查看: 1619|回复: 2
H7和F4的emwin的LCDConf_LinTemplate.c文件中的层初始化函数有点不一样
发表于 2023-8-18 16:20:53 | 显示全部楼层 |阅读模式
下面F429的部分代码主要意思是啥呢?
       LTDC_Layer_InitStruct.LTDC_HorizontalStart = HSYNC_W + HBP + 1;
        LTDC_Layer_InitStruct.LTDC_HorizontalStop = (Width + LTDC_Layer_InitStruct.LTDC_HorizontalStart - 1);
        LTDC_Layer_InitStruct.LTDC_VerticalStart = VSYNC_W + VBP + 1;
        LTDC_Layer_InitStruct.LTDC_VerticalStop = (Height + LTDC_Layer_InitStruct.LTDC_VerticalStart - 1);
       LTDC_Layer_InitStruct.LTDC_CFBLineLength    = BytesPerLine + 3;
        LTDC_Layer_InitStruct.LTDC_CFBPitch         = BytesPerLine;
        LTDC_Layer_InitStruct.LTDC_CFBLineNumber    = ySize;
static void LCD_LL_LayerInit(U32 LayerIndex)
        LTDC_LayerCfgTypeDef  layer_cfg;
        static uint32_t       LUT[256];
        uint32_t              i;
        if (LayerIndex < GUI_NUM_LAYERS)
                /* 窗口显示区设置 */
                layer_cfg.WindowX0 = 0;
                layer_cfg.WindowX1 = g_LcdWidth;
                layer_cfg.WindowY0 = 0;
                layer_cfg.WindowY1 = g_LcdHeight;
                /* 配置颜色格式 */
                layer_cfg.PixelFormat = _GetPixelformat(LayerIndex);
                /* 显存地址 */
                layer_cfg.FBStartAdress = layer_prop[LayerIndex].address;
                /* Alpha常数 (255 表示完全不透明) */
                layer_cfg.Alpha = 255;
                /* 无背景色 */
                layer_cfg.Alpha0 = 0;   /* 完全透明 */
                layer_cfg.Backcolor.Blue = 0;
                layer_cfg.Backcolor.Green = 0;
                layer_cfg.Backcolor.Red = 0;
                /* 配置图层混合因数 */
                layer_cfg.BlendingFactor1 = LTDC_BLENDING_FACTOR1_PAxCA;
                layer_cfg.BlendingFactor2 = LTDC_BLENDING_FACTOR2_PAxCA;
                /* 配置行列大小 */
                layer_cfg.ImageWidth = g_LcdWidth;
                layer_cfg.ImageHeight = g_LcdHeight;
                /* 配置图层1 */
                HAL_LTDC_ConfigLayer(&hltdc, &layer_cfg, LayerIndex);
                /* 使能LUT */
                if (LCD_GetBitsPerPixelEx(LayerIndex) <= 8)
                        HAL_LTDC_EnableCLUT(&hltdc, LayerIndex);
                        /*  AL88模式(16bpp) */
                        if (layer_prop[LayerIndex].pColorConvAPI == GUICC_88666I)
                                for (i = 0; i < 256; i++)
                                        LUT[i] = LCD_API_ColorConv_8666.pfIndex2Color(i);
                                HAL_LTDC_ConfigCLUT(&hltdc, LUT, 256, LayerIndex);
static void _LCD_InitController(int LayerIndex)
        LTDC_Layer_InitTypeDef LTDC_Layer_InitStruct = {0};
        int xSize, ySize, BytesPerLine, BitsPerPixel, i;
        U32 Pixelformat, Color;
        static int Done;
        if (LayerIndex >= GUI_COUNTOF(_apLayer))
                return;
[color=#ff0000]        if (Done == 0)
                Done = 1;
                // Enable line interrupt
                LTDC_ITConfig(LTDC_IER_LIE, ENABLE);
                NVIC_SetPriority(LTDC_IRQn, 0);
                NVIC_EnableIRQ(LTDC_IRQn);
                #if emWin_Optimize
                        // Enable DMA2D transfer complete interrupt
                        DMA2D_ITConfig(DMA2D_CR_TCIE, ENABLE);
                        NVIC_SetPriority(DMA2D_IRQn, 0);
                        NVIC_EnableIRQ(DMA2D_IRQn);
                        // Clear transfer complete interrupt flag
                        DMA2D->IFCR = (U32)DMA2D_IFSR_CTCIF;
                #endif
        }[/color]
        // Layer configuration
        xSize = LCD_GetXSizeEx(LayerIndex);
        ySize = LCD_GetYSizeEx(LayerIndex);
        // HorizontalStart = (Offset_X + Hsync + HBP);
    // HorizontalStop  = (Offset_X + Hsync + HBP + Window_Width - 1);
    // VarticalStart   = (Offset_Y + Vsync + VBP);
    // VerticalStop    = (Offset_Y + Vsync + VBP + Window_Heigh - 1);
[color=#ff0000]        LTDC_Layer_InitStruct.LTDC_HorizontalStart = HSYNC_W + HBP + 1;
        LTDC_Layer_InitStruct.LTDC_VerticalStop = (Height + LTDC_Layer_InitStruct.LTDC_VerticalStart - 1);[/color]
        // Pixel Format configuration
        Pixelformat = _GetPixelformat(LayerIndex);
        LTDC_Layer_InitStruct.LTDC_PixelFormat = Pixelformat;
        // Alpha constant (255 totally opaque)
        LTDC_Layer_InitStruct.LTDC_ConstantAlpha = 255;
        // Default Color configuration (configure A, R, G, B component values)
        LTDC_Layer_InitStruct.LTDC_DefaultColorBlue  = 0;
        LTDC_Layer_InitStruct.LTDC_DefaultColorGreen = 0;
        LTDC_Layer_InitStruct.LTDC_DefaultColorRed   = 0;
        LTDC_Layer_InitStruct.LTDC_DefaultColorAlpha = 0;
        // Configure blending factors
        BytesPerLine = _GetBytesPerLine(LayerIndex, xSize);
        LTDC_Layer_InitStruct.LTDC_BlendingFactor_1 = LTDC_BlendingFactor1_PAxCA;
        LTDC_Layer_InitStruct.LTDC_BlendingFactor_2 = LTDC_BlendingFactor2_PAxCA;
[color=#ff0000]        LTDC_Layer_InitStruct.LTDC_CFBLineLength    = BytesPerLine + 3;
        LTDC_Layer_InitStruct.LTDC_CFBLineNumber    = ySize;[/color]
        // Input Address configuration
        LTDC_Layer_InitStruct.LTDC_CFBStartAdress = _aAddr[LayerIndex];
        LTDC_LayerInit(_apLayer[LayerIndex], <DC_Layer_InitStruct);
        // Enable LUT on demand
        BitsPerPixel = LCD_GetBitsPerPixelEx(LayerIndex);
        if (BitsPerPixel <= 8)
                // Enable usage of LUT for all modes with <= 8bpp
                _LTDC_LayerEnableLUT(_apLayer[LayerIndex], ENABLE);
                // Optional CLUT initialization for L8 mode (8bpp)
                if (_apColorConvAPI[LayerIndex] == GUICC_1616I)
                        for (i = 0; i < 16; i++)
                                Color = LCD_API_ColorConv_1616I.pfIndex2Color(i);
                                _LTDC_SetLUTEntry(LayerIndex, Color, i);
                // Optional CLUT initialization for AL44 mode (8bpp)
                if (_apColorConvAPI[LayerIndex] == GUICC_8666)
                                Color = LCD_API_ColorConv_8666.pfIndex2Color(i);
                // Optional CLUT initialization for AL88 mode (16bpp)
                if (_apColorConvAPI[LayerIndex] == GUICC_88666I)
        // Enable layer
        LTDC_LayerCmd(_apLayer[LayerIndex], ENABLE);
        // Reload configuration
        LTDC_ReloadConfig(LTDC_SRCR_IMR);
发表于 2023-8-18 16:57:18 | 显示全部楼层
楼主看的F429,是不是看的标准库版的。F429也有个HAL版的可以查看。
 楼主| 发表于 2023-8-19 09:01:26 | 显示全部楼层
找到了F429HAL库版本的emwin了。我上面黄色代码标准库的配置,意思应该是配置/* 窗口显示区设置 */?
层初始化的时候标准库为啥要打开中断的操作?hal库没有呢?
if (Done == 0) {
    Done = 1;
//    LCD_Init();
GMT+8, 2026-11-25 10:14 , Processed in 0.384243 second(s), 24 queries .
