查看: 1614|回复: 2
[ThreadX全家桶] GUIX任意窗口跳转
发表于 2023-10-26 14:27:30 | 显示全部楼层 |阅读模式
void jump_to_window(GX_WIDGET *target)
    GX_ANIMATION *animation;
    GX_ANIMATION_INFO info;
    /* Allocate an animaton control from system pool. */
    if(gx_system_animation_get(&animation) == GX_SUCCESS)
        memset(&info, 0, sizeof(GX_ANIMATION_INFO));
        info.gx_animation_style = GX_ANIMATION_TRANSLATE;
        info.gx_animation_id = 0;
        info.gx_animation_parent = (GX_WIDGET *)root;
        info.gx_animation_target = target;
        info.gx_animation_start_alpha = 255;
        info.gx_animation_end_alpha = 255;
        info.gx_animation_steps = 10;
        info.gx_animation_frame_interval = 1;
        info.gx_animation_start_position.gx_point_x = 0;
        info.gx_animation_start_position.gx_point_y = 0;
        info.gx_animation_end_position.gx_point_x = 0;
        info.gx_animation_end_position.gx_point_y = 0;
        gx_animation_start(animation, &info);
方便一些非UI事件触发的页面跳转,就是手动创建个跳转动画直接执行
参与人数 1金币 +50 收起 理由
eric2013 + 50 很给力!
发表于 2023-10-26 15:17:55 | 显示全部楼层
谢谢楼主分享。
发表于 2023-10-31 08:43:29 | 显示全部楼层
楼主牛劈喔
GMT+8, 2026-11-24 00:53 , Processed in 0.462806 second(s), 25 queries .
