查看: 1860|回复: 4
[有问必答] 32定时器溢出时,定时器的值不应该是65535或0这类的临界值吗?为什么是随机值?(附代码)
发表于 2023-11-8 15:10:09 | 显示全部楼层 |阅读模式
uint32_t timer_ov;
void gpio_config(void)
    rcu_periph_clock_enable(RCU_GPIOA);
    gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
void timer2_config(void)
    timer_ic_parameter_struct timer_icinitpara;
    timer_parameter_struct timer_initpara;
    rcu_periph_clock_enable(RCU_TIMER2);
    timer_deinit(TIMER2);
    /* TIMER0 configuration */
    timer_initpara.prescaler         = 120-1;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 65535;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER2,&timer_initpara);
    timer_icinitpara.icpolarity = TIMER_IC_POLARITY_RISING;
    timer_icinitpara.icselection = TIMER_IC_SELECTION_DIRECTTI;
    timer_icinitpara.icprescaler = TIMER_IC_PSC_DIV1;
    timer_icinitpara.icfilter = 0;
    timer_interrupt_flag_clear(TIMER2,TIMER_INT_FLAG_UP|TIMER_INT_FLAG_CH0);
    timer_input_capture_config(TIMER2,TIMER_CH_0,&timer_icinitpara);
    timer_interrupt_enable(TIMER2,TIMER_INT_UP|TIMER_INT_CH0);
    nvic_irq_enable(TIMER2_IRQn, 13,0);
    /* auto-reload preload enable */
    timer_auto_reload_shadow_enable(TIMER2);
    timer_enable(TIMER2);
int main(void)
    /* configure the TIMER peripheral */
    timer2_config();
    /* configure systick */
    systick_config();
    gd_eval_com_init(EVAL_COM1);
    printf("Start\r\n");
    while (1)
        printf("timer_ov = %lu\r\n", timer_ov);
        delay_1ms(100);
void TIMER2_IRQHandler(void)
    if(timer_interrupt_flag_get(TIMER2,TIMER_INT_FLAG_UP)==SET)
        timer_ov = timer_channel_capture_value_register_read(TIMER2,TIMER_CH_0);
        timer_interrupt_flag_clear(TIMER2,TIMER_INT_FLAG_UP);
发表于 2023-11-8 22:21:55 | 显示全部楼层
你把你定时器2通道0的引脚拉低或者拉高固定到一个稳定的电平再看就是临界值了
 楼主| 发表于 2023-11-9 00:55:25 | 显示全部楼层
请问这个和引脚电平的高低有什么关系吗,求解答
发表于 2023-11-30 16:05:24 | 显示全部楼层
假设单片机定时器计数频率是120M, 120分频后, 计数频率是1M,也就是1us计数加1. 中断相应到中断处理,再读取定时器的值不一定就是0了,如果还牵涉到中断嵌套或开关中断操作就更加不准确了
发表于 2023-12-29 05:30:33 | 显示全部楼层
这里你 timer_ov 的值是通道0捕获的值,你通道0的引脚设置成浮空之后鬼知道什么时候被判定是高还是低,所以 timer_ov 的值不是0或65535
GMT+8, 2026-11-22 15:47 , Processed in 1.303835 second(s), 23 queries .
