查看: 2850|回复: 6
[Source Insight] Source Insight发布更新V4.0.0130
More we do, more we can do.
发表于 2023-8-30 18:31:19 | 显示全部楼层 |阅读模式
Fix: C++ Scoped enums (enum class and enum struct) were not handled correctly by Lookup References and Jump To Definition.
Fix: C++ using enum statements were not recognized.
Fix: C/C++: Some forms of declaring pointers to functions where not recognized.
Fix: C/C++: When there was an extern declaration of a function inside another function, using Jump To Definition of the declared function did not work.
Fix: Import External Symbols: Importing from the INCLUDE path was truncating the path.
Fix: Using custom RegEx parsing with multiple patterns could record incorrect line positions of functions and symbols. This could cause the symbol pane on the left to show the wrong current function.
Fix: Context Window: Selecting an identifier and choosing Show in Relation Window was deactivating the Context window.
Fix: Crash could happen if re-indexing the symbol database and user cancels the re-index operation.
Fix: In some cases after re-parsing a project, the symbol database was not getting updated.
Fix: XML parser was not handling comments with embedded quotes correctly.
Fix: Popup toolbar now uses the same background color as the main toolbar.
Fix: Buffer overrun bugs fixed when typing in some panels to filter the list of symbols or files.
New: You can lock the main toolbar by selecting View > Toolbars > Lock Toolbar
发表于 2023-8-31 13:54:46 | 显示全部楼层
以前的破解还能用吗?
发表于 2023-8-31 15:55:24 | 显示全部楼层
Source Insight Trial
后台审核的时候,好像有个坛友坛友分享了下载,找不到了,我也分享下吧
sourceinsight40130-setup.exe (20.33 MB, 下载次数: 64)
发表于 2023-9-7 09:11:52 | 显示全部楼层
挺好,以前的破解还可以使用!!
发表于 2023-9-11 14:20:32 | 显示全部楼层
有破解lic吗
发表于 2023-10-30 20:21:25 | 显示全部楼层
问哈老哥,有遇到过win11系统,打开Source Insight后过一段时间,它工具栏闪烁,其它软件有的工具栏也闪烁,系统右键菜单都闪烁的情况?把Source Insight关了就好了.
发表于 2023-10-30 20:21:46 | 显示全部楼层
GMT+8, 2026-11-24 11:23 , Processed in 0.350216 second(s), 27 queries .
