查看: 2394|回复: 9
[编程语言] strncat用法請教
发表于 2023-12-18 17:07:53 | 显示全部楼层 |阅读模式
各位前輩好:
小弟從外部sensor接收資料後,整理成自己的格式並編碼成2bytes大小的char
最後需要合併到一個char變數透過UART傳送
目前遇到以下問題:strncat即便指定要合併多少byte大小字元,還是會遇到0x00就當作結束的問題
想請問這個問題是否無解,只能從memcpy去著墨?
发表于 2023-12-18 19:54:46 | 显示全部楼层
这个是libC的strncat源码,方便查找问题
https://github.com/lattera/glibc/blob/master/string/strncat.c
/* Copyright (C) 1991-2018 Free Software Foundation, Inc.
   This file is part of the GNU C Library.
   The GNU C Library is free software; you can redistribute it and/or
   modify it under the terms of the GNU Lesser General Public
   License as published by the Free Software Foundation; either
   version 2.1 of the License, or (at your option) any later version.
   The GNU C Library is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
   Lesser General Public License for more details.
   You should have received a copy of the GNU Lesser General Public
   License along with the GNU C Library; if not, see
   <[url]http://www.gnu.org/licenses/>.[/url]  */
#include <string.h>
#ifndef STRNCAT
# undef strncat
# define STRNCAT  strncat
# define STRNCAT_PRIMARY
#endif
char *
STRNCAT (char *s1, const char *s2, size_t n)
  char *s = s1;
  /* Find the end of S1.  */
  s1 += strlen (s1);
  size_t ss = __strnlen (s2, n);
  s1[ss] = '\0';
  memcpy (s1, s2, ss);
  return s;
#ifdef STRNCAT_PRIMARY
strong_alias (STRNCAT, __strncat)
libc_hidden_def (__strncat)
#endif
发表于 2023-12-19 08:30:32 | 显示全部楼层
原因很简单,char y[2]以 '\0'结尾,strlen(y) == 1,所以不会复制2个字节,实际只复制了一个字节。
发表于 2023-12-19 10:16:03 | 显示全部楼层
台湾的兄弟?要是每个传感器只有2个byte数据量的话,直接用结构体填充就把它给合并了啊。
发表于 2023-12-19 15:05:03 | 显示全部楼层
这里的0x00会被认为'\0'吗?
 楼主| 发表于 2023-12-19 17:12:36 | 显示全部楼层
2360985396 发表于 2023-12-19 15:05
这里的0x00会被认为'\0'吗?
目前看起來是這樣沒錯,所以只會複製一個byte,所以我果斷使用記憶體大法
 楼主| 发表于 2023-12-19 17:13:07 | 显示全部楼层
https://github.com/lattera/glibc/blob/master/string/strncat.c ...
謝謝管理員,我參考下
 楼主| 发表于 2023-12-19 17:13:59 | 显示全部楼层
是的,看起來Srncat即使告知他要連接多大的字串,他遇到0X00還是會停下來
 楼主| 发表于 2023-12-19 17:15:09 | 显示全部楼层
是台灣的弟兄沒錯,傳感器進來沒問題,因為經過我處理後編碼成我要的字串大小後,還要combine在一起,遇到這問題。
現在使出記憶體大法了,多虧我有用結構體
发表于 2023-12-21 10:35:54 | 显示全部楼层
raycooldes 发表于 2023-12-19 17:15
是台灣的弟兄沒錯,傳感器進來沒問題,因為經過我處理後編碼成我要的字串大小後,還要combine在一起,遇 ...
还有就是strlen是不能求数组大小的,只能求字符串 假设你现在有char buff[10] = {0}; 你觉你能用strlen(buff)这样用吗 如果这个数组没有初始化 或者数组的内容是buff[0] = 0x00, buff[1]= 0x01 或者buf[0] = 0x00,buf[1] = 0x01每次strlen 都不一样
GMT+8, 2026-10-25 09:45 , Processed in 0.320038 second(s), 27 queries .
