查看: 2703|回复: 4
[技术讨论] SEGGER Flash Loader
发表于 2023-12-13 15:29:13 | 显示全部楼层 |阅读模式
看了官网的介绍,SEGGER Flash Loader - SEGGER Wiki
General considerations
  • Get the latest version of the template project
  • Follow the Step-By-Step instructions except of 1.2 FlashPrg.c --> Functions should not contain any code that accesses any SFRs
  • Build the flash loader using the release configuration
  • Perform a flash download using J-Link Commander. Flash download should report an error during verify
  • Implement SEGGER_FL_Erase() and retry the flash download test. J-Link Commander should still report verify failed but effected flash memory region should be empty. If not, check SEGGER_FL_Erase().
  • Implement SEGGER_FL_Program() and retry the flash download test. Expected result: Test reports O.K. --> Programmed successfully. If not, check SEGGER_FL_Program() code
我找不到template project的链接,有研究过的吗?求资料
发表于 2023-12-14 08:23:03 | 显示全部楼层
帮顶。
 楼主| 发表于 2023-12-15 15:20:33 | 显示全部楼层
看来是没人了
发表于 2024-1-9 22:36:15 | 显示全部楼层
楼主研究的怎么样了?
 楼主| 发表于 2024-3-9 17:37:14 来自手机 | 显示全部楼层
yklstudent 发表于 2024-1-9 22:36
楼主研究的怎么样了?
有人在论坛上发了工程模版,把MDK实现的代码直接移植过去就可以了
GMT+8, 2026-11-22 15:36 , Processed in 0.266899 second(s), 24 queries .
