查看: 2514|回复: 6
[技术讨论] 请教如何降低STM32L4的功耗
发表于 2024-3-12 13:13:58 | 显示全部楼层 |阅读模式
在测试STM32L431的stop2低功耗模式,现在运行模式功耗38mA,低功耗模式36mA,不知道为什么低功耗模式降不下去。
目前已经找到一个板载蓝色LED在耗电,压降2.68V大约耗电7mA,剩下不知道是程序的问题还是硬件的问题。
这是开发板电路图,功耗使用usb测试的,外部flash、lcd、sd卡均未接。
时钟树使用的HSI和低速晶振,未使用PLL。
下面是主要代码,使用的RTC唤醒:
int main(void)
    /* USER CODE BEGIN 1 */
    /* USER CODE END 1 */
    /* MCU Configuration--------------------------------------------------------*/
    /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
    HAL_Init();
    /* USER CODE BEGIN Init */
    /* USER CODE END Init */
    /* Configure the system clock */
    SystemClock_Config();
    /* USER CODE BEGIN SysInit */
    /* USER CODE END SysInit */
    /* Initialize all configured peripherals */
    MX_GPIO_Init();
    MX_SPI1_Init();
    MX_USART1_UART_Init();
    MX_ADC1_Init();
    MX_OPAMP1_Init();
    MX_RTC_Init();
    /* USER CODE BEGIN 2 */
    /* USER CODE END 2 */
    /* Infinite loop */
    /* USER CODE BEGIN WHILE */
    while (1)
        /* USER CODE END WHILE */
        /* USER CODE BEGIN 3 */
        printf("STOP\r\n");
        HAL_SPI_DeInit(&hspi1);
        HAL_UART_DeInit(&huart1);
        HAL_ADC_DeInit(&hadc1);
        HAL_OPAMP_DeInit(&hopamp1);
        __HAL_RCC_GPIOA_CLK_ENABLE();
        __HAL_RCC_GPIOB_CLK_ENABLE();
        __HAL_RCC_GPIOC_CLK_ENABLE();
        __HAL_RCC_GPIOH_CLK_ENABLE();
        GPIO_InitTypeDef GPIO_InitStructure = {0};
        GPIO_InitStructure.Pin = GPIO_PIN_All;
        GPIO_InitStructure.Mode = GPIO_MODE_ANALOG;
        GPIO_InitStructure.Pull = GPIO_NOPULL;
        HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
        HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
        HAL_GPIO_Init(GPIOC, &GPIO_InitStructure);
        HAL_GPIO_Init(GPIOH, &GPIO_InitStructure);
        __HAL_RCC_GPIOA_CLK_DISABLE();
        __HAL_RCC_GPIOB_CLK_DISABLE();
        __HAL_RCC_GPIOC_CLK_DISABLE();
        __HAL_RCC_GPIOH_CLK_DISABLE();
        HAL_RTCEx_DeactivateWakeUpTimer(&hrtc);
        HAL_RTCEx_SetWakeUpTimer_IT(&hrtc, 20480, RTC_WAKEUPCLOCK_RTCCLK_DIV16);
        __HAL_RCC_WAKEUPSTOP_CLK_CONFIG(RCC_STOP_WAKEUPCLOCK_MSI);
        HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI);
        MX_GPIO_Init();
        printf("WAKE UP\r\n");
        HAL_GPIO_WritePin(LED_GREEN_GPIO_Port, LED_GREEN_Pin, GPIO_PIN_RESET);
        HAL_Delay(5000);
    /* USER CODE END 3 */
 楼主| 发表于 2024-3-12 13:16:43 | 显示全部楼层
时钟的代码如下:
 * @brief System Clock Configuration
 * @retval None
void SystemClock_Config(void)
    RCC_OscInitTypeDef RCC_OscInitStruct = {0};
    RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
    /** Configure the main internal regulator output voltage
    if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE2) != HAL_OK)
        Error_Handler();
    /** Configure LSE Drive Capability
    HAL_PWR_EnableBkUpAccess();
    __HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW);
    /** Initializes the RCC Oscillators according to the specified parameters
     * in the RCC_OscInitTypeDef structure.
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI | RCC_OSCILLATORTYPE_LSE;
    RCC_OscInitStruct.LSEState = RCC_LSE_ON;
    RCC_OscInitStruct.HSIState = RCC_HSI_ON;
    RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
        Error_Handler();
    /** Initializes the CPU, AHB and APB buses clocks
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
        Error_Handler();
发表于 2024-3-13 08:36:53 | 显示全部楼层
可以试试仅焊接个主控芯片,复位和外围电阻电容,程序清空,看看功耗多少。
 楼主| 发表于 2024-3-13 12:43:30 | 显示全部楼层
找到问题了,忘了拔调试器
发表于 2024-3-14 00:33:39 | 显示全部楼层
MaxDYi 发表于 2024-3-13 12:43
找到问题了,忘了拔调试器
谢谢告知最终原因
发表于 2024-3-19 18:03:56 | 显示全部楼层
eric2013 发表于 2024-3-14 00:33
谢谢告知最终原因
大佬,为何调试模式下,会增大功耗?该关闭的外设时钟不是都是关闭的吗,接个烧录器为何会有影响?
发表于 2024-4-12 17:33:17 | 显示全部楼层
在debug模式下芯片不会正确进入低功耗模式,无法休眠,同时调试器也有耗电
GMT+8, 2026-11-22 15:41 , Processed in 1.096884 second(s), 27 queries .
