查看: 3572|回复: 4
[CAN/FDCAN] CANopenNode的配置项是真的多,不过代码注释是真的详细
发表于 2023-9-7 09:08:05 | 显示全部楼层 |阅读模式
CANopenNode的源码还是值得学习下:
 * Configuration macros for CANopenNode.
 * @file        CO_config.h
 * @ingroup     CO_STACK_CONFIG
 * @author      Janez Paternoster
 * @copyright   2020 Janez Paternoster
 * This file is part of CANopenNode, an opensource CANopen Stack.
 * Project home page is <[url]https://github.com/CANopenNode/CANopenNode>.[/url]
 * For more information on CANopen see <[url]http://www.can-cia.org/>.[/url]
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     [url]http://www.apache.org/licenses/LICENSE-2.0[/url]
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#ifndef CO_CONFIG_FLAGS_H
#define CO_CONFIG_FLAGS_H
#ifdef __cplusplus
extern "C" {
#endif
 * @defgroup CO_STACK_CONFIG Stack configuration
 * Stack configuration and enabling macros.
 * @ingroup CO_driver
 * Default values for stack configuration macros are set in corresponding
 * header files. The same default values are also provided in this file, but
 * only for documentation generator. Default values can be overridden by
 * CO_driver_target.h file. If specified so, they can further be overridden by
 * CO_driver_custom.h file.
 * Stack configuration macro is specified as bits, where each bit
 * enables/disables some part of the configurable CANopenNode object. Flags are
 * used for enabling or checking specific bit. Multiple flags can be ORed
 * together.
 * Some functionalities of CANopenNode objects, enabled by configuration macros,
 * requires some objects from Object Dictionary to exist. Object Dictionary
 * configuration must match @ref CO_STACK_CONFIG.
 * @defgroup CO_STACK_CONFIG_COMMON Common definitions
 * Constants for common definitions.
 * Enable custom callback after CAN receive
 * Flag enables optional callback functions, which are part of some CANopenNode
 * objects. Callbacks can optionally be registered by application, which
 * configures threads in operating system. Callbacks are called after something
 * has been preprocessed by higher priority thread and must be further
 * processed by lower priority thread. For example when CAN message is received
 * and preprocessed, callback should wake up mainline processing function.
 * See also @ref CO_process() function.
 * If callback functions are used, they must be initialized separately, after
 * the object initialization.
 * This flag is common to multiple configuration macros.
#define CO_CONFIG_FLAG_CALLBACK_PRE 0x1000
 * Enable calculation of timerNext_us variable.
 * Calculation of the timerNext_us variable is useful for smooth operation on
 * operating system. See also @ref CO_process() function.
#define CO_CONFIG_FLAG_TIMERNEXT 0x2000
 * Enable dynamic behaviour of Object Dictionary variables
 * Some CANopen objects uses Object Dictionary variables as arguments to
 * initialization functions, which are processed in communication reset section.
 * If this flag is set, then writing to OD variable will reconfigure
 * corresponding CANopen object also during CANopen normal operation.
#define CO_CONFIG_FLAG_OD_DYNAMIC 0x4000
/** This flag may be set globally for mainline objects to
 * @ref CO_CONFIG_FLAG_CALLBACK_PRE */
#ifdef CO_DOXYGEN
#define CO_CONFIG_GLOBAL_FLAG_CALLBACK_PRE (0)
#endif
/** This flag may be set globally for Real-Time objects (SYNC, PDO) to
#ifdef CO_DOXYGEN
#define CO_CONFIG_GLOBAL_RT_FLAG_CALLBACK_PRE (0)
#endif
/** This flag may be set globally to @ref CO_CONFIG_FLAG_TIMERNEXT */
#ifdef CO_DOXYGEN
#define CO_CONFIG_GLOBAL_FLAG_TIMERNEXT (0)
#endif
/** This flag may be set globally to (0) */
#ifdef CO_DOXYGEN
#define CO_CONFIG_GLOBAL_FLAG_OD_DYNAMIC CO_CONFIG_FLAG_OD_DYNAMIC
#endif
/** @} */ /* CO_STACK_CONFIG_COMMON */
 * @defgroup CO_STACK_CONFIG_NMT_HB NMT master/slave and HB producer/consumer
 * Specified in standard CiA 301
 * Configuration of @ref CO_NMT_Heartbeat.
 * Possible flags, can be ORed:
 * - CO_CONFIG_NMT_CALLBACK_CHANGE - Enable custom callback after NMT
 *   state changes. Callback is configured by
 *   CO_NMT_initCallbackChanged().
 * - CO_CONFIG_NMT_MASTER - Enable simple NMT master
 * - #CO_CONFIG_FLAG_CALLBACK_PRE - Enable custom callback after preprocessing
 *   received NMT CAN message.
 *   Callback is configured by CO_NMT_initCallbackPre().
 * - #CO_CONFIG_FLAG_TIMERNEXT - Enable calculation of timerNext_us variable
 *   inside CO_NMT_process().
#ifdef CO_DOXYGEN
#define CO_CONFIG_NMT (CO_CONFIG_GLOBAL_FLAG_CALLBACK_PRE | CO_CONFIG_GLOBAL_FLAG_TIMERNEXT)
#endif
#define CO_CONFIG_NMT_CALLBACK_CHANGE 0x01
#define CO_CONFIG_NMT_MASTER 0x02
 * Configuration of @ref CO_HBconsumer
 * - CO_CONFIG_HB_CONS_ENABLE - Enable heartbeat consumer.
 * - CO_CONFIG_HB_CONS_CALLBACK_CHANGE - Enable custom common callback after NMT
 *   state of the monitored node changes. Callback is configured by
 *   CO_HBconsumer_initCallbackNmtChanged().
 * - CO_CONFIG_HB_CONS_CALLBACK_MULTI - Enable multiple custom callbacks, which
 *   can be configured individually for each monitored node. Callbacks are
 *   configured by CO_HBconsumer_initCallbackNmtChanged(),
 *   CO_HBconsumer_initCallbackHeartbeatStarted(),
 *   CO_HBconsumer_initCallbackTimeout() and
 *   CO_HBconsumer_initCallbackRemoteReset() functions.
 * - CO_CONFIG_HB_CONS_QUERY_FUNCT - Enable functions for query HB state or
 *   NMT state of the specific monitored node.
 *   received heartbeat CAN message.
 *   Callback is configured by CO_HBconsumer_initCallbackPre().
 *   inside CO_HBconsumer_process().
 * - #CO_CONFIG_FLAG_OD_DYNAMIC - Enable dynamic configuration of monitored
 *   nodes (Writing to object 0x1016 re-configures the monitored nodes).
 * @warning CO_CONFIG_HB_CONS_CALLBACK_CHANGE and
 * CO_CONFIG_HB_CONS_CALLBACK_MULTI cannot be set simultaneously.
#ifdef CO_DOXYGEN
#define CO_CONFIG_HB_CONS (CO_CONFIG_HB_CONS_ENABLE | CO_CONFIG_GLOBAL_FLAG_CALLBACK_PRE | CO_CONFIG_GLOBAL_FLAG_TIMERNEXT | CO_CONFIG_GLOBAL_FLAG_OD_DYNAMIC)
#endif
#define CO_CONFIG_HB_CONS_ENABLE 0x01
#define CO_CONFIG_HB_CONS_CALLBACK_CHANGE 0x02
#define CO_CONFIG_HB_CONS_CALLBACK_MULTI 0x04
#define CO_CONFIG_HB_CONS_QUERY_FUNCT 0x08
/** @} */ /* CO_STACK_CONFIG_NMT_HB */
 * @defgroup CO_STACK_CONFIG_EMERGENCY Emergency producer/consumer
 * Configuration of @ref CO_Emergency
 * - CO_CONFIG_EM_PRODUCER - Enable emergency producer.
 * - CO_CONFIG_EM_PROD_CONFIGURABLE - Emergency producer COB-ID is configurable,
 *   OD object 0x1014. If not configurable, then 0x1014 is read-only, COB_ID
 *   is set to CO_CAN_ID_EMERGENCY + nodeId and write is not verified.
 * - CO_CONFIG_EM_PROD_INHIBIT - Enable inhibit timer on emergency producer,
 *   OD object 0x1015.
 * - CO_CONFIG_EM_HISTORY - Enable error history, OD object 0x1003,
 *   "Pre-defined error field"
 * - CO_CONFIG_EM_CONSUMER - Enable simple emergency consumer with callback.
 * - CO_CONFIG_EM_STATUS_BITS - Access @ref CO_EM_errorStatusBits_t from OD.
 *   emergency condition by CO_errorReport() or CO_errorReset() call.
 *   Callback is configured by CO_EM_initCallbackPre().
 *   inside CO_EM_process().
#ifdef CO_DOXYGEN
#define CO_CONFIG_EM (CO_CONFIG_EM_PRODUCER | CO_CONFIG_EM_HISTORY | CO_CONFIG_GLOBAL_FLAG_CALLBACK_PRE | CO_CONFIG_GLOBAL_FLAG_TIMERNEXT)
#endif
#define CO_CONFIG_EM_PRODUCER 0x01
#define CO_CONFIG_EM_PROD_CONFIGURABLE 0x02
#define CO_CONFIG_EM_PROD_INHIBIT 0x04
#define CO_CONFIG_EM_HISTORY 0x08
#define CO_CONFIG_EM_STATUS_BITS 0x10
#define CO_CONFIG_EM_CONSUMER 0x20
 * Maximum number of @ref CO_EM_errorStatusBits_t
 * Stack uses 6*8 = 48 @ref CO_EM_errorStatusBits_t, others are free to use by
 * manufacturer. Allowable value range is from 48 to 256 bits in steps of 8.
 * Default is 80.
#ifdef CO_DOXYGEN
#define CO_CONFIG_EM_ERR_STATUS_BITS_COUNT (10*8)
#endif
 * Condition for calculating CANopen Error register, "generic" error bit.
 * Condition must observe suitable @ref CO_EM_errorStatusBits_t and use
 * corresponding member of errorStatusBits array from CO_EM_t to calculate the
 * condition. See also @ref CO_errorRegister_t.
 * @warning Size of @ref CO_CONFIG_EM_ERR_STATUS_BITS_COUNT must be large
 * enough. (CO_CONFIG_EM_ERR_STATUS_BITS_COUNT/8) must be larger than index of
 * array member in em->errorStatusBits[index].
 * em->errorStatusBits[5] should be included in the condition, because they are
 * used by the stack.
#ifdef CO_DOXYGEN
#define CO_CONFIG_ERR_CONDITION_GENERIC (em->errorStatusBits[5] != 0)
#endif
 * Condition for calculating CANopen Error register, "current" error bit.
 * See @ref CO_CONFIG_ERR_CONDITION_GENERIC for description.
 * Macro is not defined by default, so no error is verified.
#ifdef CO_DOXYGEN
#define CO_CONFIG_ERR_CONDITION_CURRENT
#endif
 * Condition for calculating CANopen Error register, "voltage" error bit.
#ifdef CO_DOXYGEN
#define CO_CONFIG_ERR_CONDITION_VOLTAGE
#endif
 * Condition for calculating CANopen Error register, "temperature" error bit.
#ifdef CO_DOXYGEN
#define CO_CONFIG_ERR_CONDITION_TEMPERATURE
#endif
 * Condition for calculating CANopen Error register, "communication" error bit.
 * em->errorStatusBits[2] and em->errorStatusBits[3] must be included in the
 * condition, because they are used by the stack.
#ifdef CO_DOXYGEN
#define CO_CONFIG_ERR_CONDITION_COMMUNICATION (em->errorStatusBits[2] || em->errorStatusBits[3])
#endif
 * Condition for calculating CANopen Error register, "device profile" error bit.
#ifdef CO_DOXYGEN
#define CO_CONFIG_ERR_CONDITION_DEV_PROFILE
#endif
 * Condition for calculating CANopen Error register, "manufacturer" error bit.
 * em->errorStatusBits[8] and em->errorStatusBits[8] are pre-defined, but can
 * be changed.
#ifdef CO_DOXYGEN
#define CO_CONFIG_ERR_CONDITION_MANUFACTURER (em->errorStatusBits[8] || em->errorStatusBits[9])
#endif
/** @} */ /* CO_STACK_CONFIG_EMERGENCY */
 * @defgroup CO_STACK_CONFIG_SDO SDO server/client
 * Configuration of @ref CO_SDOserver
 * - CO_CONFIG_SDO_SRV_SEGMENTED - Enable SDO server segmented transfer.
 * - CO_CONFIG_SDO_SRV_BLOCK - Enable SDO server block transfer. If set, then
 *   CO_CONFIG_SDO_SRV_SEGMENTED must also be set.
 *   received SDO CAN message.
 *   Callback is configured by CO_SDOserver_initCallbackPre().
 *   inside CO_SDOserver_process().
 * - #CO_CONFIG_FLAG_OD_DYNAMIC - Enable dynamic configuration of additional SDO
 *   servers (Writing to object 0x1201+ re-configures the additional server).
#ifdef CO_DOXYGEN
#define CO_CONFIG_SDO_SRV (CO_CONFIG_SDO_SRV_SEGMENTED | CO_CONFIG_GLOBAL_FLAG_CALLBACK_PRE | CO_CONFIG_GLOBAL_FLAG_TIMERNEXT | CO_CONFIG_GLOBAL_FLAG_OD_DYNAMIC)
#endif
#define CO_CONFIG_SDO_SRV_SEGMENTED 0x02
#define CO_CONFIG_SDO_SRV_BLOCK 0x04
 * Size of the internal data buffer for the SDO server.
 * If size is less than size of some variables in Object Dictionary, then data
 * will be transferred to internal buffer in several segments. Minimum size is
 * 8 or 899 (127*7) for block transfer.
#ifdef CO_DOXYGEN
#define CO_CONFIG_SDO_SRV_BUFFER_SIZE 32
#endif
 * Configuration of @ref CO_SDOclient
 * - CO_CONFIG_SDO_CLI_ENABLE - Enable SDO client.
 * - CO_CONFIG_SDO_CLI_SEGMENTED - Enable SDO client segmented transfer.
 * - CO_CONFIG_SDO_CLI_BLOCK - Enable SDO client block transfer. If set, then
 *   CO_CONFIG_SDO_CLI_SEGMENTED, CO_CONFIG_FIFO_ALT_READ and
 *   CO_CONFIG_FIFO_CRC16_CCITT must also be set.
 * - CO_CONFIG_SDO_CLI_LOCAL - Enable local transfer, if Node-ID of the SDO
 *   server is the same as node-ID of the SDO client. (SDO client is the same
 *   device as SDO server.) Transfer data directly without communication on CAN.
 *   Callback is configured by CO_SDOclient_initCallbackPre().
 *   inside CO_SDOclientDownloadInitiate(), CO_SDOclientDownload(),
 *   CO_SDOclientUploadInitiate(), CO_SDOclientUpload().
 * - #CO_CONFIG_FLAG_OD_DYNAMIC - Enable dynamic configuration of SDO clients
 *   (Writing to object 0x1280+ re-configures the client).
#ifdef CO_DOXYGEN
#define CO_CONFIG_SDO_CLI (0)
#endif
#define CO_CONFIG_SDO_CLI_ENABLE 0x01
#define CO_CONFIG_SDO_CLI_SEGMENTED 0x02
#define CO_CONFIG_SDO_CLI_BLOCK 0x04
#define CO_CONFIG_SDO_CLI_LOCAL 0x08
 * Size of the internal data buffer for the SDO client.
 * Circular buffer is used for SDO communication. It can be read or written
 * between successive SDO calls. So size of the buffer can be lower than size of
 * the actual size of data transferred. If only segmented transfer is used, then
 * buffer size can be as low as 7 bytes, if data are read/written each cycle. If
 * block transfer is used, buffer size should be set to at least 1000 bytes, so
 * maximum blksize can be used (blksize is calculated from free buffer space).
 * Default value for block transfer is 1000, otherwise 32.
#ifdef CO_DOXYGEN
#define CO_CONFIG_SDO_CLI_BUFFER_SIZE 32
#endif
/** @} */ /* CO_STACK_CONFIG_SDO */
 * @defgroup CO_STACK_CONFIG_TIME Time producer/consumer
 * Configuration of @ref CO_TIME
 * - CO_CONFIG_TIME_ENABLE - Enable TIME object and TIME consumer.
 * - CO_CONFIG_TIME_PRODUCER - Enable TIME producer.
 *   received TIME CAN message.
 *   Callback is configured by CO_TIME_initCallbackPre().
 * - #CO_CONFIG_FLAG_OD_DYNAMIC - Enable dynamic configuration - writing to
 *   object 0x1012 enables / disables time producer or consumer.
#ifdef CO_DOXYGEN
#define CO_CONFIG_TIME (CO_CONFIG_TIME_ENABLE | CO_CONFIG_GLOBAL_FLAG_CALLBACK_PRE | CO_CONFIG_GLOBAL_FLAG_OD_DYNAMIC)
#endif
#define CO_CONFIG_TIME_ENABLE 0x01
#define CO_CONFIG_TIME_PRODUCER 0x02
/** @} */ /* CO_STACK_CONFIG_TIME */
 * @defgroup CO_STACK_CONFIG_SYNC_PDO SYNC and PDO producer/consumer
 * Configuration of @ref CO_SYNC
 * - CO_CONFIG_SYNC_ENABLE - Enable SYNC object and SYNC consumer.
 * - CO_CONFIG_SYNC_PRODUCER - Enable SYNC producer.
 *   received SYNC CAN message.
 *   Callback is configured by CO_SYNC_initCallbackPre().
 *   inside CO_SYNC_process().
 * - #CO_CONFIG_FLAG_OD_DYNAMIC - Enable dynamic configuration of SYNC.
#ifdef CO_DOXYGEN
#define CO_CONFIG_SYNC (CO_CONFIG_SYNC_ENABLE | CO_CONFIG_SYNC_PRODUCER | CO_CONFIG_GLOBAL_RT_FLAG_CALLBACK_PRE | CO_CONFIG_GLOBAL_FLAG_TIMERNEXT | CO_CONFIG_GLOBAL_FLAG_OD_DYNAMIC)
#endif
#define CO_CONFIG_SYNC_ENABLE 0x01
#define CO_CONFIG_SYNC_PRODUCER 0x02
 * Configuration of @ref CO_PDO
 * - CO_CONFIG_RPDO_ENABLE - Enable receive PDO objects.
 * - CO_CONFIG_TPDO_ENABLE - Enable transmit PDO objects.
 * - CO_CONFIG_RPDO_TIMERS_ENABLE - Enable RPDO timers: RPDO timeout monitoring
 *   with event timer.
 * - CO_CONFIG_TPDO_TIMERS_ENABLE - Enable TPDO timers: TPDO inhibit and event
 *   timers.
 * - CO_CONFIG_PDO_SYNC_ENABLE - Enable SYNC in PDO objects.
 * - CO_CONFIG_PDO_OD_IO_ACCESS - For OD variables mapped to PDO use read/write
 *   function access with @ref OD_IO_t. This option enables much more
 *   flexibility for application program, but consumes some additional memory
 *   and processor resources. If this option is not enabled, then data from OD
 *   variables are fetched directly from memory allocated by Object dictionary.
 *   received RPDO CAN message.
 *   Callback is configured by CO_RPDO_initCallbackPre().
 *   inside CO_TPDO_process().
 * - #CO_CONFIG_FLAG_OD_DYNAMIC - Enable dynamic configuration of PDO.
#ifdef CO_DOXYGEN
#define CO_CONFIG_PDO (CO_CONFIG_RPDO_ENABLE | CO_CONFIG_TPDO_ENABLE | CO_CONFIG_RPDO_TIMERS_ENABLE | CO_CONFIG_TPDO_TIMERS_ENABLE | CO_CONFIG_PDO_SYNC_ENABLE | CO_CONFIG_PDO_OD_IO_ACCESS | CO_CONFIG_GLOBAL_RT_FLAG_CALLBACK_PRE | CO_CONFIG_GLOBAL_FLAG_TIMERNEXT | CO_CONFIG_GLOBAL_FLAG_OD_DYNAMIC)
#endif
#define CO_CONFIG_RPDO_ENABLE 0x01
#define CO_CONFIG_TPDO_ENABLE 0x02
#define CO_CONFIG_RPDO_TIMERS_ENABLE 0x04
#define CO_CONFIG_TPDO_TIMERS_ENABLE 0x08
#define CO_CONFIG_PDO_SYNC_ENABLE 0x10
#define CO_CONFIG_PDO_OD_IO_ACCESS 0x20
/** @} */ /* CO_STACK_CONFIG_SYNC_PDO */
 * @defgroup CO_STACK_CONFIG_STORAGE Data storage
 * Data storage with CANopen OD objects 1010 and 1011, CiA 301
 * Configuration of @ref CO_storage
 * - CO_CONFIG_STORAGE_ENABLE - Enable data storage
#ifdef CO_DOXYGEN
#define CO_CONFIG_STORAGE (CO_CONFIG_STORAGE_ENABLE)
#endif
#define CO_CONFIG_STORAGE_ENABLE 0x01
/** @} */ /* CO_STACK_CONFIG_STORAGE */
 * @defgroup CO_STACK_CONFIG_LEDS CANopen LED diodes
 * Specified in standard CiA 303-3
 * Configuration of @ref CO_LEDs
 * - CO_CONFIG_LEDS_ENABLE - Enable calculation of the CANopen LED indicators.
#ifdef CO_DOXYGEN
#define CO_CONFIG_LEDS (CO_CONFIG_LEDS_ENABLE | CO_CONFIG_GLOBAL_FLAG_TIMERNEXT)
#endif
#define CO_CONFIG_LEDS_ENABLE 0x01
/** @} */ /* CO_STACK_CONFIG_LEDS */
 * @defgroup CO_STACK_CONFIG_SRDO Safety Related Data Objects (SRDO)
 * Specified in standard EN 50325-5 (CiA 304)
 * Configuration of @ref CO_GFC
 * - CO_CONFIG_GFC_ENABLE - Enable the GFC object
 * - CO_CONFIG_GFC_CONSUMER - Enable the GFC consumer
 * - CO_CONFIG_GFC_PRODUCER - Enable the GFC producer
#ifdef CO_DOXYGEN
#define CO_CONFIG_GFC (0)
#endif
#define CO_CONFIG_GFC_ENABLE 0x01
#define CO_CONFIG_GFC_CONSUMER 0x02
#define CO_CONFIG_GFC_PRODUCER 0x04
 * Configuration of @ref CO_SRDO
 * - CO_CONFIG_SRDO_ENABLE - Enable the SRDO object.
 * - CO_CONFIG_SRDO_CHECK_TX - Enable checking data before sending.
 * - CO_CONFIG_RSRDO_CALLS_EXTENSION - Enable calling configured extension
 *   callbacks when received RSRDO CAN message modifies OD entries.
 * - CO_CONFIG_TRSRDO_CALLS_EXTENSION - Enable calling configured extension
 *   callbacks before TSRDO CAN message is sent.
 *   received RSRDO CAN message.
 *   Callback is configured by CO_SRDO_initCallbackPre().
 *   inside CO_SRDO_process() (Tx SRDO only).
#ifdef CO_DOXYGEN
#define CO_CONFIG_SRDO (0)
#endif
#define CO_CONFIG_SRDO_ENABLE 0x01
#define CO_CONFIG_SRDO_CHECK_TX 0x02
#define CO_CONFIG_RSRDO_CALLS_EXTENSION 0x04
#define CO_CONFIG_TSRDO_CALLS_EXTENSION 0x08
 * SRDO Tx time delay
 * minimum time between the first and second SRDO (Tx) message
 * in us
#ifdef CO_DOXYGEN
#define CO_CONFIG_SRDO_MINIMUM_DELAY 0
#endif
/** @} */ /* CO_STACK_CONFIG_SRDO */
 * @defgroup CO_STACK_CONFIG_LSS LSS master/slave
 * Specified in standard CiA 305
 * Configuration of @ref CO_LSS
 * - CO_CONFIG_LSS_SLAVE - Enable LSS slave
 * - CO_CONFIG_LSS_SLAVE_FASTSCAN_DIRECT_RESPOND - Send LSS fastscan respond
 *   directly from CO_LSSslave_receive() function.
 * - CO_CONFIG_LSS_MASTER - Enable LSS master
 *   received CAN message.
 *   Callback is configured by CO_LSSmaster_initCallbackPre().
#ifdef CO_DOXYGEN
#define CO_CONFIG_LSS (CO_CONFIG_LSS_SLAVE | CO_CONFIG_GLOBAL_FLAG_CALLBACK_PRE)
#endif
#define CO_CONFIG_LSS_SLAVE 0x01
#define CO_CONFIG_LSS_SLAVE_FASTSCAN_DIRECT_RESPOND 0x02
#define CO_CONFIG_LSS_MASTER 0x10
/** @} */ /* CO_STACK_CONFIG_LSS */
 * @defgroup CO_STACK_CONFIG_GATEWAY CANopen gateway
 * Specified in standard CiA 309
 * Configuration of @ref CO_CANopen_309_3
 * Gateway object is covered by standard CiA 309 - CANopen access from other
 * networks. It enables usage of the NMT master, SDO client and LSS master as a
 * gateway device.
 * - CO_CONFIG_GTW_MULTI_NET - Enable multiple network interfaces in gateway
 *   device. This functionality is currently not implemented.
 * - CO_CONFIG_GTW_ASCII - Enable gateway device with ASCII mapping (CiA 309-3)
 *   If set, then CO_CONFIG_FIFO_ASCII_COMMANDS must also be set.
 * - CO_CONFIG_GTW_ASCII_SDO - Enable SDO client. If set, then
 *   CO_CONFIG_FIFO_ASCII_DATATYPES must also be set.
 * - CO_CONFIG_GTW_ASCII_NMT - Enable NMT master
 * - CO_CONFIG_GTW_ASCII_LSS - Enable LSS master
 * - CO_CONFIG_GTW_ASCII_LOG - Enable non-standard message log read
 * - CO_CONFIG_GTW_ASCII_ERROR_DESC - Print error description as additional
 *   comments in gateway-ascii device for SDO and gateway errors.
 * - CO_CONFIG_GTW_ASCII_PRINT_HELP - use non-standard command "help" to print
 *   help usage.
 * - CO_CONFIG_GTW_ASCII_PRINT_LEDS - Display "red" and "green" CANopen status
 *   LED diodes on terminal.
#ifdef CO_DOXYGEN
#define CO_CONFIG_GTW (0)
#endif
#define CO_CONFIG_GTW_MULTI_NET 0x01
#define CO_CONFIG_GTW_ASCII 0x02
#define CO_CONFIG_GTW_ASCII_SDO 0x04
#define CO_CONFIG_GTW_ASCII_NMT 0x08
#define CO_CONFIG_GTW_ASCII_LSS 0x10
#define CO_CONFIG_GTW_ASCII_LOG 0x20
#define CO_CONFIG_GTW_ASCII_ERROR_DESC 0x40
#define CO_CONFIG_GTW_ASCII_PRINT_HELP 0x80
#define CO_CONFIG_GTW_ASCII_PRINT_LEDS 0x100
 * Number of loops of #CO_SDOclientDownload() in case of block download
 * If SDO clint has block download in progress and OS has buffer for CAN tx
 * messages, then #CO_SDOclientDownload() functionion can be called multiple
 * times within own loop (up to 127). This can speed-up SDO block transfer.
#ifdef CO_DOXYGEN
#define CO_CONFIG_GTW_BLOCK_DL_LOOP 1
#endif
 * Size of command buffer in ASCII gateway object.
 * If large amount of data is transferred (block transfer), then this should be
 * increased to 1000 or more. Buffer may be refilled between the block transfer.
#ifdef CO_DOXYGEN
#define CO_CONFIG_GTWA_COMM_BUF_SIZE 200
#endif
 * Size of message log buffer in ASCII gateway object.
#ifdef CO_DOXYGEN
#define CO_CONFIG_GTWA_LOG_BUF_SIZE 2000
#endif
/** @} */ /* CO_STACK_CONFIG_GATEWAY */
 * @defgroup CO_STACK_CONFIG_CRC16 CRC 16 calculation
 * Helper object for CRC-16 checksum
 * Configuration of @ref CO_crc16_ccitt calculation
 * - CO_CONFIG_CRC16_ENABLE - Enable CRC16 calculation
 * - CO_CONFIG_CRC16_EXTERNAL - CRC functions are defined externally
#ifdef CO_DOXYGEN
#define CO_CONFIG_CRC16 (0)
#endif
#define CO_CONFIG_CRC16_ENABLE 0x01
#define CO_CONFIG_CRC16_EXTERNAL 0x02
/** @} */ /* CO_STACK_CONFIG_CRC16 */
 * @defgroup CO_STACK_CONFIG_FIFO FIFO buffer
 * Helper object for FIFO buffer
 * Configuration of @ref CO_CANopen_301_fifo
 * FIFO buffer is basically a simple first-in first-out circular data buffer. It
 * is used by the SDO client and by the CANopen gateway. It has additional
 * advanced functions for data passed to FIFO.
 * - CO_CONFIG_FIFO_ENABLE - Enable FIFO buffer
 * - CO_CONFIG_FIFO_ALT_READ - This must be enabled, when SDO client has
 *   CO_CONFIG_SDO_CLI_BLOCK enabled. See @ref CO_fifo_altRead().
 * - CO_CONFIG_FIFO_CRC16_CCITT - This must be enabled, when SDO client has
 *   CO_CONFIG_SDO_CLI_BLOCK enabled. It enables CRC calculation on data.
 * - CO_CONFIG_FIFO_ASCII_COMMANDS - This must be enabled, when CANopen gateway
 *   has CO_CONFIG_GTW_ASCII enabled. It adds command handling functions.
 * - CO_CONFIG_FIFO_ASCII_DATATYPES - This must be enabled, when CANopen gateway
 *   has CO_CONFIG_GTW_ASCII and CO_CONFIG_GTW_ASCII_SDO enabled. It adds
 *   datatype transform functions between binary and ascii, which are necessary
 *   for SDO client.
#ifdef CO_DOXYGEN
#define CO_CONFIG_FIFO (0)
#endif
#define CO_CONFIG_FIFO_ENABLE 0x01
#define CO_CONFIG_FIFO_ALT_READ 0x02
#define CO_CONFIG_FIFO_CRC16_CCITT 0x04
#define CO_CONFIG_FIFO_ASCII_COMMANDS 0x08
#define CO_CONFIG_FIFO_ASCII_DATATYPES 0x10
/** @} */ /* CO_STACK_CONFIG_FIFO */
 * @defgroup CO_STACK_CONFIG_TRACE Trace recorder
 * Non standard object
 * Configuration of @ref CO_trace for recording variables over time.
 * - CO_CONFIG_TRACE_ENABLE - Enable Trace recorder
 * - CO_CONFIG_TRACE_OWN_INTTYPES - If set, then macros PRIu32("u" or "lu")
 *   and PRId32("d" or "ld") must be set. (File inttypes.h can not be included).
#ifdef CO_DOXYGEN
#define CO_CONFIG_TRACE (0)
#endif
#define CO_CONFIG_TRACE_ENABLE 0x01
#define CO_CONFIG_TRACE_OWN_INTTYPES 0x02
/** @} */ /* CO_STACK_CONFIG_TRACE */
 * @defgroup CO_STACK_CONFIG_DEBUG Debug messages
 * Messages from different parts of the stack.
 * Configuration of debug messages from different parts of the stack, which can
 * be logged according to target specific function.
 * - CO_CONFIG_DEBUG_COMMON - Define default CO_DEBUG_COMMON(msg) macro. This
 *   macro is target specific. This macro is then used as default macro in all
 *   other defined CO_DEBUG_XXX(msg) macros.
 * - CO_CONFIG_DEBUG_SDO_CLIENT - Define default CO_DEBUG_SDO_CLIENT(msg) macro.
 * - CO_CONFIG_DEBUG_SDO_SERVER - Define default CO_DEBUG_SDO_SERVER(msg) macro.
#ifdef CO_DOXYGEN
#define CO_CONFIG_DEBUG (0)
#endif
#define CO_CONFIG_DEBUG_COMMON 0x01
#define CO_CONFIG_DEBUG_SDO_CLIENT 0x02
#define CO_CONFIG_DEBUG_SDO_SERVER 0x04
/** @} */ /* CO_STACK_CONFIG_DEBUG */
/** @} */ /* CO_STACK_CONFIG */
#ifdef __cplusplus
#endif /* __cplusplus */
#endif /* CO_CONFIG_FLAGS_H */
发表于 2023-9-8 15:29:35 | 显示全部楼层
CO吃透,可以吃一辈子。前提得在外企
 楼主| 发表于 2023-9-8 16:39:39 | 显示全部楼层
十二月的肖邦 发表于 2023-9-8 15:29
CO吃透,可以吃一辈子。前提得在外企
CAN涉及到东西天多了,而且也非常依赖实战经验。学好确实要花不少精力。
发表于 2023-9-8 20:27:58 | 显示全部楼层
没玩过这个,就只知道CAN汽车常用的,其他的常见的还有哪些产品。
 楼主| 发表于 2023-9-9 07:58:58 | 显示全部楼层
目前 CANopen 协议已经在运动控制、车辆工业、轨道交通、电机驱动、工程机械、船舶海运等行业得到广泛的应用
GMT+8, 2026-10-25 12:14 , Processed in 0.249616 second(s), 24 queries .
