查看: 1870|回复: 2
[μCOS-II] uCOS-II的AC6工程问题
发表于 2024-1-22 16:25:41 | 显示全部楼层 |阅读模式
;                                              uC/OS-III
;                                        The Real-Time Kernel
;                    Copyright 2009-2020 Silicon Laboratories Inc. www.silabs.com
;                                 SPDX-License-Identifier: APACHE-2.0
;               This software is subject to an open source license and is distributed by
;                Silicon Laboratories Inc. pursuant to the terms of the Apache License,
;                    Version 2.0 available at www.apache.org/licenses/LICENSE-2.0.
;                                          designed by eric2013
    PRESERVE8
    THUMB
    AREA CODE, CODE, READONLY
        IMPORT  OS_CPU_PendSVHandler
        IMPORT  OS_CPU_SysTickHandler
        EXPORT PendSV_Handler
PendSV_Handler
    B OS_CPU_PendSVHandler
        B .
        EXPORT SysTick_Handler
SysTick_Handler
    B OS_CPU_SysTickHandler
        B .
        END
这个是ucosiii AC5 汇编(.asm)替换pendsv和systick   想改成AC6 汇编(.s),不知如何改动,不想改启动文件
 楼主| 发表于 2024-1-22 16:31:39 | 显示全部楼层
直接改后缀好像也没有问题
发表于 2024-1-22 17:04:26 | 显示全部楼层
整理了一个,供参考
V7-uCOS-II.7z (1.41 MB, 下载次数: 15)
GMT+8, 2026-11-24 01:06 , Processed in 0.187098 second(s), 27 queries .
