBITS_FULLDUPLEX:
      duplex = ETH_FULLDUPLEX_MODE;
      speed = ETH_SPEED_100M;
      linkchanged = 1;
    case LAN8742_STATUS_100MBITS_HALFDUPLEX:
      duplex = ETH_HALFDUPLEX_MODE;
      linkchanged = 1;
    case LAN8742_STATUS_10MBITS_FULLDUPLEX:
      speed = ETH_SPEED_10M;
      linkchanged = 1;
    case LAN8742_STATUS_10MBITS_HALFDUPLEX:
      linkchanged = 1;
    default:
    if(linkchanged)
      /* Get MAC Config MAC */
      HAL_ETH_GetMACConfig(&EthHandle, &MACConf);
      MACConf.DuplexMode = duplex;
      MACConf.Speed = speed;
      HAL_ETH_SetMACConfig(&EthHandle, &MACConf);
      HAL_ETH_Start(&EthHandle);
      netif_set_up(netif);
      netif_set_link_up(netif);
MPU的配置如下,参考的官网的例程进行配置的
static void MPU_Config(void)
  MPU_Region_InitTypeDef MPU_InitStruct;
  /* Disable the MPU */
  HAL_MPU_Disable();
  /* Configure the MPU as Strongly ordered for not defined regions */
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.BaseAddress = 0x00;
  MPU_InitStruct.Size = MPU_REGION_SIZE_4GB;
  MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.SubRegionDisable = 0x87;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
  HAL_MPU_ConfigRegion(&MPU_InitStruct);
  /* Configure the MPU as Normal Non Cacheable for Ethernet Buffers in the SRAM2 */
  MPU_InitStruct.BaseAddress = 0x20048000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_16KB;
  MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
  MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER1;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1;
  MPU_InitStruct.SubRegionDisable = 0x00;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
  /* Configure the MPU as Device for Ethernet Descriptors in the SRAM2 */
  MPU_InitStruct.BaseAddress = 0x2004C000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_1KB;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER2;
  /* Configure the MPU attributes as WT for SDRAM */
  MPU_InitStruct.BaseAddress = 0xC0000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_32MB;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER3;
  /* Configure the MPU attributes FMC control registers */
  MPU_InitStruct.BaseAddress = 0xA0000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_8KB;
  MPU_InitStruct.Number = MPU_REGION_NUMBER4;
  MPU_InitStruct.SubRegionDisable = 0x0;
  /* Enable the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
发表于 2024-3-14 00:25:50 | 显示全部楼层
回帖奖励 +10 个金币
仅看楼主发的代码,看不出什么问题。
 楼主| 发表于 2024-3-15 23:34:42 | 显示全部楼层
eric2013 发表于 2024-3-14 00:25
仅看楼主发的代码,看不出什么问题。
我把我的源代码上传上来吧,感谢硬汉哥的回复。非常感谢
GMT+8, 2026-11-26 11:08 , Processed in 0.950022 second(s), 24 queries .
