查看: 2010|回复: 3
[FreeRTOS] 关于队列先入先出的一点疑问
发表于 2024-3-12 12:22:16 | 显示全部楼层 |阅读模式
#include <stdio.h>
#include "sdkconfig.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_spi_flash.h"
#include"freertos/queue.h"
void SendTask1(void *pvParam){
    QueueHandle_t QHandle;
    QHandle = (QueueHandle_t)pvParam;
    BaseType_t xStatus;
    int i=111;
    while (1){
        xStatus = xQueueSend(QHandle, &i, 0);
        if (xStatus != pdPASS)
            printf("[Task1] Fail,Queue is FULL,Reset!.\n");
            xQueueReset(QHandle);
             printf("[Task1] Success,Have [    %d  ] Loca.\n" ,uxQueueSpacesAvailable(QHandle));
        vTaskDelay(1000 / portTICK_PERIOD_MS);
void SendTask2(void *pvParam){
    BaseType_t xStatus;
    int i=222;
    while (1){
            printf("[Task2],Queue is FULL,Reset!.\n");
            printf("[Task2] Success Have [    %d  ] Loca.\n" ,uxQueueSpacesAvailable(QHandle));
void ReceiveTask(void *pvParam){
    BaseType_t xStatus;
    int j = 0;
    while (1)
            xStatus = xQueueReceive(QHandle, &j, 0);
            if (xStatus != pdPASS){
                printf("Receive Fail.\n");
            else{
                printf("*******************************\n");
                printf("Receive Success.i = <%d>.\n", j);
                printf("队列可用消息 = %d.\n", uxQueueMessagesWaiting(QHandle));
void app_main(void)
    QHandle = xQueueCreate(5, sizeof(int));
    if (QHandle != NULL)
        printf("Creat queue Successfully.\n");
        xTaskCreate(SendTask1, "SendTask1", 1024 * 5, (void *)QHandle, 1, NULL);
        xTaskCreate(SendTask2, "SendTask2", 1024 * 5, (void *)QHandle, 1, NULL);
        xTaskCreate(ReceiveTask, "ReceiveTask", 1024 * 5, (void *)QHandle, 3, NULL);
    else{
        printf("Not Creat.\n");
/*TAsk1和TASk2公用一个队列,后创建的先运行,循环发送数据,待队列满进行重启,始终都是TASK1重启
终端显示:
[Task2] Success Have [    4  ] Loca.
[Task1] Success,Have [    3  ] Loca.
Receive Success.i = <222>.
队列可用消息 = 1.
[Task2] Success Have [    3  ] Loca.
[Task1] Success,Have [    2  ] Loca.
Receive Success.i = <111>.
队列可用消息 = 2.
[Task2] Success Have [    2  ] Loca.
[Task1] Success,Have [    1  ] Loca.
队列可用消息 = 3.
[Task2] Success Have [    1  ] Loca.
[Task1] Success,Have [    0  ] Loca.
队列可用消息 = 4.
[Task2] Success Have [    0  ] Loca.
Receive Fail.
问题描述:
两个Task往同一个队列传数据,接收函数接收到立即传出,并且接收函数优先级高于发送函数,为什么通过uxQueueSpaceAvaliable查询队列空间再减少。
FreeRTos不是接收数据后就销毁吗,如果空间不断减少,那对于大量数据的接收不是太浪费空间了吗。
初来论坛,问题描述可能不够精确,望海涵。
Queue_FIFO.txt
3.26 KB, 下载次数: 0
发表于 2024-3-13 09:08:31 | 显示全部楼层
这个打印内容是最开始的吗,如果是最开始的,那有点诡异,成了发送先执行,接收后执行了。
队列可用消息 = 1.
 楼主| 发表于 2024-3-20 11:43:45 | 显示全部楼层
前面有一条调试信息,也是发送先进行接收后进行,你说我才意识到确实诡异,后面就是循环输出信息了,硬件用的ESP32的板子,我也看了ESP32里相关FreeRtos的相关文档,确实没发现问题出在哪里
这两天没看帖子,回复晚了,不好意思
[Task1] Success,Have [    4  ] Loca.
队列可用消息 = 1.
队列可用消息 = 1.
队列可用消息 = 2.
队列可用消息 = 3.
队列可用消息 = 4.
Receive Fail.
队列可用消息 = 1.
队列可用消息 = 2.
队列可用消息 = 3.
队列可用消息 = 4.
Receive Fail.
 楼主| 发表于 2024-3-20 11:52:58 | 显示全部楼层
初学者,对一些内容的理解偏差可能比较大,还是得多多研究源码了
GMT+8, 2026-11-24 15:14 , Processed in 1.205859 second(s), 27 queries .
