查看: 1189|回复: 0
[Lua] LUA的Table变量和函数名不能设置成一个,折腾一晚上才发现这里搞错了
发表于 2023-8-13 08:41:29 | 显示全部楼层 |阅读模式
测试的时候没注意这个地方,命名成一个了:
[Lua] 纯文本查看 复制代码
local ListTcp =
	{"|TCB Addr    = ", '   '},
	{"|NamePtr     = ", '   '},
	{"|TaskPrio    = ", '   '},
	{"|StackSize   = ", '   '},
	{"|StackStart  = ", '   '},
	{"|StackEnd    = ", '   '},
	{"|StackHigh   = ", '   '},
	{"|StackPtr    = ", '   '},
	{"|TaskState   = ", '   '},
	{"|TaskRunCout = ", '   '},
	{"|CreatedPrev = ", '<--'},
	{"|CreatedNext = ", '   '},
function ListTcp(pcbpcb, strstr)
        local tmppcb1, tmppcb2
        str2 = "  "
        ListTcp[1][2] =ListTcp[1][2]..ListTcp[1][1].."   "
		ListTcp[2][2] =ListTcp[2][2]..ListTcp[2][1]..string.format("0x%-17x|", pcbpcb).."   "
导致测试一直不对,整懵了,花了不少时间才锁定是这里搞错了。
GMT+8, 2026-3-7 14:53 , Processed in 0.356840 second(s), 24 queries .
