查看: 6930|回复: 21
[SPI/QSPI] 贡献一个H723外扩串行RAM的例子
发表于 2023-8-22 11:20:56 | 显示全部楼层 |阅读模式
APS6404L-3SQR,64M bits(8M bytes, 2^23) and connected to OSPI2 byQSPI mode
CubeMX settings:
Ensure all gpios' speed are set as "very high"
Parameters follow datasheet. The OSPI clk source is 125M.
Enable interrupt
Set as "Device" in MPU
#define PS_OSPI hospi2
#define OCTOSPIx_BASE OCTOSPI2_BASE
#define TOTAL_PS_SIZE (8*1024*1024)
// PSRAM commands
#define FAST_READ_QUAD 0xEB
#define QUAD_WRITE 0x38
#define ENTER_QUAD_MODE 0x35
#define EXIT_QUAD_MODE 0xF5
// settings refer to datasheet
#define FAST_READ_QUAD_DUMMY_CYCLES 6
#define WRITE_QUAD_DUMMY_CYCLES 0
#define ENTER_QUAD_DUMMY_CYCLES 0
void EnableMemMappedQuadMode(void) {
    OSPI_RegularCmdTypeDef sCommand;
    OSPI_MemoryMappedTypeDef sMemMappedCfg;
    sCommand.FlashId = HAL_OSPI_FLASH_ID_1;
    sCommand.InstructionMode = HAL_OSPI_INSTRUCTION_4_LINES;
    sCommand.InstructionSize = HAL_OSPI_INSTRUCTION_8_BITS;
    sCommand.InstructionDtrMode = HAL_OSPI_INSTRUCTION_DTR_DISABLE;
    sCommand.AddressMode = HAL_OSPI_ADDRESS_4_LINES;
    sCommand.AddressSize = HAL_OSPI_ADDRESS_24_BITS;
    sCommand.AddressDtrMode = HAL_OSPI_ADDRESS_DTR_DISABLE;
    sCommand.AlternateBytesMode = HAL_OSPI_ALTERNATE_BYTES_NONE;
    sCommand.DataMode = HAL_OSPI_DATA_4_LINES;
    sCommand.DataDtrMode = HAL_OSPI_DATA_DTR_DISABLE;
    sCommand.SIOOMode = HAL_OSPI_SIOO_INST_EVERY_CMD;
    sCommand.Address = 0;
    sCommand.NbData = 1;
    /* Memory-mapped mode configuration for Quad Read mode 4-4-4*/
    sCommand.OperationType = HAL_OSPI_OPTYPE_READ_CFG;
    sCommand.Instruction = FAST_READ_QUAD;
    sCommand.DummyCycles = FAST_READ_QUAD_DUMMY_CYCLES;
    if (HAL_OSPI_Command(&PS_OSPI, &sCommand, HAL_OSPI_TIMEOUT_DEFAULT_VALUE)
            != HAL_OK) {
        Error_Handler();
    /* Memory-mapped mode configuration for Quad Write mode 4-4-4*/
    sCommand.OperationType = HAL_OSPI_OPTYPE_WRITE_CFG;
    sCommand.Instruction = QUAD_WRITE;
    sCommand.DummyCycles = WRITE_QUAD_DUMMY_CYCLES;
    sCommand.DQSMode = HAL_OSPI_DQS_ENABLE;
            != HAL_OK) {
        Error_Handler();
    /*Disable timeout counter for memory mapped mode*/
    sMemMappedCfg.TimeOutActivation = HAL_OSPI_TIMEOUT_COUNTER_DISABLE;
    /*Enable memory mapped mode*/
    if (HAL_OSPI_MemoryMapped(&PS_OSPI, &sMemMappedCfg) != HAL_OK) {
        Error_Handler();
void EnterQuadMode(void) {
    sCommand.OperationType = HAL_OSPI_OPTYPE_COMMON_CFG;
    sCommand.Instruction = ENTER_QUAD_MODE;
    sCommand.InstructionMode = HAL_OSPI_INSTRUCTION_1_LINE;
    sCommand.AddressMode = HAL_OSPI_ADDRESS_NONE;
    sCommand.DataMode = HAL_OSPI_DATA_NONE;
    sCommand.DummyCycles = ENTER_QUAD_DUMMY_CYCLES;
    sCommand.DQSMode = HAL_OSPI_DQS_DISABLE;
    /*Enter QUAD mode*/
            != HAL_OK) {
        Error_Handler();
int PsRamTest() {
    __IO uint32_t *mem_addr;
    uint32_t wr = 0x55000000;
    mem_addr = (__IO uint32_t*)OCTOSPIx_BASE;
    for (int i = 0; i < TOTAL_PS_SIZE/4; i++) {
        *mem_addr++ = wr++;
    wr = 0x55000000;
    int errcnt = 0;
        if (*mem_addr++ != wr++) {
            errcnt++;
    return errcnt;
参与人数 2金币 +120 收起 理由
江南月 + 20 赞一个!
eric2013 + 100 很给力!
发表于 2023-8-22 11:28:04 | 显示全部楼层
速度能上到多少
发表于 2023-8-22 11:35:27 | 显示全部楼层
谢谢楼主分享,非常好的分享贴。之前还有网友咨询外接QSPI RAM
https://www.apmemory.com/wp-content/uploads/APS6404L-3SQR.pdf
发表于 2023-8-22 11:57:08 | 显示全部楼层
从他的截图来看,是配置的62.5M
 楼主| 发表于 2023-8-22 14:02:10 | 显示全部楼层
https://www.apmemory.com/wp-content/up ...
测试部分在freertos中会有写错误,硬汉如果有空能不能帮忙分析一下可能是哪里的问题?
发表于 2023-8-23 08:22:45 | 显示全部楼层
加大下.DummyCycless是不是好点。
 楼主| 发表于 2023-8-23 09:50:17 | 显示全部楼层
搞定了,cache的问题,lz位已更新
发表于 2023-8-23 13:43:35 | 显示全部楼层
这种串行RAM,一般用来做什么用途呢?
发表于 2023-8-23 14:12:02 | 显示全部楼层
能直接DMA操作吗? 比如把ADC的数据用DMA送到串行RAM?
发表于 2023-8-23 16:12:05 | 显示全部楼层
能直接读写吗?还是可以直接读,不能直接写?
发表于 2023-8-23 18:12:58 | 显示全部楼层
eric2013 发表于 2023-8-22 11:57
从他的截图来看,是配置的62.5M
请教下,他这个可以写吗?QSPI 内存映射模式是不是只能读啊?
发表于 2023-8-24 00:42:59 | 显示全部楼层
QSPI Flash不能写。
他这个是QSPI RAM,可以写。
发表于 2023-8-24 00:43:33 | 显示全部楼层
可以的。
发表于 2023-8-24 00:43:48 | 显示全部楼层
QSPI Flash不能写。
他这个是QSPI RAM,可以写。
发表于 2023-8-24 00:46:13 | 显示全部楼层
morning_enr6U 发表于 2023-8-23 13:43
这种串行RAM,一般用来做什么用途呢?
他这个是QSPI RAM,速度不慢,驱动60MHz,差不多速度得有20-30MB
发表于 2023-8-24 00:46:27 | 显示全部楼层
regsofweb 发表于 2023-8-23 09:50
搞定了,cache的问题,lz位已更新
谢谢告知最终原因。
发表于 2023-8-24 10:58:44 | 显示全部楼层
刚开始还挺惊讶,想着qspi的内存映射模式居然能写了,然后仔细查了手册才发现是因为楼主用的是OCTOSPI才能实现,这个外设确实支持内存映射写
发表于 2023-8-26 17:49:36 | 显示全部楼层
这个对比SDRAM速度怎么样
发表于 2023-8-26 21:21:00 | 显示全部楼层
这个串行RAM只有OCTOSPI才能实现吗,H743的QSPI不能写吗?
发表于 2023-8-27 09:21:53 | 显示全部楼层
244141084 发表于 2023-8-26 17:49
这个对比SDRAM速度怎么样
比不了SDRAM,SDRAM是16bit,32bit的。
发表于 2023-8-27 09:25:18 | 显示全部楼层
手册里面的说明是仅可以读
发表于 2025-1-8 15:15:53 | 显示全部楼层
谢谢楼主,
我用这个芯片遇到了一个奇怪的问题,不过解决了
帖子在这里
https://forum.anfulai.cn/forum.p ... d=127210&extra=
GMT+8, 2026-10-24 09:27 , Processed in 0.271319 second(s), 28 queries .
