查看: 4854|回复: 0
[客户分享] ST新推出的一个大功率步进电机驱动板,有需要的可以看看
发表于 2015-8-5 18:04:23 | 显示全部楼层 |阅读模式
板子效果:
板子主要特性:
    [li]Power system-in-package, integrated dual full-bridge with low RDS(on)[/li][li]Voltage range from 10.5 V to 85 V[/li][li]Phase current up to 10 A rms[/li][li]Power OK and fault LEDs[/li][li]Up to 1/128 micro-stepping[/li][li]Programmable speed profile and overcurrent protection[/li][li]Sensorless stall detection[/li][li]Adjustable output slew rate[/li][li]Overtemperature protection[/li][li]Compatible with Arduino UNO R3 connector[/li][li]Compatible with STM32 Nucleo boards[/li][li]Suitable for multi-motor solution[/li][li]RoHS compliant[/li]
资料下载:链接
GMT+8, 2026-11-28 13:26 , Processed in 0.864637 second(s), 27 queries .
