查看: 2804|回复: 8
[RL-RTX] 请教下,大神最近移植 rtx5 ,任务堆栈使用数组定义的形式工作正常,使用内存管理申请的方式则不行 ?
发表于 2023-8-29 09:38:52 | 显示全部楼层 |阅读模式
这是为何呀 ??
a. 任务堆栈使用数组形式定义:
   这样形式定义工作完全正常 ok
__ALIGN_8BYTES( os_thread_t   AppTaskStartTCB);
__ALIGN_8BYTES( uint64_t       AppTaskStartStk[(APP_CFG_TASK_START_STK_SIZE * sizeof(uint32_t))/8]);
static const osThreadAttr_t vTaskStart_Attr = {
        .name       = "vTaskStart",
        .attr_bits  = osThreadDetached,
        .priority   = (osPriority_t)APP_CFG_TASK_START_PRIO,
        .stack_size = APP_CFG_TASK_START_STK_SIZE * sizeof(uint32_t),
        .stack_mem  = (void *)&AppTaskStartStk[0],
        .cb_mem     = &AppTaskStartTCB,
        .cb_size    = sizeof(os_thread_t),
                xHandleTask_Start = osThreadNew(vTaskStart, NULL, &vTaskStart_Attr);
                if(xHandleTask_Start != 0) {
                        __log("vTaskStart creat ok ...\r\n");
                else {
                        __log("vTaskStart creat err ...?\r\n");
b. 任务堆栈使用内存管理进行申请方式
os_thread_t   *AppTaskStartTCB = 0;
uint64_t       *AppTaskStartStk = 0;
static  osThreadAttr_t vTaskStart_Attr ;
int main(void)
          AppTaskStartTCB   = (os_thread_t *)mymalloc(SRAM2, sizeof(os_thread_t));
        if(AppTaskStartTCB == NULL)
                My_Printf("AppTaskStartTCB fail ...\r\n");
                while(1) {}
        AppTaskStartStk   = (void *)mymalloc(SRAM2, APP_CFG_TASK_START_STK_SIZE * sizeof(uint32_t));
        if(AppTaskStartStk == NULL)
                My_Printf("AppTaskStartStk fail ...\r\n");
                while(1) {}
        vTaskStart_Attr .name       = "vTaskStart";
        vTaskStart_Attr .attr_bits  = osThreadDetached;
        vTaskStart_Attr .priority   = (osPriority_t)APP_CFG_TASK_START_PRIO;
        vTaskStart_Attr .stack_size = APP_CFG_TASK_START_STK_SIZE * sizeof(uint32_t);
        vTaskStart_Attr .stack_mem  = (void *)AppTaskStartStk;
        vTaskStart_Attr .cb_mem     = AppTaskStartTCB,;
        vTaskStart_Attr .cb_size    = sizeof(os_thread_t);
                else {
                        __log("vTaskStart creat err ...?\r\n");   // 这里就会产生错误 了 哟 ,... ?  难道是 rtx5 不支持这样使用吗 ?
发表于 2023-8-29 13:16:52 | 显示全部楼层
你这种的定义是不是没有8字节对齐
 楼主| 发表于 2023-8-29 15:38:43 | 显示全部楼层
eric2013 发表于 2023-8-29 13:16
你这种的定义是不是没有8字节对齐
AppTaskStartStk   = (void *)mymalloc(SRAM2, APP_CFG_TASK_START_STK ...
之前在 freertos 上使用这种方式貌似是没有问题的
内存申请是 #define ULONG             unsigned long      对齐的,这个应该是 8 字节对齐的吧 ?
发表于 2023-8-29 15:51:42 | 显示全部楼层
可以单步调试进去看看从那个地方反馈的错误,方便修改。
 楼主| 发表于 2023-8-29 16:43:11 | 显示全部楼层
仿真不方便啊,我把 申请到的内存地址打印出地址看看是不是 8 字节对齐的地址
发表于 2023-8-30 11:18:49 | 显示全部楼层
可以这样测试,直接把这两个改成静态数组看看是否正常,如果正常,那就是分配的问题造成的。
 楼主| 发表于 2023-8-30 12:08:40 | 显示全部楼层
vTaskSta ...
我改用数组的形式时, 任务创建成功,而且运行正常,
当又重新改用 内存管理的方式就又不行了哟,难道是内存管理方式分配的地址不符合 rtx5  的要求 ?
但是内存申请分配的地址 我看了 却实是 8 字节对齐的,现在又有些迷糊了啊 。
还是说 这个 rtx5 任务堆栈不支持 指针的形式 ?
发表于 2023-9-1 16:46:37 | 显示全部楼层
当又重新改用 内存管理的方式就又不行了哟,难道 ...
RTOS支持动态分配是基本功能。
可以使用mdk的RTE自动生成一个项目进行对比。 或者RTE中应该可以找到示例项目。
 楼主| 发表于 2023-9-2 13:54:19 | 显示全部楼层
caicaptain2 发表于 2023-9-1 16:46
RTOS支持动态分配是基本功能。
可以使用mdk的RTE自动生成一个项目进行对比。 或者RTE中应该可以找到示 ...
目前还没有找到 rtx5 使用指针的形式 + 内存申请的方法 例程啊,
其他的 os 系统 任务堆栈我使用内存申请的方法都是没有问题的,就唯独这个 rtx5 不行 啊
GMT+8, 2026-11-25 21:49 , Processed in 0.281402 second(s), 24 queries .
