查看: 1540|回复: 1
单片机
发表于 2023-11-17 18:27:23 | 显示全部楼层 |阅读模式
void converToPrintInstruction(uint16_t decimalData[],uint8_t size)
    static uint16_t Remember_Data = 0;
    static uint8_t flag = 0;
    //static uint8_t DataSendPrintf[100] = {0};
    //uint8_t *DataSendPrintf = (uint8_t*)MemMalloc(1000*sizeof(uint8_t));
    uint16_t i = 0, j = 0, decimalValue = 0, m_g = 0;
    uint16_t buwei = 0;
    uint8_t binaryData[358] = {0};
    uint16_t position[NUMBER_DATA] = {0};
    if(size >= NUMBER_DATA)
        //printf("Error:Input data Number error.\n");
        return;
    if(flag != 0)return;
   // DataSendPrintf = (uint8_t*)MemMalloc(1000*sizeof(uint8_t));
    for(m_g = 0; m_g < size; m_g++)
        if(decimalData[m_g] < 0 || decimalData[m_g] > 4096)
            //printf("Error:Input data out of range.\n");
            return;
        for(i = 0; i < 384; i++)
            binaryData[i] = 0;
        position[m_g] = decimalData[m_g] * 384 / 4096;
        binaryData[position[m_g]] = 1;
        if(m_g >= 1)
            if(position[m_g] != position[m_g-1])
                if(position[m_g] > position[m_g-1])
                    buwei = position[m_g] - position[m_g-1];
                    for(i = 1; i <= buwei; i++)
                        binaryData[position[m_g]-i] = 1;
                    buwei = position[m_g-1] - position[m_g];
                        binaryData[position[m_g]+i] = 1;
                if(decimalData[m_g] != decimalData[m_g-1])
                   if(decimalData[m_g] > decimalData[m_g-1])
                      binaryData[position[m_g]+1] = 1;
                      binaryData[position[m_g]-1] = 1;
        //printf("1630 ");
        #if 0
        *BlueSendPrintfer.SendData = 0x16;
        BlueSendPrintfer.SendData++;
        BlueSendPrintfer.flag_num++;
        *BlueSendPrintfer.SendData = 0x30;
        #else
        BlueSendPrintfer.DataSendPrintf[Remember_Data++] = 0x16;
        BlueSendPrintfer.DataSendPrintf[Remember_Data++] = 0x30;
        #endif
        for(i = 0; i < 48; i++)
            decimalValue = 0;
            for(j = 0; j < 8; j++)
                 decimalValue += binaryData[(i * 8) + j] << (7 - j);
            //printf("%02X ",decimalValue);
            //printf("%lld ",convertDecimalToBinary(decimalValue));
            //将每一位十六进制数存储在数组中
            while(decimalValue != 0)
                int remainder = decimalValue % 16;
                if(remainder < 10)
                    BlueSendPrintfer.DataSendPrintf[Remember_Data++] = remainder + '0'; //转换成字符
                    //BlueSendPrintfer.SendData++;
                    BlueSendPrintfer.DataSendPrintf[Remember_Data++] = remainder - 10 + 'A';   //转换成大写字母
                decimalValue /= 16;
        //printf("\r\n1501\r\n");
    flag = 1;
这段函数意思是什么
 楼主| 发表于 2023-11-18 13:07:56 | 显示全部楼层
#define NUMBER_DATA 100
typedef struct{
    uint8_t *SendDataPrintfer;
    uint8_t *SendDataPrintferHeader;
    uint32_t num;
    uint8_t SendDataPrintfer_Char[2000];
}Data_Test;
Data_Test SendData;
//测试蓝牙发送数据是否为1601 ff 数据
void decimal_to_hex(uint8_t decimal_num, uint8_t *hex_num) {
    char hex_string[5]; // 足够存储 "0x" + 2 个十六进制字符 + 结束符
    sprintf(hex_string, "0x%02X", decimal_num); // 将十进制数转换为十六进制格式的字符串
    sscanf(hex_string, "%hhX", hex_num); // 将十六进制格式的字符串转换为十六进制数
    //static uint8_t flag = 0;
    static uint8_t a = 0x16, b = 0x30;
    uint16_t buwei = 0;
    static uint8_t Data_Temp = 0;
    static uint16_t binaryData[358] = {0};
        return;
    //if(flag != 0)return;
            return;
            binaryData[i] = 0;
        if(m_g >= 1)
        //printf("1630 ");
        *SendData.SendDataPrintfer = a;
        SendData.SendDataPrintfer++;
        //SendData.SendDataPrintfer_Char[Remember_Data++] = a;
        SendData.num++;
        *SendData.SendDataPrintfer = b;
        //SendData.SendDataPrintfer_Char[Remember_Data++] = b;
        SendData.num++;
            decimalValue = 0;
            decimal_to_hex(decimalValue,&Data_Temp);
            *SendData.SendDataPrintfer = Data_Temp;
            //SendData.SendDataPrintfer_Char[Remember_Data++] = Data_Temp;
            SendData.num++;
    //flag = 1;
int main() {
    uint32_t i = 0;
    memset(&SendData,0,sizeof(SendData));
    SendData.SendDataPrintfer = (uint8_t *)malloc((sizeof(uint8_t))*1000);
    SendData.SendDataPrintferHeader = SendData.SendDataPrintfer;
    uint16_t decimal_num[4] = {2048};
    converToPrintInstruction(decimal_num,1);
    for(i = 0; i < SendData.num; i++)
        printf("%x ",*SendData.SendDataPrintferHeader);
         //printf("%x\n",SendData.SendDataPrintfer_Char[i]);
        SendData.SendDataPrintferHeader++;
    return 0;
这是改进之后的
GMT+8, 2026-11-24 06:12 , Processed in 1.217702 second(s), 22 queries .
