查看: 2913|回复: 2
STM32F4使用HAL库双CAN通信出现错误Wait initialisation acknowledge解决办法
发表于 2023-10-24 08:29:50 | 显示全部楼层 |阅读模式
准备给V5和V6板子板载的双CAN移植CANopen协议栈,发现板载的CAN1和CAN2连接后,CAN的初始化都过不去,直接卡死在这个里面了:
  /* Request initialisation */
  SET_BIT(hcan->Instance->MCR, CAN_MCR_INRQ);
  /* Get tick */
  tickstart = HAL_GetTick();
  /* Wait initialisation acknowledge */
  while ((hcan->Instance->MSR & CAN_MSR_INAK) == 0U)
    if ((HAL_GetTick() - tickstart) > CAN_TIMEOUT_VALUE)
      /* Update error code */
      hcan->ErrorCode |= HAL_CAN_ERROR_TIMEOUT;
      /* Change CAN state */
      hcan->State = HAL_CAN_STATE_ERROR;
      return HAL_ERROR;
经过不断测试,发现要提前将CAN1和CAN2的引脚状态配置好才可以正常初始化:
*	函 数 名: HAL_CAN_MspInit
*	功能说明: 配置CAN gpio
*	形    参: hcan
*	返 回 值: 无
void HAL_CAN_MspInit(CAN_HandleTypeDef *hcan)
	GPIO_InitTypeDef   GPIO_InitStruct;
	/*##-1- Enable peripherals and GPIO Clocks #################################*/
	/* CAN1 Periph clock enable */
	__HAL_RCC_CAN1_CLK_ENABLE();
	__HAL_RCC_CAN2_CLK_ENABLE();
	/* Enable GPIO clock ****************************************/
	CAN1_TX_GPIO_CLK_ENABLE();
	CAN1_RX_GPIO_CLK_ENABLE();
	/*##-2- Configure peripheral GPIO ##########################################*/
	/* CAN1 TX GPIO pin configuration */
	GPIO_InitStruct.Pin = CAN1_TX_PIN;
	GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
	GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
	GPIO_InitStruct.Pull = GPIO_PULLUP;
	GPIO_InitStruct.Alternate =  CAN1_TX_AF;
	HAL_GPIO_Init(CAN1_TX_GPIO_PORT, &GPIO_InitStruct);
	/* CAN1 RX GPIO pin configuration */
	GPIO_InitStruct.Pin = CAN1_RX_PIN;
	GPIO_InitStruct.Alternate =  CAN1_RX_AF;
	HAL_GPIO_Init(CAN1_RX_GPIO_PORT, &GPIO_InitStruct);
	/*##-3- Configure the NVIC #################################################*/
	/* NVIC configuration for CAN1 Reception complete interrupt */
	HAL_NVIC_SetPriority(CAN1_RX0_IRQn, 1, 0);
	HAL_NVIC_EnableIRQ(CAN1_RX0_IRQn);
	HAL_NVIC_SetPriority(CAN1_TX_IRQn, 1, 0);
	HAL_NVIC_EnableIRQ(CAN1_TX_IRQn);
	CAN2_TX_GPIO_CLK_ENABLE();
	CAN2_RX_GPIO_CLK_ENABLE();
	GPIO_InitStruct.Pin = CAN2_TX_PIN;
	GPIO_InitStruct.Alternate =  CAN2_TX_AF;
	HAL_GPIO_Init(CAN2_TX_GPIO_PORT, &GPIO_InitStruct);
	GPIO_InitStruct.Pin = CAN2_RX_PIN;
	GPIO_InitStruct.Alternate =  CAN2_RX_AF;
	HAL_GPIO_Init(CAN2_RX_GPIO_PORT, &GPIO_InitStruct);
	HAL_NVIC_SetPriority(CAN2_RX1_IRQn, 1, 0);
	HAL_NVIC_EnableIRQ(CAN2_RX1_IRQn);
	HAL_NVIC_SetPriority(CAN2_TX_IRQn, 1, 0);
	HAL_NVIC_EnableIRQ(CAN2_TX_IRQn);
发表于 2025-1-9 12:03:09 | 显示全部楼层
遇到了类似的这个问题,在初始化过程中调用HAL_CAN_Start()进入Error_Handler(),将引脚设置为上拉模式后就可以正常初始化,有时候可能会忽略这个小问题
 楼主| 发表于 2025-1-10 07:45:04 | 显示全部楼层
renjiaqi12138 发表于 2025-1-9 12:03
遇到了类似的这个问题,在初始化过程中调用HAL_CAN_Start()进入Error_Handler(),将引脚设置为上拉模式后就 ...
这个问题防不胜防,还以为CAN配置有问题。
GMT+8, 2026-10-25 09:49 , Processed in 0.242276 second(s), 24 queries .
